Commit 6c02f641 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Changed emax meaning and inferred emin from it.
parent b3c69558
This file is part of the Flocq formalization of floating-point
arithmetic in Coq: http://flocq.gforge.inria.fr/
Copyright (C) 2010 Sylvie Boldo
#<br />#
Copyright (C) 2010 Guillaume Melquiond
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 3 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
COPYING file for more details.
(** * IEEE-754 arithmetic *)
Require Import Fcore.
Require Import Fcalc_digits.
Require Import Fcalc_round.
......@@ -8,20 +28,19 @@ Require Import Fcalc_sqrt.
Section Binary.
Variable prec emin emax : Z.
Variable prec emax : Z.
Hypothesis Hprec : (0 < prec)%Z.
Hypothesis Hmin : (emin <= 0)%Z.
Hypothesis Hminmax : (emin <= emax)%Z.
Hypothesis Hmax : (2 <= emax)%Z.
Let emin := (3 - emax - prec)%Z.
Let fexp := FLT_exp emin prec.
Let fexp_correct : valid_exp fexp := FLT_exp_correct _ _ Hprec.
Definition bounded_prec m e :=
Zeq_bool (fexp (Z_of_nat (S (digits2_Pnat m)) + e)) e.
Definition bounded m e :=
andb (bounded_prec m e) (Zle_bool e emax).
andb (bounded_prec m e) (Zle_bool e (emax - prec)).
Inductive binary_float :=
| B754_zero : bool -> binary_float
......@@ -147,7 +166,7 @@ Qed.
Theorem bounded_lt_emax :
forall mx ex,
bounded mx ex = true ->
(F2R (Float radix2 (Zpos mx) ex) < bpow radix2 (emax + prec))%R.
(F2R (Float radix2 (Zpos mx) ex) < bpow radix2 emax)%R.
Proof.
intros mx ex Hx.
destruct (andb_prop _ _ Hx) as (H1,H2).
......@@ -169,14 +188,15 @@ revert H1. clear -H2.
rewrite Z_of_nat_S_digits2_Pnat.
change Fcalc_digits.radix2 with radix2.
unfold fexp, FLT_exp.
generalize (Zmax_spec (digits radix2 (Zpos mx) + ex - prec) emin).
intros.
generalize (digits radix2 (Zpos mx)).
intros ; zify ; subst.
clear -H H2. clearbody emin.
omega.
Qed.
Theorem B2R_lt_emax :
forall x,
(Rabs (B2R x) < bpow radix2 (emax + prec))%R.
(Rabs (B2R x) < bpow radix2 emax)%R.
Proof.
intros [sx|sx| |sx mx ex Hx] ; simpl ; try ( rewrite Rabs_R0 ; apply bpow_gt_0 ).
rewrite abs_F2R, abs_cond_Zopp.
......@@ -186,7 +206,7 @@ Qed.
Theorem bounded_canonic_lt_emax :
forall mx ex,
canonic radix2 fexp (Float radix2 (Zpos mx) ex) ->
(F2R (Float radix2 (Zpos mx) ex) < bpow radix2 (emax + prec))%R ->
(F2R (Float radix2 (Zpos mx) ex) < bpow radix2 emax)%R ->
bounded mx ex = true.
Proof.
intros mx ex Cx Bx.
......@@ -205,8 +225,8 @@ unfold canonic, Fexp in Cx.
rewrite Cx.
unfold canonic_exponent, fexp, FLT_exp.
destruct (ln_beta radix2 (F2R (Float radix2 (Zpos mx) ex))) as (e',Ex). simpl.
apply Zmax_lub with (2 := Hminmax).
cut (e' - 1 < emax + prec)%Z. omega.
apply Zmax_lub.
cut (e' - 1 < emax)%Z. clear ; omega.
apply lt_bpow with radix2.
apply Rle_lt_trans with (2 := Bx).
change (Zpos mx) with (Zabs (Zpos mx)).
......@@ -214,6 +234,8 @@ rewrite <- abs_F2R.
apply Ex.
apply Rgt_not_eq.
now apply F2R_gt_0_compat.
unfold emin. clear -Hprec Hmax.
omega.
Qed.
Inductive mode := mode_NE | mode_ZR | mode_DN | mode_UP | mode_NA.
......@@ -253,7 +275,7 @@ Theorem binary_round_sign_correct :
forall mode x mx ex lx,
inbetween_float radix2 (Zpos mx) ex (Rabs x) lx ->
(ex <= fexp (digits radix2 (Zpos mx) + ex))%Z ->
if Rlt_bool (Rabs (round radix2 fexp (round_mode mode) x)) (bpow radix2 (emax + prec)) then
if Rlt_bool (Rabs (round radix2 fexp (round_mode mode) x)) (bpow radix2 emax) then
B2R (binary_round_sign mode (Rlt_bool x 0) mx ex lx) = round radix2 fexp (round_mode mode) x
else
binary_round_sign mode (Rlt_bool x 0) mx ex lx = B754_infinity (Rlt_bool x 0).
......@@ -392,7 +414,7 @@ Definition Bmult m x y :=
Theorem Bmult_correct :
forall m x y,
if Rlt_bool (Rabs (round radix2 fexp (round_mode m) (B2R x * B2R y))) (bpow radix2 (emax + prec)) then
if Rlt_bool (Rabs (round radix2 fexp (round_mode m) (B2R x * B2R y))) (bpow radix2 emax) then
B2R (Bmult m x y) = round radix2 fexp (round_mode m) (B2R x * B2R y)
else
Bmult m x y = B754_infinity (xorb (Bsign x) (Bsign y)).
......@@ -422,7 +444,8 @@ unfold fexp, FLT_exp.
refine (_ (digits_mult_ge radix2 (Zpos mx) (Zpos my) _ _)) ; try discriminate.
refine (_ (digits_gt_0 radix2 (Zpos mx) _) (digits_gt_0 radix2 (Zpos my) _)) ; try discriminate.
generalize (digits radix2 (Zpos mx)) (digits radix2 (Zpos my)) (digits radix2 (Zpos mx * Zpos my)).
clear -Hprec Hmin.
clear -Hprec Hmax.
unfold emin.
intros dx dy dxy Hx Hy Hxy.
zify ; intros ; subst.
omega.
......@@ -530,7 +553,7 @@ Theorem Bplus_correct :
forall m x y,
is_finite x = true ->
is_finite y = true ->
if Rlt_bool (Rabs (round radix2 fexp (round_mode m) (B2R x + B2R y))) (bpow radix2 (emax + prec)) then
if Rlt_bool (Rabs (round radix2 fexp (round_mode m) (B2R x + B2R y))) (bpow radix2 emax) then
B2R (Bplus m x y) = round radix2 fexp (round_mode m) (B2R x + B2R y)
else
(Bplus m x y = B754_infinity (Bsign x) /\ Bsign x = Bsign y).
......@@ -559,7 +582,7 @@ rewrite <- plus_F2R.
case_eq (Fplus radix2 (Float radix2 (cond_Zopp sx (Zpos mx)) ex)
(Float radix2 (cond_Zopp sy (Zpos my)) ey)).
intros mz ez Hz.
assert (Sz: (bpow radix2 (emax + prec) <= Rabs (round radix2 fexp (round_mode m) (F2R (Float radix2 mz ez))))%R -> sx = Rlt_bool (F2R (Float radix2 mz ez)) 0 /\ sx = sy).
assert (Sz: (bpow radix2 emax <= Rabs (round radix2 fexp (round_mode m) (F2R (Float radix2 mz ez))))%R -> sx = Rlt_bool (F2R (Float radix2 mz ez)) 0 /\ sx = sy).
rewrite <- Hz.
rewrite plus_F2R.
......@@ -700,7 +723,7 @@ Definition Bdiv m x y :=
Theorem Bdiv_correct :
forall m x y,
B2R y <> R0 ->
if Rlt_bool (Rabs (round radix2 fexp (round_mode m) (B2R x / B2R y))) (bpow radix2 (emax + prec)) then
if Rlt_bool (Rabs (round radix2 fexp (round_mode m) (B2R x / B2R y))) (bpow radix2 emax) then
B2R (Bdiv m x y) = round radix2 fexp (round_mode m) (B2R x / B2R y)
else
Bdiv m x y = B754_infinity (xorb (Bsign x) (Bsign y)).
