Commit af5a3da3 authored by POTTIER Francois's avatar POTTIER Francois
Use cppo macros in the construction of Toolbox.
parent 87136d34
(* [copy] returns a copy of its argument where every bound name has been
replaced with a fresh copy, and every free name is unchanged. *)
#define __COPY \
class ['self] copy = object (_ : 'self) \
inherit [_] map \
inherit [_] KitCopy.map \
#define COPY(term) \
let CONCAT(copy_, term) t = \
new copy # CONCAT(visit_, term) KitCopy.empty t
(* [show] converts its argument to a raw term, in a NONHYGIENIC manner, using
[Atom.show] both at free name occurrences and bound name occurrences. It
is a debugging tool. *)
#define __SHOW \
class ['self] show = object (_ : 'self) \
inherit [_] map \
inherit [_] KitShow.map \
#define SHOW(term) \
let CONCAT(show_, term) t = \
new show # CONCAT(visit_, term) () t
(* [import] converts a raw term to a nominal term that satisfies the Global
Uniqueness Hypothesis, that is, a nominal term where every binding name
occurrence is represented by a unique atom. [import] expects every free
name occurrence to be in the domain of [env]. If that is not the case,
the exception [Unbound] is raised. *)
(* TEMPORARY use string * loc so as to be able to give a location *)
#define __IMPORT \
class ['self] import = object (_ : 'self) \
inherit [_] map \
inherit [_] KitImport.map \
#define IMPORT(term) \
let CONCAT(import_, term) env t = \
new import # CONCAT(visit_, term) env t
(* [export] converts a nominal term to a raw term, in a hygienic manner. This
is the proper way of displaying a term. [export] expects every free name
occurrence to be in the domain of [env]. *)
#define __EXPORT \
class ['self] export = object (_ : 'self) \
inherit [_] map \
inherit [_] KitExport.map \
#define EXPORT(term) \
let CONCAT(export_, term) env t = \
new export # CONCAT(visit_, term) env t
(* [size] computes the size of its argument. *)
(* Beware: this counts the nodes whose type is [term], but does not count the
nodes of other types. *)
#define __SIZE \
class ['self] size = object (_ : 'self) \
inherit [_] reduce as super \
inherit [_] KitTrivial.reduce \
inherit [_] VisitorsRuntime.addition_monoid \
method! CONCAT(visit_, term) env t = \
1 + super # CONCAT(visit_, term) env t \
#define SIZE(term) \
let CONCAT(size_, term) t = \
new size # CONCAT(visit_, term) () t
...@@ -8,12 +8,19 @@ PACKAGE := \ ...@@ -8,12 +8,19 @@ PACKAGE := \
TARGET := \ TARGET := \
$(patsubst %,$(PACKAGE).%,a cma cmi cmo cmx cmxa o) \ $(patsubst %,$(PACKAGE).%,a cma cmi cmo cmx cmxa o) \
PWD := \
$(shell pwd)
OCAMLBUILD := \ OCAMLBUILD := \
ocamlbuild \ ocamlbuild \
-j 0 \
-use-ocamlfind \ -use-ocamlfind \
-classic-display \ -classic-display \
-cflags "-g" -lflags "-g" -cflags "-g" -lflags "-g" \
-plugin-tag 'package(cppo_ocamlbuild)' \
-tag "cppo_I($(PWD))" \
# TEMPORARY cppo_I should not be required
# TEMPORARY a dependency computation on .cppo.ml files should be carried out
#include "AlphaLibMacros.cppo.ml"
(* This functor is applied to a type of terms, equipped with visitor classes. (* This functor is applied to a type of terms, equipped with visitor classes.
...@@ -89,85 +91,20 @@ type debruijn_term = ...@@ -89,85 +91,20 @@ type debruijn_term =
(* [size] computes the size of its argument. *) __COPY
COPY(term)
(* Beware: this counts the nodes whose type is [term] nodes, but does not count
the nodes of other types. *)
method! visit_term env t =
1 + super#visit_term env t
let size : 'fn 'bn . ('fn, 'bn) term -> int =
fun t -> new size # visit_term () t
inherit [_] map
let show : nominal_term -> raw_term =
new show # visit_term ()
inherit [_] map
let copy : nominal_term -> nominal_term =
new copy # visit_term KitCopy.empty
(* TEMPORARY maybe [module Import = KitImport] so that the user does not
have to know about the kits at all. *)
exception Unbound = KitImport.Unbound __SHOW
SHOW(term)
class ['self] import = object (_ : 'self) __IMPORT
inherit [_] map IMPORT(term)
let import : KitImport.env -> raw_term -> nominal_term =
new import # visit_term
class ['self] export = object (_ : 'self) __EXPORT
inherit [_] map EXPORT(term)
let export : KitExport.env -> nominal_term -> raw_term = __SIZE
new export # visit_term SIZE(term)
...@@ -241,7 +178,7 @@ class subst = object ...@@ -241,7 +178,7 @@ class subst = object
| u -> | u ->
(* Do not forget to copy the term that is being grafted, so as (* Do not forget to copy the term that is being grafted, so as
to maintain the GUH. *) to maintain the GUH. *)
copy u copy_term u
| exception Not_found -> | exception Not_found ->
this this
end end
let () =
Ocamlbuild_plugin.dispatch (fun phase ->
Ocamlbuild_cppo.dispatcher phase
