GitLab
Support
Community forum
Keyboard shortcuts
menhir
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
POTTIER Francois
menhir
2135285b
2135285b
POTTIER Francois
Renamed main_incremental to Incremental.main.
This guarantees the absence of name clashes.
a2c403bc
7
7 changed files
50 additions
35 deletions
+50
-35
CHANGES
CHANGES
+4
TODO
TODO
+0
-8
demos/calc-incremental/calc.ml
+1
-1
doc/main.tex
doc/main.tex
+13
-8
src/interface.ml
src/interface.ml
+10
-11
src/interface.mli
src/interface.mli
+2
-2
src/tableBackend.ml
src/tableBackend.ml
+20
-5
CHANGES
2135285b
2015/01/01:
Incompatible change of the incremental API.
The entry point main_incremental is now named Incremental.main.
2014/12/29:
2014/12/29:
The API now exposes reduction events.
TODO
2135285b
* Introduce a submodule Incremental for the incremental entry
points. Move also the types terminal, nonterminal, symbol
to a sub-module, to avoid any name clashes.
* Clean up Interface and tableBackend. Decide whether we need
a new switch (--inspect) for the inspection API. Condition
[terminal], [nonterminal], etc. to this new switch.
* IncrementalEngine: document [lr1state], [element], [view].
* Define MenhirLib.Stream?
2135285b
@@ -107,7 +107,7 @@ let rec loop linebuf (result : int I.result) =
let
process
line
string
let
process
line
string
let
linebuf
Lexing
from_string
line
in
let
linebuf
Lexing
from_string
line
in
try
try
loop
linebuf
Parser
main_incremental
loop
linebuf
Parser
Incremental
main
Lexer
Error
msg
Lexer
Error
msg
Printf
fprintf
stderr
"%s%!"
msg
Printf
fprintf
stderr
"%s%!"
msg
doc/main.tex
2135285b
@@ -1797,7 +1797,8 @@ We assume that the grammar specification has just one start symbol
\label
sec:monolithic
\label
sec:monolithic
The monolithic API consists in just one parsing function, named after the
start symbol:
start symbol. The generated file
\texttt
parser.mli
contains the following
declaration:
\begin{verbatim}
\begin{verbatim}
val main: (Lexing.lexbuf -> token) -> Lexing.lexbuf -> thing
\end{verbatim}
\end{verbatim}
@@ -1839,10 +1840,14 @@ $O(n)$ space in memory.
% TEMPORARY actually, live parsing also requires a way of performing
% error recovery, up to a complete parse... as in Merlin.
In this API, the parser is started by invoking
\verb
main_incremental
where
\mystartsymbol
is the name of the start symbol:
\texttt
Incremental.
\mystartsymbol
. (Recall that we assume
\mystartsymbol
is
the name of the start symbol.) The generated file
\texttt
parser.mli
contains
the following declaration:
\begin{verbatim}
\begin{verbatim}
val main
_
incremental: unit -> thing MenhirInterpreter.result
module Incremental : sig
val main: unit -> thing MenhirInterpreter.result
\end{verbatim}
\end{verbatim}
The sub-module
\menhirinterpreter
is also part of the incremental API.
The sub-module
\menhirinterpreter
@@ -1932,10 +1937,10 @@ parser has suspended itself with a result of the form
This function expects just the previous result
\verb
result
. It produces a new
\verb
result
. It produces a new
result. It does not raise any exception.
The incremental API subsumes the monolithic API. Indeed,
verb
main
can
mystartsymbol
can be
be (and is in fact) implemented by first using
\verb
main_incremental
, then
calling
\verb
offer
\verb
resume
in a loop, until a final result is
\texttt
Incremental.
\mystartsymbol
, then calling
\verb
offer
obtained.
\verb
resume
obtained.
At this time, because the type
\verb
env
is opaque, the state of the parser
\verb
env
cannot be inspected by the user. We plan to offer an inspection API in the
src/interface.ml
2135285b
@@ -40,13 +40,10 @@ let result t =
(* The name of the
incremental entry point for the start symbol [symbol]
(* The name of the
sub-module that contains the incremental entry points
let
incremental
symbol
let
incremental
(* This convention is not great. A name clash with a non-incremental
"Incremental"
entry point is possible if there exists a nonterminal symbol whose name
ends with [_incremental]. It would be preferable to introduce a sub-module. *)
Misc
normalize
symbol
"_incremental"
(* The type of the incremental entry point for the start symbol [symbol]. *)
@@ -93,11 +90,13 @@ let incremental_api grammar () =
IIComment
"The entry point(s) to the incremental API."
IIComment
IIValDecls
IIModule
incremental
MTSigEnd
StringSet
fold
fun
symbol
decls
IIValDecls
incremental
symbol
entrytypescheme_incremental
grammar
symbol
decls
StringSet
fold
fun
symbol
decls
grammar
start_symbols
symbol
grammar
symbol
decls
grammar
start_symbols
src/interface.mli
2135285b
@@ -19,9 +19,9 @@ val interpreter: string
val
result
IL
typ
IL
typ
val
result
IL
typ
IL
typ
(* The name of the
(* The name of the
val
incremental
string
string
val
incremental
string
(* This writes the interface of the generated parser to the [.mli] file. *)
src/tableBackend.ml
2135285b
@@ -687,7 +687,9 @@ let application =
(* The client API invokes the interpreter with an appropriate start state. *)
(* The client APIs invoke the interpreter with an appropriate start state.
The monolithic API calls [entry] (see [Engine]), while the incremental
API calls [start]. *)
(* An entry point to the monolithic API. *)
@@ -713,11 +715,19 @@ let monolithic_entry_point state nt t =
(* The whole monolithic API. *)
let
monolithic_api
IL
valdef
list
Lr1
fold_entry
fun
_prod
state
nt
t
api
state
nt
t
api
(* An entry point to the incremental API. *)
let
incremental_entry_point
state
nt
t
let
state
nt
t
define
define
incremental
Nonterminal
print
true
nt
Nonterminal
print
true
nt
(* In principle the abstraction [fun () -> ...] should not be
necessary, since [start] is a pure function. However, when
[--trace] is enabled, [start] will log messages to the
@@ -737,9 +747,10 @@ let incremental_entry_point state nt t =
let
api
IL
valdef
list
(* The whole incremental API. *)
let
incremental_api
IL
valdef
list
Lr1
fold_entry
fun
_prod
state
nt
t
api
Lr1
fold_entry
fun
_prod
state
nt
t
api
state
nt
t
state
nt
t
state
nt
t
api
api
@@ -859,7 +870,11 @@ let program =
SIModuleDef
interpreter
application
SIModuleDef
interpreter
application
SIValDefs
false
api
SIValDefs
false
monolithic_api
SIModuleDef
incremental
MStruct
SIValDefs
false
incremental_api
listiflazy
Settings
inspection
fun
listiflazy
Settings
inspection
fun
