Commit 9dd3286a authored by POTTIER Francois's avatar POTTIER Francois
Allow [make processed] to work even if the generated code is ill-typed.
parent 63da7435
...@@ -33,7 +33,8 @@ test: all ...@@ -33,7 +33,8 @@ test: all
mli: mli:
@ $(OCAMLBUILD) $(MLI) @ $(OCAMLBUILD) $(MLI)
processed: all processed:
make all || true
make -C _build -f $(shell ocamlfind query visitors)/Makefile.preprocess F.processed.ml make -C _build -f $(shell ocamlfind query visitors)/Makefile.preprocess F.processed.ml
clean: clean:
