Commit 62deca00 authored by BOLDO Sylvie's avatar BOLDO Sylvie
Modified ln_beta_lt_pos + changes in Fprop_plus_error + minor stuff
# Conflicts:
#	src/Prop/Plus_error.v
parent 57408d82
Require Import Reals. Require Import Reals.
Require Import Fcore. Require Import Flocq.Core.Fcore.
Require Import Fprop_relative. Require Import Flocq.Prop.Fprop_relative.
Require Import Fprop_Sterbenz. Require Import Flocq.Prop.Fprop_Sterbenz.
Require Import Fcalc_ops. Require Import Flocq.Calc.Fcalc_ops.
Require Import Interval.Interval_tactic. Require Import Interval.Interval_tactic.
Section Delta_FLX. Section Delta_FLX.
...@@ -1838,10 +1838,13 @@ Qed. ...@@ -1838,10 +1838,13 @@ Qed.
Lemma ln_beta_lt_pos : Lemma ln_beta_lt_pos :
forall x y, forall x y,
(0 < x)%R -> (0 < y)%R -> (0 < y)%R ->
(ln_beta x < ln_beta y)%Z -> (x < y)%R. (ln_beta x < ln_beta y)%Z -> (x < y)%R.
Proof. Proof.
intros x y Px Py. intros x y Py.
case (Rle_or_lt x 0); intros Px.
intros H.
now apply Rle_lt_trans with 0%R.
destruct (ln_beta x) as (ex, Hex). destruct (ln_beta x) as (ex, Hex).
destruct (ln_beta y) as (ey, Hey). destruct (ln_beta y) as (ey, Hey).
simpl. simpl.
...@@ -2096,7 +2099,7 @@ assert (Hbeta : (2 <= r)%Z). ...@@ -2096,7 +2099,7 @@ assert (Hbeta : (2 <= r)%Z).
{ destruct r as (beta_val,beta_prop). { destruct r as (beta_val,beta_prop).
now apply Zle_bool_imp_le. } now apply Zle_bool_imp_le. }
intros x y Px Py Hln. intros x y Px Py Hln.
assert (Oxy : (y < x)%R); [now apply ln_beta_lt_pos; [| |omega]|]. assert (Oxy : (y < x)%R); [apply ln_beta_lt_pos;[assumption|omega]|].
destruct (ln_beta x) as (ex,Hex). destruct (ln_beta x) as (ex,Hex).
destruct (ln_beta y) as (ey,Hey). destruct (ln_beta y) as (ey,Hey).
simpl in Hln |- *. simpl in Hln |- *.
...@@ -783,7 +783,7 @@ Lemma ln_beta_minus_disj : ...@@ -783,7 +783,7 @@ Lemma ln_beta_minus_disj :
\/ (ln_beta (x - y) = (ln_beta x - 1)%Z :> Z)). \/ (ln_beta (x - y) = (ln_beta x - 1)%Z :> Z)).
Proof. Proof.
assert (Hxy : y < x); [now apply (ln_beta_lt_pos beta); [| |omega]|]. assert (Hxy : y < x); [now apply (ln_beta_lt_pos beta); [ |omega]|].
generalize (ln_beta_minus beta x y Py Hxy); intro Hln2. generalize (ln_beta_minus beta x y Py Hxy); intro Hln2.
generalize (ln_beta_minus_lb beta x y Px Py Hln); intro Hln3. generalize (ln_beta_minus_lb beta x y Px Py Hln); intro Hln3.
omega. omega.
...@@ -262,7 +262,7 @@ Qed. ...@@ -262,7 +262,7 @@ Qed.
End Fprop_plus_FLT. End Fprop_plus_FLT.
Section Fprop_plus_multi. Section Fprop_plus_multi.
Variable beta : radix. Variable beta : radix.
...@@ -278,7 +278,7 @@ Context { valid_rnd : Valid_rnd rnd }. ...@@ -278,7 +278,7 @@ Context { valid_rnd : Valid_rnd rnd }.
Notation format := (generic_format beta fexp). Notation format := (generic_format beta fexp).
Notation cexp := (cexp beta fexp). Notation cexp := (cexp beta fexp).
Lemma toto: forall x e, format x -> (e <= cexp x)%Z -> Lemma ex_shift: forall x e, format x -> (e <= cexp x)%Z ->
exists m, (x = Z2R m*bpow e)%R. exists m, (x = Z2R m*bpow e)%R.
Proof with auto with typeclass_instances. Proof with auto with typeclass_instances.
intros x e Fx He. intros x e Fx He.
...@@ -291,24 +291,9 @@ rewrite Z2R_Zpower. ...@@ -291,24 +291,9 @@ rewrite Z2R_Zpower.
rewrite <- bpow_plus; f_equal; ring. rewrite <- bpow_plus; f_equal; ring.
Qed. Qed.
(*Lemma Fprop_plus_mutiple_aux: Lemma ln_beta_minus1:
forall x y, format x -> format y -> forall z, (z<>0)%R -> (ln_beta beta z -1 = ln_beta beta (z / Z2R beta))%Z.
(0 < x)%R -> (y < 0)%R ->
exists m',
(round beta fexp rnd (x+y) = Z2R m' * ulp beta fexp (x/Z2R beta))%R.
ln_beta_minus_lb
Lemma Fprop_plus_mutiple:
forall x y, format x -> format y -> (x <> 0)%R ->
exists m,
(round beta fexp rnd (x+y) = Z2R m * ulp beta fexp (x/Z2R beta))%R.
intros x y Fx Fy Zx.
assert (H: forall z, (z<>0)%R -> (ln_beta beta z -1 = ln_beta beta (z / Z2R beta))%Z).
intros z Hz; apply sym_eq, ln_beta_unique. intros z Hz; apply sym_eq, ln_beta_unique.
destruct (ln_beta beta z) as (e,He); simpl. destruct (ln_beta beta z) as (e,He); simpl.
replace (z / Z2R beta)%R with (z*bpow (-1))%R. replace (z / Z2R beta)%R with (z*bpow (-1))%R.
...@@ -328,13 +313,20 @@ apply bpow_le; omega. ...@@ -328,13 +313,20 @@ apply bpow_le; omega.
apply Rle_ge, bpow_ge_0. apply Rle_ge, bpow_ge_0.
simpl; unfold Rdiv; f_equal; f_equal; f_equal. simpl; unfold Rdiv; f_equal; f_equal; f_equal.
unfold Z.pow_pos; simpl; ring. unfold Z.pow_pos; simpl; ring.
(* *) Qed.
Lemma rnd_plus_mutiple:
exists m,
case (Zle_or_lt (ln_beta beta (x/Z2R beta)) (ln_beta beta y)); intros H1. case (Zle_or_lt (ln_beta beta (x/Z2R beta)) (ln_beta beta y)); intros H1.
pose (e:=cexp (x / Z2R beta)). pose (e:=cexp (x / Z2R beta)).
destruct (toto x e) as (nx, Hnx); try exact Fx. destruct (ex_shift x e) as (nx, Hnx); try exact Fx.
apply monotone_exp. apply monotone_exp.
rewrite <- (H x Zx); omega. rewrite <- (ln_beta_minus1 x Zx); omega.
destruct (toto y e) as (ny, Hny); try assumption. destruct (ex_shift y e) as (ny, Hny); try assumption.
apply monotone_exp... apply monotone_exp...
destruct (round_repr_same_exp beta fexp rnd (nx+ny) e) as (n,Hn). destruct (round_repr_same_exp beta fexp rnd (nx+ny) e) as (n,Hn).
exists n. exists n.
...@@ -348,19 +340,57 @@ apply Rinv_neq_0_compat. ...@@ -348,19 +340,57 @@ apply Rinv_neq_0_compat.
apply Rgt_not_eq. apply Rgt_not_eq.
apply radix_pos. apply radix_pos.
destruct (toto (round beta fexp rnd (x + y)) (cexp (x/Z2R beta))) as (n,Hn). destruct (ex_shift (round beta fexp rnd (x + y)) (cexp (x/Z2R beta))) as (n,Hn).
apply generic_format_round... apply generic_format_round...
apply Zle_trans with (cexp (x+y)). apply Zle_trans with (cexp (x+y)).
rewrite <- H; try assumption. rewrite <- ln_beta_minus1; try assumption.
rewrite <- (ln_beta_abs beta (x+y)). rewrite <- (ln_beta_abs beta (x+y)).
assert (U:(Rabs (x+y) = Rabs x + Rabs y)%R \/ (y <> 0 /\ Rabs (x+y)=Rabs x - Rabs y)%R). assert (U:(Rabs (x+y) = Rabs x + Rabs y)%R \/ (y <> 0 /\ Rabs (x+y)=Rabs x - Rabs y)%R).
assert (V: forall x y, (Rabs y <= Rabs x)%R ->
clear; intros x y.
admit. case (Rle_or_lt 0 y); intros Hy.
case Hy; intros Hy'.
case (Rle_or_lt 0 x); intros Hx.
intros _; rewrite (Rabs_right y); [idtac|now apply Rle_ge].
rewrite (Rabs_right x); [idtac|now apply Rle_ge].
left; apply Rabs_right.
apply Rle_ge; apply Rplus_le_le_0_compat; assumption.
rewrite (Rabs_left x); [idtac|assumption].
intros H; right; split.
now apply Rgt_not_eq.
rewrite Rabs_left1.
ring.
apply Rplus_le_reg_l with (-x)%R; ring_simplify; assumption.
intros _; left.
now rewrite <- Hy', Rabs_R0, 2!Rplus_0_r.
rewrite (Rabs_left y); [idtac|assumption].
apply sym_not_eq; now apply Rgt_not_eq.
rewrite Rabs_right.
ring.
apply Rle_ge; apply Rplus_le_reg_l with (-y)%R; ring_simplify; assumption.
intros _; left.
rewrite Rabs_left1.
ring.
rewrite <- (Ropp_involutive (x+y)), <- Ropp_0.
apply Ropp_le_contravar; rewrite Ropp_plus_distr.
apply Rplus_le_le_0_compat.
rewrite <- Ropp_0; apply Ropp_le_contravar; now left.
apply V; left.
apply ln_beta_lt_pos with beta.
now apply Rabs_pos_lt.
rewrite <- ln_beta_minus1 in H1; try assumption.
rewrite 2!ln_beta_abs; omega.
destruct U as [U|U]. destruct U as [U|U].
rewrite U; apply Zle_trans with (ln_beta beta x);[omega|idtac]. rewrite U; apply Zle_trans with (ln_beta beta x);[omega|idtac].
rewrite <- ln_beta_abs. rewrite <- ln_beta_abs.
...@@ -375,13 +405,13 @@ now apply Rabs_pos_lt. ...@@ -375,13 +405,13 @@ now apply Rabs_pos_lt.
now apply Rabs_pos_lt. now apply Rabs_pos_lt.
rewrite 2!ln_beta_abs. rewrite 2!ln_beta_abs.
assert (ln_beta beta y < ln_beta beta x -1)%Z;[idtac|omega]. assert (ln_beta beta y < ln_beta beta x -1)%Z;[idtac|omega].
now rewrite (H x Zx). now rewrite (ln_beta_minus1 x Zx).
apply canonic_exp_round_ge... apply cexp_round_ge...
intros K. intros K.
absurd (x+y=0)%R. absurd (x+y=0)%R.
intros K'. intros K'.
contradict H1; apply Zle_not_lt. contradict H1; apply Zle_not_lt.
rewrite <- (H x Zx). rewrite <- (ln_beta_minus1 x Zx).
replace y with (-x)%R. replace y with (-x)%R.
rewrite ln_beta_opp; omega. rewrite ln_beta_opp; omega.
apply Rplus_eq_reg_l with x; rewrite K'; ring. apply Rplus_eq_reg_l with x; rewrite K'; ring.
...@@ -393,20 +423,129 @@ apply Rmult_integral_contrapositive_currified; try assumption. ...@@ -393,20 +423,129 @@ apply Rmult_integral_contrapositive_currified; try assumption.
apply Rinv_neq_0_compat. apply Rinv_neq_0_compat.
Admitted. Qed.
Lemma rnd_0_or_ge: Exp_not_FTZ fexp -> forall x y, format x -> format y ->
(round beta fexp rnd (x+y) = 0)%R \/
(ulp beta fexp (x/Z2R beta) <= Rabs (round beta fexp rnd (x+y)))%R.
intros exp_not_FTZ x y Fx Fy.
case (Req_dec x 0); intros Zx.
rewrite Zx, Rplus_0_l.
rewrite round_generic...
unfold Rdiv; rewrite Rmult_0_l.
rewrite Fy at 2.
unfold F2R; simpl; rewrite Rabs_mult.
rewrite (Rabs_right (bpow _)).
2: apply Rle_ge, bpow_ge_0.
case (Z.eq_dec (Ztrunc (scaled_mantissa beta fexp y)) 0); intros Hm.
left.
rewrite Fy, Hm; unfold F2R; simpl; ring.
right.
apply Rle_trans with (1*bpow (cexp y))%R.
rewrite Rmult_1_l.
rewrite <- ulp_neq_0.
apply ulp_ge_ulp_0...
intros K; apply Hm.
rewrite K, scaled_mantissa_0.
replace 0%R with (Z2R 0) by reflexivity.
apply Ztrunc_Z2R.
apply Rmult_le_compat_r.
apply bpow_ge_0.
rewrite <- Z2R_abs.
replace 1%R with (Z2R 1) by reflexivity.
apply Z2R_le.
assert (0 < Z.abs (Ztrunc (scaled_mantissa beta fexp y)))%Z;[|omega].
now apply Z.abs_pos.
destruct (rnd_plus_mutiple x y Fx Fy Zx) as (m,Hm).
case (Z.eq_dec m 0); intros Zm.
left.
rewrite Hm, Zm; simpl; ring.
right.
rewrite Hm, Rabs_mult.
rewrite (Rabs_right (ulp _ _ _)).
2: apply Rle_ge, ulp_ge_0.
apply Rle_trans with (1*ulp beta fexp (x/Z2R beta))%R.
right; ring.
apply ulp_ge_0.
rewrite <- Z2R_abs.
apply Z2R_le.
assert (0 < Z.abs m)%Z;[|omega].
Qed.
(* End Fprop_plus_multi.
Section Fprop_plus_multii.
Notation bpow e := (bpow beta e).
x oplus y est un multiple de ulp (x / beta) Variable rnd : R -> Z.
Variable emin prec : Z.
Context { prec_gt_0_ : Prec_gt_0 prec }.
==> Lemma rnd_0_or_ge_FLT: forall x y e,
generic_format beta (FLT_exp emin prec) x -> generic_format beta (FLT_exp emin prec) y ->
(bpow e <= Rabs x)%R ->
(round beta (FLT_exp emin prec) rnd (x+y) = 0)%R \/
(bpow (e - prec) <= Rabs (round beta (FLT_exp emin prec) rnd (x+y)))%R.
intros x y e Fx Fy He.
assert (Zx:(x <> 0)%R).
intros K; contradict He.
apply Rlt_not_le; rewrite K, Rabs_R0.
apply bpow_gt_0.
case rnd_0_or_ge with beta (FLT_exp emin prec) rnd x y...
intros H; right.
apply Rle_trans with (2:=H).
rewrite ulp_neq_0.
unfold cexp.
unfold FLT_exp; apply bpow_le.
apply Zle_trans with (2:=Z.le_max_l _ _).
destruct (ln_beta beta x) as (n,Hn); simpl.
assert (e < n)%Z; try omega.
apply lt_bpow with beta.
apply Rle_lt_trans with (1:=He).
now apply Hn.
apply Rgt_not_eq.
apply radix_pos.
Qed.
x oplus y = 0 ou >= /beta * ulp x
|x| >= bpow e -> x oplus y = 0 ou >= bpow (e-p) Lemma rnd_0_or_ge_FLX: forall x y e,
generic_format beta (FLX_exp prec) x -> generic_format beta (FLX_exp prec) y ->
(round beta (FLX_exp prec) rnd (x+y) = 0)%R \/
(bpow (e - prec) <= Rabs (round beta (FLX_exp prec) rnd (x+y)))%R.
apply bpow_gt_0.
case rnd_0_or_ge with beta (FLX_exp prec) rnd x y...
intros H; right.
rewrite ulp_neq_0.
unfold cexp.
unfold FLX_exp; apply bpow_le.
now apply Hn.
apply Rgt_not_eq.
apply radix_pos.
Qed.
*) End Fprop_plus_multii.
...@@ -963,9 +963,9 @@ Let r3 := (gamma+alpha2) -r2. ...@@ -963,9 +963,9 @@ Let r3 := (gamma+alpha2) -r2.
(** Non-underflow hypotheses *) (** Non-underflow hypotheses *)
Hypothesis Und1: a * x = 0 \/ bpow radix2 (emin + 2 * prec - 1) <= Rabs (a * x). Hypothesis Und1: a * x = 0 \/ bpow radix2 (emin + 2 * prec - 1) <= Rabs (a * x).
Hypothesis Und2: alpha1 = 0 \/ bpow radix2 (emin + prec) <= Rabs alpha1. (*Hypothesis Und2: alpha1 = 0 \/ bpow radix2 (emin + prec) <= Rabs alpha1.*)
Hypothesis Und4: beta1 = 0 \/ bpow radix2 (emin + prec+1) <= Rabs beta1. (*Hypothesis Und4: beta1 = 0 \/ bpow radix2 (emin + prec+1) <= Rabs beta1.*)
Hypothesis Und5: r1 = 0 \/ bpow radix2 (emin + prec-1) <= Rabs r1. Hypothesis Und5: r1 = 0 \/ bpow radix2 (emin + prec-1) <= Rabs r1.
...@@ -988,7 +988,33 @@ apply Rle_trans with (2:=H). ...@@ -988,7 +988,33 @@ apply Rle_trans with (2:=H).
apply bpow_le; omega. apply bpow_le; omega.
Qed. Qed.
Lemma Und4: beta1 = 0 \/ bpow radix2 (emin + prec+1) <= Rabs beta1.
unfold beta1.
replace (emin+prec+1)%Z with ((emin+2*prec+1)-prec)%Z by ring.
apply rnd_0_or_ge_FLT...
apply Und3'.
TOTO.
replace (u2) with (-(u1-(a*x))) by (unfold u2; ring).
apply generic_format_opp.
apply mult_error_FLT...
Lemma Und2: alpha1 = 0 \/ bpow radix2 (emin + prec) <= Rabs alpha1.
unfold alpha1.
replace (emin+prec)%Z with ((emin+2*prec)-prec)%Z by ring.
rewrite Rplus_comm.
