Commit 1331fffa authored by POTTIER Francois's avatar POTTIER Francois
TODO.
parent b0aba629
* Add a syntax for puns, "x = x".
* Set up continuous integration (ci.inria.fr)... * Set up continuous integration (ci.inria.fr)...
Check that Menhir builds (and the test pass) Check that Menhir builds (and the test pass)
with multiple versions of OCaml. with multiple versions of OCaml.
* Add an --auto-inline pass, which marks certain symbols %inline according
to a well-defined strategy. E.g.,
- mark %inline every symbol that is referenced only once
- mark %inline every symbol that has only one production
(unconditional? subject to a size constraint?)
- mark %inline every symbol whose productions have length <= 1
Ideally, do this *after* the analyses that guarantee that every symbol
is reachable and recognizes a nonempty language.
Check that the auto-%inlined symbol has no %prec annotation.
Document that --auto-inline requires pure semantic actions.
(Note that --auto-inline turns midrule into endrule!)
Should --auto-inline be a command line switch, or a directive %autoinline?
Consider adding %noinline to prevent --auto-inline from inlining a symbol.
* Add a command line option to control how "MenhirLib" should be named in the * Add a command line option to control how "MenhirLib" should be named in the
generated code. (Suggested by Gabriel Scherer.) generated code. (Suggested by Gabriel Scherer.)
* Incremental API: expose a function `lookahead` of type `'a env -> token option`. * Incremental API: expose a function `lookahead` of type `'a env -> token option`.
* Do not host the .tar.gz archive on yquem. Look into gitlab.inria.fr.
* Think about implementing Adams and Might's technique for intersecting * Think about implementing Adams and Might's technique for intersecting
a grammar with a tree automaton. (As a preprocessing step. Think about a grammar with a tree automaton. (As a preprocessing step. Think about
the interaction with parameterized symbols and with %inline.) the interaction with parameterized symbols and with %inline.)
...@@ -172,8 +154,7 @@ ...@@ -172,8 +154,7 @@
* Documenter la différence de philosophie avec Denny & Malloy à propos * Documenter la différence de philosophie avec Denny & Malloy à propos
des conflits (cf. email à Laurence Tratt). des conflits (cf. email à Laurence Tratt).
* Accept Jacques-Henri's pull request which packages the Coq library. * Add demos/calc-coq to show how the Coq back-end is used.
Add demos/calc-coq to show how it is used.
* Simplify the demos by assuming that Menhir is already installed. * Simplify the demos by assuming that Menhir is already installed.
Remove find-menhir.sh. Remove find-menhir.sh.
...@@ -217,8 +198,6 @@ ...@@ -217,8 +198,6 @@
* (petit) BUG: --follow-construction n'affiche pas le contenu des états * (petit) BUG: --follow-construction n'affiche pas le contenu des états
initiaux (r0) initiaux (r0)
* que fait/que doit faire la combinaison --tokens-only --depend?
* Préserver dirname/ dans les directives #line émises. * Préserver dirname/ dans les directives #line émises.
* BUG: Boris (1.- bouclage parser sur une entrée erronée 2.- une lecture * BUG: Boris (1.- bouclage parser sur une entrée erronée 2.- une lecture
...@@ -243,10 +222,6 @@ ...@@ -243,10 +222,6 @@
ete supprimees par resolution de conflits. Afficher aussi les ete supprimees par resolution de conflits. Afficher aussi les
réductions par défaut? réductions par défaut?
* Read Chen and Pager's paper, "An Extension Of The Unit Production
Elimination Algorithm", and find out whether such an optimization
would be useful (beneficial) in the context of Menhir.
* Ideally, [PartialGrammar] should avoid renaming the parameters of * Ideally, [PartialGrammar] should avoid renaming the parameters of
a rule, when there is no need to do so. The renamed parameter is a rule, when there is no need to do so. The renamed parameter is
visible in sort unification error messages and in messages about visible in sort unification error messages and in messages about
...@@ -2,6 +2,20 @@ This file contains a series of ideas and remarks that could be in ...@@ -2,6 +2,20 @@ This file contains a series of ideas and remarks that could be in
the TODO list -- except I do not intend to do anything about them, the TODO list -- except I do not intend to do anything about them,
for now. for now.
* Incompatibility with ocamlyacc/yacc/bison: these tools guarantee * Incompatibility with ocamlyacc/yacc/bison: these tools guarantee
to perform a default reduction without looking ahead at the next to perform a default reduction without looking ahead at the next
token, whereas Menhir does not. token, whereas Menhir does not.
...@@ -92,3 +106,7 @@ for now. ...@@ -92,3 +106,7 @@ for now.
conservative? There may be situations where there is no reduce action conservative? There may be situations where there is no reduce action
in the table (because they were killed off by conflict resolution) yet in the table (because they were killed off by conflict resolution) yet
this state is still capable of reducing this production. this state is still capable of reducing this production.
