<div align="justify">
Table of Contents
[[_TOC_]]
# Introduction
*Clang-Tidy* is a tool developed and maintained by the *Clang/LLVM* community. The official documentation can be found at [http://clang.llvm.org/extra/clang-tidy/](http://clang.llvm.org/extra/clang-tidy/).
# Install
When running Linux, *clang-tidy* is usually easy to get via your distribution’s package manager. On Ubuntu Linux:
~~~sh
sudo apt-get install clang-tidy
Additionally you can download directly in the [project page](http://releases.llvm.org/download.html).
# How to use it
A typical invocation of the command-line tool looks like this:
~~~sh
clang-tidy test.cpp -- -Imy_project/include -DMY_DEFINES ...
Executing it like this, the tool will print a bunch of warnings and notes (if applicable), in exactly the same way Clang/GCC provide diagnostics, too.
The avalaible checkers avaible can be found with the following command:
~~~sh
clang-tidy --list-checks -checks='*' | grep "modernize"
modernize-avoid-bind
modernize-deprecated-headers
modernize-loop-convert
modernize-make-shared
modernize-make-unique
modernize-pass-by-value
modernize-raw-string-literal
modernize-redundant-void-arg
modernize-replace-auto-ptr
modernize-shrink-to-fit
modernize-use-auto
modernize-use-bool-literals
modernize-use-default
modernize-use-emplace
modernize-use-nullptr
modernize-use-override
modernize-use-using
To correct the code we can use the command `-fix` (not all the avalaible checkers have the `-fix` function). For example to add the missing overrides in the following code:
~~~c
struct Base {
virtual void reimplementMe(int a) {}
struct Derived : public Base {
We use the next command:
~~~sh
clang-tidy -checks='modernize-use-override' -fix test.cpp -- -std=c++11
# Using to correct a whole project
The previous example will work just with a very simple example contained in one file. To correct the whole project we will need to create a `json` file containing all the file in the project. For that we add the following line to ou configure.sh:
~~~sh
-DCMAKE_EXPORT_COMPILE_COMMANDS=ON \
This will create a file named `compile_commands.json` that we will use with the following python script from the [LLVM project](https://gitlab.inria.fr/felisce/extra/documentation/-/raw/master/Resources/Clang-tidy%20modernize/run-clang-tidy.py?inline=false)).
Once we have the script and the json file we can check and fix the whole project by the following way:
~~~sh
run-clang-tidy.py -header-filter='.*' -checks='-*,modernize-use-override' -fix
You can run simmultaneously all the possible modernize commands using the following [shell script]( https://gitlab.inria.fr/felisce/extra/documentation/-/raw/master/Resources/Clang-tidy%20modernize/modernize.sh?inline=false).
~~~sh
sh modernize.sh
# References
- [LLVM](http://releases.llvm.org/download.html)
- [Clang-Tidy](http://clang.llvm.org/extra/clang-tidy/)
- [Clang-Tidy, part 1: Modernize your source code using C++11/C++14](https://www.kdab.com/clang-tidy-part-1-modernize-source-code-using-c11c14/)
</div> |
\ No newline at end of file |
