GitLab
Support
Community forum
Keyboard shortcuts
A
alphaLib
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
POTTIER Francois
alphaLib
a1185be3
a1185be3
POTTIER Francois
Removed the [env] parameter of [InsideRecVisit].
63ecb7a2
15 additions
25 deletions
+15
-25
src/Unbound.ml
src/Unbound.ml
+15
-25
src/Unbound.ml
a1185be3
type
env
mode
OutsideRec
InsideRecDiscovery
(* updating [current] and doing nothing else; embedded subterms not visited *)
InsideRecVisit
of
env
(* [inner] component now known
; embedded subterms visited *)
OutsideRec
(* updating [current] and visiting [outer] subterms *)
InsideRecDiscovery
InsideRecVisit
(* [current] not updated; [inner] is [current]
Repeated
type
env
penv
@@ -29,10 +29,8 @@ type ('p, 't) bind =
p
t
outer
rebind
abstraction
(* = 'p * 't *)
(* [Abstraction] allowed only in an expression *)
(* [Rebind], [Rec] forbidden under [Rec] *)
(* [Outer], [Binder] allowed both outside and inside [Rec] *)
(* [Inner] allowed only under [Rec]. *)
(* [Repeated] allowed everywhere *)
(* [Rebind], [Rec] forbidden under [Rec] and [Repeated] *)
(* [Outer], [Inner], [Binder], [Repeated] allowed everywhere *)
type
t
inner
t
@@ -58,7 +56,7 @@ class virtual ['self] libmap = object (self : 'self)
fun
visit_t
penv
t1
match
penv
mode
OutsideRec
InsideRecVisit
_
InsideRecVisit
Repeated
visit_t
penv
outer
t1
InsideRecDiscovery
@@ -77,15 +75,11 @@ class virtual ['self] libmap = object (self : 'self)
let
x2
env
self
extend
x1
env
in
current
env
x2
Repeated
let
current
penv
current
in
let
env
current
in
self
lookup
x1
env
InsideRecVisit
env
assert
env
penv
current
(* TEMPORARY if always true, then we do not need to carry [env] *)
Repeated
InsideRecVisit
(* The environment should not be extended when in visit mode.
It has been extended already during the discovery phase. *)
self
lookup
env
x1
self
lookup
x1
penv
current
method
private
visit_rebind
env
p1
p2
q1
q2
env
penv
p1
p2
@@ -101,7 +95,7 @@ class virtual ['self] libmap = object (self : 'self)
let
q2
visit_q
penv
q1
in
p2
q2
InsideRecDiscovery
InsideRecVisit
_
InsideRecVisit
Repeated
(* [rebind] forbidden under [rec] and [repeated] *)
assert
false
@@ -123,15 +117,11 @@ class virtual ['self] libmap = object (self : 'self)
env
penv
t1
inner
t2
inner
fun
visit_t
penv
t1
match
penv
mode
OutsideRec
(* [inner] allowed only under [rec] *)
assert
false
InsideRecDiscovery
(* An [inner] subterm is NOT visited in discovery mode. *)
Obj
magic
InsideRecVisit
env
assert
env
penv
current
visit_t
env
t1
OutsideRec
InsideRecVisit
Repeated
visit_t
penv
current
t1
@@ -146,12 +136,12 @@ class virtual ['self] libmap = object (self : 'self)
let
penv
penv
mode
InsideRecDiscovery
in
let
_
visit_p
penv
p1
in
(* [!current] becomes [inner] *)
let
penv
penv
mode
InsideRecVisit
penv
current
in
let
penv
penv
mode
InsideRecVisit
in
visit_p
penv
p1
InsideRecDiscovery
InsideRecVisit
_
InsideRecVisit
Repeated
(* [rec]
not allowed
under [rec] or [repeated] *)
(* [rec]
forbidden
assert
false
method
private
visit_repeated
env
p1
p2
