GitLab
Support
Community forum
Keyboard shortcuts
menhir
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
POTTIER Francois
menhir
159fe729
159fe729
POTTIER Francois
Modified the build rules for [calc-two] so as to avoid unused token warnings.
a4611cf8
2
2 changed files
14 additions
6 deletions
+14
-6
demos/calc-two/_tags
+2
demos/calc-two/myocamlbuild.ml
+12
-6
159fe729
<tokens.mlypack>: only_tokens
<algebraic.mlypack>: external_tokens(Tokens)
<reverse.mlypack>: external_tokens(Tokens)
<reverse.mly>: unused_token(LPAREN)
<reverse.mly>: unused_token(RPAREN)
159fe729
open
Ocamlbuild_plugin
open
Ocamlbuild_plugin
open
Command
open
Command
(* Define ocamlbuild flags [only_tokens] and [external_tokens(Foo)] and
[unused_token(Bar)] which correspond to menhir's [--only-tokens] and
[--external-tokens Foo] and [--unused-token Bar]. When they are used, these
flags should be passed both to [menhir] and to [menhir --raw-depend]. *)
let
menhir_flags
let
menhir_flags
(* Define two ocamlbuild flags [only_tokens] and [external_tokens(Foo)]
which correspond to menhir's [--only-tokens] and [--external-tokens Foo].
When they are used, these flags should be passed both to [menhir] and to
iter
fun
mode
iter
fun
mode
flag
mode
"only_tokens"
S
A
"--only-tokens"
flag
mode
"only_tokens"
S
A
"--only-tokens"
pflag
mode
"external_tokens"
fun
name
pflag
mode
"external_tokens"
fun
name
S
A
"--external-tokens"
A
name
S
A
"--external-tokens"
A
name
pflag
mode
"unused_token"
fun
name
S
A
"--unused-token"
A
name
"menhir"
"menhir_ocamldep"
"menhir"
"menhir_ocamldep"
let
let
dispatch
fun
event
dispatch
fun
event
match
event
match
event
After_rules
After_rules
menhir_flags
menhir_flags
_
_
