Commit 1b9ef0c4 authored by POTTIER Francois's avatar POTTIER Francois
Added [embedded] to standard.mly. Extensive comment.
parent 04e7f44a
* Document anonymous rules. * Document anonymous rules.
Produce well-chosen (predictable) names for anonymous rules. Produce well-chosen (predictable) names for anonymous rules.
In the standard library, possibly rename "anonymous" and "embedded"
and document them. The non-inline version allows embedding an action in the
middle of a rule.
* ErrorReporting: experiment with merging several symbols * ErrorReporting: experiment with merging several symbols
so as to reduce the noise (e.g. operators, expressions, so as to reduce the noise (e.g. operators, expressions,
...@@ -9,11 +9,71 @@ ...@@ -9,11 +9,71 @@
(* [anonymous(X)] is the same as [X]. *) (* [anonymous(X)] is the same as [X]. *)
(* This can be useful because it allows placing an anonymous sub-rule in (* This allows placing an anonymous sub-rule in the middle of a rule, as in:
the middle of a rule, as in [foo anonymous(bar { ... } | quux { ...}) baz]. *)
foo
anonymous(baz { action1 })
bar
{ action2 }
Because anonymous is marked %inline, everything is expanded away. So,
this is equivalent to:
foo baz bar { action1; action2 }
Note that [action1] moves to the end of the rule. The anonymous sub-rule
can even have several branches, as in:
foo
anonymous(baz { action1a } | quux { action1b })
bar
{ action2 }
This is expanded to:
foo baz bar { action1a; action2 }
| foo quux bar { action1b; action2 }
%public %inline anonymous(X): %public %inline anonymous(X):
x = X x = X
{ x }
(* [embedded(X)] is the same as [X]. *)
foo
embedded(baz { action1 })
bar
{ action2 }
Because [embedded] is not marked %inline, this is equivalent to:
foo xxx bar { action2 }
where the fresh non-terminal symbol [xxx] is separately defined by:
xxx: baz { action1 }
In particular, if there is no [baz], what we get is a semantic action
embedded in the middle of a rule. For instance,
foo embedded({ action1 }) bar { action2 }
is equivalent to:
where [xxx] is separately defined by the rule:
xxx: { action1 }
%public embedded(X):
x = X
{ x } { x }
