Commit c5cbb050 authored by POTTIER Francois's avatar POTTIER Francois
The beginning of a more serious test suite.
parent 6fbe4f5f
...@@ -2,9 +2,120 @@ open Printf ...@@ -2,9 +2,120 @@ open Printf
open AlphaLib open AlphaLib
open Term open Term
open TermGenerator open TermGenerator
module T = Toolbox.Make(Term)
module T =
Toolbox.Make(Term)
open T open T
(* [interval i j] constructs a list representation of the semi-open interval
[i..j). *)
let rec interval i j : int list =
if i < j then
i :: interval (i + 1) j
else
(* [init i j f] constructs a list of the values [f i] up to [f (j - 1)]. *)
let init i j (f : int -> 'a) : 'a list =
List.map f (interval i j)
(* A non-hygienic printer of arbitrary terms. This printer shows the internal
identity of atoms, using [Atom.show]. *)
let nhprint oc t =
Print.term oc (show_term t)
(* A hygienic printer of closed terms. This printer uses [export]. *)
let hprint oc t =
Print.term oc (export_term KitExport.empty t)
(* Test parameters. *)
let number = 1000
let size = 1000
let atoms = 100
(* A collection of closed raw terms. *)
let closed_raw_terms : raw_term list =
printf "Generating random closed raw terms...\n%!";
init 0 number (fun _i ->
generate_raw size
(* Import them, so as to obtain a collection of closed nominal terms. *)
let closed_nominal_terms : nominal_term list =
printf "Importing these raw terms...\n%!";
List.map (import_term KitImport.empty) closed_raw_terms
let on_closed_nominal_terms f =
List.iter f closed_nominal_terms
(* The closed terms should be closed and well-formed. *)
let () =
printf "Checking closedness and well-formedness...\n%!";
on_closed_nominal_terms (fun t ->
assert (closed_term t);
assert (Atom.Set.is_empty (fa_term t));
assert (wf_term t)
(* A collection of random (non-closed, non-well-formed) nominal terms. *)
let arbitrary_nominal_terms : nominal_term list =
printf "Generating random nominal terms...\n%!";
generate_nominal atoms size
let on_arbitrary_nominal_terms f =
List.iter f arbitrary_nominal_terms
(* Copy them, so as to obtain well-formed (although non-closed) nominal terms. *)
let wf_nominal_terms : nominal_term list =
printf "Copying these terms...\n%!";
List.map copy_term arbitrary_nominal_terms
let on_wf_nominal_terms f =
List.iter f wf_nominal_terms
(* These terms should be well-formed. *)
let () =
printf "Checking well-formedness...\n%!";
on_wf_nominal_terms (fun t ->
assert (wf_term t)
(* The size computation should succeed. *)
let () =
printf "Computing sizes...\n%!";
ignore (size_term t : int)
(* [fa] and [occurs] should be consistent with each other. *)
let () =
printf "Comparing fa and occurs...\n%!";
on_arbitrary_nominal_terms (fun t ->
let atoms = fa_term t in
Atom.Set.iter (fun a ->
if not (occurs_term a t) then begin
printf "Atom %a does not occur in term %a" Atom.print a nhprint t
end;
assert (occurs_term a t); (* slow *)
) atoms
(* Sample terms. *) (* Sample terms. *)
let x = let x =
...@@ -48,18 +159,6 @@ let closed_samples = [ ...@@ -48,18 +159,6 @@ let closed_samples = [
let evaluate f = let evaluate f =
List.iter f samples List.iter f samples
(* A non-hygienic term printer. This printer shows the real (internal) identity
let nhprint oc t =
(* A hygienic term printer. This printer uses [export]. *)
let hprint oc t =
(* works for closed terms only, as of now *)
let () = let () =
printf "Testing size...\n"; printf "Testing size...\n";
...@@ -142,6 +241,7 @@ let () = ...@@ -142,6 +241,7 @@ let () =
evaluate print_wf; evaluate print_wf;
print_wf (TApp (id, id)) print_wf (TApp (id, id))
let () = let () =
for _i = 0 to 9 do for _i = 0 to 9 do
let t = import_term KitImport.empty (generate_raw 15) in let t = import_term KitImport.empty (generate_raw 15) in
...@@ -155,3 +255,4 @@ let () = ...@@ -155,3 +255,4 @@ let () =
let t = generate_nominal (* atoms: *) 5 (* size: *) 15 in let t = generate_nominal (* atoms: *) 5 (* size: *) 15 in
printf "generate_nominal() = %a\n%!" nhprint t printf "generate_nominal() = %a\n%!" nhprint t
done done
