Attention une mise à jour du service Gitlab va être effectuée le mardi 30 novembre entre 17h30 et 18h00. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes. Cette mise à jour intermédiaire en version 14.0.12 nous permettra de rapidement pouvoir mettre à votre disposition une version plus récente.
Commit 06df0f59 authored by POTTIER Francois's avatar POTTIER Francois
Cleanup of [Interpret]. Now able to read a .messages file.
parent ce8395ac
...@@ -12,6 +12,27 @@ module I = Invariant (* artificial dependency; ensures that [Invariant] runs fir ...@@ -12,6 +12,27 @@ module I = Invariant (* artificial dependency; ensures that [Invariant] runs fir
type sentence = type sentence =
Nonterminal.t option * Terminal.t list Nonterminal.t option * Terminal.t list
(* Debugging.
let print_sentence (nto, terminals) : string =
let b = Buffer.create 128 in
Option.iter (fun nt ->
Printf.bprintf b "%s: " (Nonterminal.print true nt)
) nto;
List.iter (fun t ->
Printf.bprintf b "%s " (Terminal.print t)
) terminals;
Printf.bprintf b "\n";
Buffer.contents b
let print_sentence sentence : unit =
print_string (print_sentence sentence)
let print_located_sentence (_, sentence) : unit =
(* [stream] turns a finite list of terminals into a stream of terminals. *) (* [stream] turns a finite list of terminals into a stream of terminals. *)
...@@ -248,60 +269,43 @@ let () = ...@@ -248,60 +269,43 @@ let () =
(* If [--compile-errors <filename>] is set, compile the error message (* If [--compile-errors <filename>] is set, compile the error message
descriptions found in file [filename] down to OCaml code, then stop. *) descriptions found in file [filename] down to OCaml code, then stop. *)
(* TEMPORARY old
let read filename =
let lexbuf = Lexing.from_string (IO.read_whole_file filename) in
lexbuf.Lexing.lex_curr_p <-
Lexing.pos_fname = filename;
Lexing.pos_lnum = 1;
Lexing.pos_bol = 0;
Lexing.pos_cnum = 0
try
SentenceParser.file SentenceLexer.lex lexbuf
with Parsing.Parse_error ->
Error.error (Positions.lexbuf lexbuf) "Ill-formed error message description file."
(* TEMPORARY could improve this message... *)
let () =
Settings.compile_errors |> Option.iter (fun filename ->
(* Read the file. *)
let entries = read filename in
(* Convert every sentence to a state number. This can signal errors.
We report all of them. *)
let _entries = List.map convert_entry entries in
if Error.errors() then exit 1;
exit 0
let () = let () =
Settings.compile_errors |> Option.iter (fun filename -> Settings.compile_errors |> Option.iter (fun filename ->
(* Read the file. (Don't bother closing it.) *)
let c = open_in filename in (* Read and segment the file. Each segment is a pair of a string and a
let lexbuf = Lexing.from_channel c in lexbuf. *)
lexbuf.Lexing.lex_curr_p <- let segments = Segment.segment filename in
{ (* Process the segments, two by two. We expect one segment to contain
Lexing.pos_fname = filename; a non-empty series of sentences, and the next segment to contain
Lexing.pos_lnum = 1; free-form text. *)
Lexing.pos_bol = 0; let rec loop accu segments =
Lexing.pos_cnum = 0 match segments with
let rec loop accu =
(* Try to read a non-empty series of non-empty sentences. *)
SentenceLexer.skip lexbuf;
match SentenceParser.entry1 SentenceLexer.lex lexbuf with
(* We have read [EOF]. Stop. *)
List.rev accu List.rev accu
| sentences -> | (_, lexbuf) :: [] ->
(* We have read at least one sentence. Now, read a block of text. *) (* Oops, we are desynchronized. *)
SentenceLexer.skip lexbuf; Error.signal
let text = SentenceLexer.block (Buffer.create 512) lexbuf in (Positions.one (Lexing.lexeme_end_p lexbuf))
(* Continue. *) "Syntax error: missing a final message. I may be desynchronized.";
loop ((sentences, text) :: accu) List.rev accu
| (_, lexbuf) :: (text, _) :: segments ->
(* Read a non-empty series of located sentences. *)
match SentenceParser.entry SentenceLexer.lex lexbuf with
| exception Parsing.Parse_error ->
(* Report an error. *)
Error.signal
(Positions.one (Lexing.lexeme_start_p lexbuf))
"Syntax error: ill-formed sentence.";
(* Continue anyway. *)
loop accu segments
| sentences ->
loop ((sentences, text) :: accu) segments
in in
let entries = loop [] in let entries = loop [] segments in
(* Although we try to report several errors, [SentenceLexer.lex] may
abort the whole process after just one error. This could be improved. *)
(* Convert every sentence to a state number. This can signal errors. (* Convert every sentence to a state number. This can signal errors.
We report all of them. *) We report all of them. *)
let _entries = List.map convert_entry entries in let _entries = List.map convert_entry entries in
...@@ -309,3 +313,4 @@ let () = ...@@ -309,3 +313,4 @@ let () =
exit 0 exit 0
module S = Segment
