Commit 63ecb7a2 authored by POTTIER Francois's avatar POTTIER Francois
Added [repeated].
parent 8e837f81
...@@ -2,6 +2,7 @@ type 'env mode = ...@@ -2,6 +2,7 @@ type 'env mode =
| OutsideRec | OutsideRec
| InsideRecDiscovery (* updating [current] and doing nothing else; embedded subterms not visited *) | InsideRecDiscovery (* updating [current] and doing nothing else; embedded subterms not visited *)
| InsideRecVisit of 'env (* [inner] component now known; embedded subterms visited *) | InsideRecVisit of 'env (* [inner] component now known; embedded subterms visited *)
| Repeated
type 'env penv = { type 'env penv = {
current: 'env ref; (* threaded left to right *) current: 'env ref; (* threaded left to right *)
...@@ -21,6 +22,9 @@ type 't outer = ...@@ -21,6 +22,9 @@ type 't outer =
type ('p, 't) rebind = type ('p, 't) rebind =
'p * 't 'p * 't
type 'p repeated =
'p
type ('p, 't) bind = type ('p, 't) bind =
(('p, 't outer) rebind) abstraction (* = 'p * 't *) (('p, 't outer) rebind) abstraction (* = 'p * 't *)
...@@ -28,6 +32,7 @@ type ('p, 't) bind = ...@@ -28,6 +32,7 @@ type ('p, 't) bind =
(* [Rebind], [Rec] forbidden under [Rec] *) (* [Rebind], [Rec] forbidden under [Rec] *)
(* [Outer], [Binder] allowed both outside and inside [Rec] *) (* [Outer], [Binder] allowed both outside and inside [Rec] *)
(* [Inner] allowed only under [Rec]. *) (* [Inner] allowed only under [Rec]. *)
(* [Repeated] allowed everywhere *)
type 't inner = type 't inner =
't 't
...@@ -53,7 +58,8 @@ class virtual ['self] libmap = object (self : 'self) ...@@ -53,7 +58,8 @@ class virtual ['self] libmap = object (self : 'self)
= fun visit_t penv t1 -> = fun visit_t penv t1 ->
match penv.mode with match penv.mode with
| InsideRecVisit _ -> | InsideRecVisit _
| Repeated ->
visit_t penv.outer t1 visit_t penv.outer t1
| InsideRecDiscovery -> | InsideRecDiscovery ->
(* An [outer] subterm is NOT visited in discovery mode. *) (* An [outer] subterm is NOT visited in discovery mode. *)
...@@ -71,6 +77,10 @@ class virtual ['self] libmap = object (self : 'self) ...@@ -71,6 +77,10 @@ class virtual ['self] libmap = object (self : 'self)
let x2, env = self#extend x1 env in let x2, env = self#extend x1 env in
current := env; current := env;
x2 x2
| Repeated ->
let current = penv.current in
let env = !current in
self#lookup x1 env
| InsideRecVisit env -> | InsideRecVisit env ->
assert (env == !(penv.current)); (* TEMPORARY if always true, then we do not need to carry [env] *) assert (env == !(penv.current)); (* TEMPORARY if always true, then we do not need to carry [env] *)
(* The environment should not be extended when in visit mode. (* The environment should not be extended when in visit mode.
...@@ -91,8 +101,9 @@ class virtual ['self] libmap = object (self : 'self) ...@@ -91,8 +101,9 @@ class virtual ['self] libmap = object (self : 'self)
let q2 = visit_q penv q1 in let q2 = visit_q penv q1 in
p2, q2 p2, q2
| InsideRecDiscovery | InsideRecDiscovery
(* [rebind] forbidden under [rec] *) | Repeated ->
(* [rebind] forbidden under [rec] and [repeated] *)
assert false assert false
(* could in principle be generated, if [visitors] supported dealing with (* could in principle be generated, if [visitors] supported dealing with
...@@ -121,6 +132,8 @@ class virtual ['self] libmap = object (self : 'self) ...@@ -121,6 +132,8 @@ class virtual ['self] libmap = object (self : 'self)
assert (env == !(penv.current)); assert (env == !(penv.current));
visit_t env t1 visit_t env t1
| Repeated ->
visit_t !(penv.current) t1
method private visit_recursive: 'env 'p1 'p2 . method private visit_recursive: 'env 'p1 'p2 .
('env penv -> 'p1 -> 'p2) -> ('env penv -> 'p1 -> 'p2) ->
...@@ -136,10 +149,18 @@ class virtual ['self] libmap = object (self : 'self) ...@@ -136,10 +149,18 @@ class virtual ['self] libmap = object (self : 'self)
let penv = { penv with mode = InsideRecVisit !(penv.current) } in let penv = { penv with mode = InsideRecVisit !(penv.current) } in
visit_p penv p1 visit_p penv p1
(* [rec] not allowed under [rec] *) | Repeated ->
(* [rec] not allowed under [rec] or [repeated] *)
method private visit_repeated: 'env 'p1 'p2 .
'env penv -> 'p1 repeated -> 'p2 repeated
= fun visit_p penv p1 ->
let penv = { penv with mode = Repeated } in
visit_p penv p1
end end
type ('bn, 'fn) tele = type ('bn, 'fn) tele =
