Commit d826e9ea authored by Vicente Mataix Ferrándiz's avatar Vicente Mataix Ferrándiz 🐍
[Types] Adding mention to std::ptrdiff_t, signed counter part of std::size_t
parent 7d4efeac
...@@ -282,7 +282,7 @@ ...@@ -282,7 +282,7 @@
"\n", "\n",
"The _0 notation column_ is the way to notice explicitly the type in an expression; of course any value might be used instead of 0. A `u` might be used to signal the unsigned status for integer types; for instance `3ul` means 3 as an _unsigned long_. `auto` notation below will illustrate a case in which such a notation is useful.\n", "The _0 notation column_ is the way to notice explicitly the type in an expression; of course any value might be used instead of 0. A `u` might be used to signal the unsigned status for integer types; for instance `3ul` means 3 as an _unsigned long_. `auto` notation below will illustrate a case in which such a notation is useful.\n",
"\n", "\n",
"The STL features rather heavily a type named `std::size_t`, which by design is able to store the maximum size of a theoretically possible object of any type (including array). On most (all?) systems `std::size_t` is an alias to an `unsigned long`. More may be found about this type on [CppReference](https://en.cppreference.com/w/cpp/types/size_t).\n", "The STL features rather heavily a type named `std::size_t`, which by design is able to store the maximum size of a theoretically possible object of any type (including array). On most (all?) systems `std::size_t` is an alias to an `unsigned long`. More may be found about this type on [CppReference](https://en.cppreference.com/w/cpp/types/size_t). The equivalent counter part for signed integers is the [`std::ptrdiff_t`](https://en.cppreference.com/w/cpp/types/ptrdiff_t), which is the signed integer type of the result of subtracting two pointers. \n",
"\n", "\n",
"\n", "\n",
"#### Numeric limits\n", "#### Numeric limits\n",
