GitLab
Support
Community forum
Keyboard shortcuts
F
flocq
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Flocq
flocq
8c0fdde4
8c0fdde4
Guillaume Melquiond
Update remake.
f68e394c
31 additions
8 deletions
+31
-8
remake.cpp
remake.cpp
+31
-8
remake.cpp
8c0fdde4
@@ -74,6 +74,7 @@ Usage: <tt>remake <i>options</i> <i>targets</i></tt>
Options:
- <tt>-B</tt>, <tt>--always-make</tt>: Unconditionally make all targets.
- <tt>-d</tt>: Echo script commands.
- <tt>-f FILE</tt>: Read <tt>FILE</tt> as <b>Remakefile</b>.
- <tt>-j[N]</tt>, <tt>--jobs=[N]</tt>: Allow <tt>N</tt> jobs at once;
@@ -511,6 +512,7 @@ enum status_e
Todo
///< Target is missing or obsolete.
Recheck
///< Target has an obsolete dependency.
Running
///< Target is being rebuilt.
RunningRecheck
///< Static prerequisites are being rebuilt.
Remade
///< Target was successfully rebuilt.
Failed
///< Build failed for target.
@@ -733,6 +735,11 @@ static bool changed_prefix_dir;
static
bool
propagate_vars
false
* Whether targets are unconditionally obsolete.
static
bool
obsolete_targets
false
#ifndef WINDOWS
static
volatile
sig_atomic_t
got_SIGCHLD
@@ -776,7 +783,7 @@ struct log
log
debug
static
log
debug
struct
log_auto_close
@@ -1935,6 +1942,13 @@ static status_t const &get_status(std::string const &target)
ts
last
s
st_mtime
return
ts
if
obsolete_targets
DEBUG_close
"forcefully obsolete
\n
ts
status
Todo
ts
last
return
ts
dependency_t
const
dep
j
second
status_e
st
Uptodate
time_t
latest
@@ -2017,10 +2031,10 @@ static void update_status(std::string const &target)
static
bool
still_need_rebuild
std
string
const
target
DEBUG_open
"Rechecking obsoleteness of "
target
status_map
const_iterator
i
status
find
target
assert
i
status
if
i
second
status
Recheck
return
true
if
i
second
status
RunningRecheck
return
true
DEBUG_open
target
dependency_map
const_iterator
j
dependencies
find
target
assert
j
dependencies
dependency_t
const
dep
j
second
@@ -2301,10 +2315,14 @@ static status_e start(std::string const &target, client_list::iterator ¤t)
std
cerr
"No rule for building "
target
std
endl
return
Failed
bool
has_deps
job
rule
deps
empty
job
rule
wdeps
empty
status_e
st
Running
if
has_deps
status
target
status
Recheck
st
RunningRecheck
for
string_list
const_iterator
i
job
rule
targets
begin
i_end
job
rule
targets
i
i_end
i
status
i
status
Running
status
i
status
st
if
propagate_vars
job
vars
current
vars
for
assign_map
const_iterator
i
job
rule
assigns
begin
@@ -2324,7 +2342,7 @@ static status_e start(std::string const &target, client_list::iterator ¤t)
else
if
k
second
v
clear
v
insert
v
i
second
value
begin
i
second
value
if
job
rule
deps
empty
job
rule
wdeps
empty
if
has_deps
current
clients
insert
current
client_t
current
job_id
job_id
@@ -2333,7 +2351,7 @@ static status_e start(std::string const &target, client_list::iterator ¤t)
job
rule
wdeps
begin
job
rule
wdeps
if
propagate_vars
current
vars
job
vars
current
delayed
true
return
Recheck
return
R
unningR
echeck
return
run_script
job_id
job
@@ -2421,6 +2439,7 @@ static bool handle_clients()
switch
k
second
status
case
Running
case
RunningRecheck
break
case
Failed
i
failed
true
@@ -2444,6 +2463,7 @@ static bool handle_clients()
switch
get_status
target
status
case
Running
case
RunningRecheck
i
running
insert
target
break
case
Failed
@@ -2466,7 +2486,7 @@ static bool handle_clients()
j
running
insert
target
if
has_free_slots
return
true
break
case
Recheck
case
R
unningR
echeck
// Switch to the dependency client that was inserted.
j
running
insert
target
i_next
j
@@ -2931,12 +2951,13 @@ static void usage(int exit_status)
std
cerr
"Usage: remake [options] [target] ...
\n
"Options
\n
" -B, --always-make Unconditionally make all targets.
\n
" -d Echo script commands.
\n
" -d -d Print lots of debugging information.
\n
" -f FILE Read FILE as Remakefile.
\n
" -h, --help Print this message and exit.
\n
" -j[N], --jobs=[N] Allow N jobs at once; infinite jobs with no arg.
\n
" -k
Keep going when some targets cannot be made.
\n
" -k
, --keep-going
\n
" -r Look up targets from the dependencies on stdin.
\n
" -s, --silent, --quiet Do not echo targets.
\n
exit
exit_status
@@ -2976,6 +2997,8 @@ int main(int argc, char *argv[])
show_targets
false
else
if
arg
"-r"
indirect_targets
true
else
if
arg
"-B"
arg
"--always-make"
obsolete_targets
true
else
if
arg
"-f"
if
i
argc
usage
EXIT_FAILURE
