Commit 1eb50c49 authored by POTTIER Francois's avatar POTTIER Francois
More beautiful grammar of expressions, using binary unions instead
of flat lists.
parent 74b133ce
...@@ -887,45 +887,35 @@ end ...@@ -887,45 +887,35 @@ end
symbols (in a first pass), then solve the constraints (in a second symbols (in a first pass), then solve the constraints (in a second
pass). *) pass). *)
(* A member of an equation's right-hand side is either a variable (named after (* An equation's right-hand side is a set expression. *)
a nonterminal symbol) or a constant (a set of terminal symbols). *)
type member = type expr =
| MemberVar of Nonterminal.t | EVar of Nonterminal.t
| MemberConstant of TerminalSet.t | EConstant of TerminalSet.t
| EUnion of expr * expr
(* A right-hand side is a list of members. *)
type rhs =
member list
(* A system of equations is represented as an array, which maps nonterminal (* A system of equations is represented as an array, which maps nonterminal
symbols to right-hand sides. *) symbols to expressions. *)
type equations = type equations =
rhs array expr array
(* This solver computes the least solution of a set of equations. *) (* This solver computes the least solution of a set of equations. *)
let solve (eqs : equations) : Nonterminal.t -> TerminalSet.t = let solve (eqs : equations) : Nonterminal.t -> TerminalSet.t =
let member m get = let rec expr e get =
match m with match e with
| MemberVar nt -> | EVar nt ->
get nt get nt
| MemberConstant c -> | EConstant c ->
c c
in | EUnion (e1, e2) ->
TerminalSet.union (expr e1 get) (expr e2 get)
let rhs rhs get =
(* Union of all members. *)
List.fold_left (fun accu m ->
TerminalSet.union accu (member m get)
) TerminalSet.empty rhs
in in
let nonterminal nt get = let nonterminal nt get =
rhs eqs.(nt) get expr eqs.(nt) get
in in
let module F = let module F =
...@@ -1054,15 +1044,15 @@ let follow : Nonterminal.t -> TerminalSet.t = ...@@ -1054,15 +1044,15 @@ let follow : Nonterminal.t -> TerminalSet.t =
symbols. *) symbols. *)
let follow : equations = let follow : equations =
Array.make Nonterminal.n [] Array.make Nonterminal.n (EConstant TerminalSet.empty)
in in
(* Iterate over all start symbols. *) (* Iterate over all start symbols. *)
let sharp = MemberConstant (TerminalSet.singleton Terminal.sharp) in let sharp = EConstant (TerminalSet.singleton Terminal.sharp) in
for nt = 0 to Nonterminal.start - 1 do for nt = 0 to Nonterminal.start - 1 do
assert (Nonterminal.is_start nt); assert (Nonterminal.is_start nt);
(* Add # to FOLLOW(nt). *) (* Add # to FOLLOW(nt). *)
follow.(nt) <- sharp :: follow.(nt) follow.(nt) <- EUnion (sharp, follow.(nt))
done; done;
(* We need to do this explicitly because our start productions are (* We need to do this explicitly because our start productions are
of the form S' -> S, not S' -> S #, so # will not automatically of the form S' -> S, not S' -> S #, so # will not automatically
...@@ -1080,11 +1070,11 @@ let follow : Nonterminal.t -> TerminalSet.t = ...@@ -1080,11 +1070,11 @@ let follow : Nonterminal.t -> TerminalSet.t =
and first = FIRST.production prod (i+1) in and first = FIRST.production prod (i+1) in
(* The FIRST set of the remainder of the right-hand side (* The FIRST set of the remainder of the right-hand side
contributes to the FOLLOW set of [nt2]. *) contributes to the FOLLOW set of [nt2]. *)
follow.(nt2) <- MemberConstant first :: follow.(nt2); follow.(nt2) <- EUnion (EConstant first, follow.(nt2));
(* If the remainder of the right-hand side is nullable, (* If the remainder of the right-hand side is nullable,
FOLLOW(nt1) contributes to FOLLOW(nt2). *) FOLLOW(nt1) contributes to FOLLOW(nt2). *)
if nullable then if nullable then
follow.(nt2) <- MemberVar nt1 :: follow.(nt2) follow.(nt2) <- EUnion (EVar nt1, follow.(nt2))
) rhs ) rhs
) Production.table; ) Production.table;
