Commit 603d5937 authored by BOLDO Sylvie's avatar BOLDO Sylvie
End of Veltkamp + Beginning FTS
parent c517cdec
...@@ -55,6 +55,15 @@ omega. ...@@ -55,6 +55,15 @@ omega.
Qed. Qed.
Lemma FtoR_F2R: forall (f:Float.float) (g: float beta), Float.Fnum f = Fnum g -> Float.Fexp f = Fexp g ->
FtoR beta f = F2R g.
Proof.
intros f g H1 H2; unfold FtoR, F2R.
rewrite H1, H2, Z2R_IZR.
now rewrite bpow_powerRZ, Z2R_IZR.
Qed.
End Bounds. End Bounds.
Section b_Bounds. Section b_Bounds.
...@@ -101,27 +110,52 @@ exact H0. ...@@ -101,27 +110,52 @@ exact H0.
Qed. Qed.
Lemma format_is_pff_format': forall r,
(generic_format beta (FLT_exp (-dExp b) p) r) ->
Fbounded b (Float.Float (Ztrunc (scaled_mantissa beta (FLT_exp (-dExp b) p) r))
(canonic_exp beta (FLT_exp (-dExp b) p) r)).
Proof.
intros x; unfold generic_format.
set (ex := canonic_exp beta (FLT_exp (-dExp b) p) x).
set (mx := Ztrunc (scaled_mantissa beta (FLT_exp (-dExp b) p) x)).
intros Hx; repeat split ; simpl.
apply lt_Z2R.
rewrite pGivesBound, Z2R_Zpower_nat.
apply Rmult_lt_reg_r with (bpow beta ex).
apply bpow_gt_0.
rewrite <- bpow_plus.
rewrite inj_abs; try omega.
change (F2R (Float beta (Zabs mx) ex) < bpow beta (p + ex))%R.
rewrite F2R_Zabs.
rewrite <- Hx.
destruct (Req_dec x 0) as [Hx0|Hx0].
rewrite Hx0, Rabs_R0.
apply bpow_gt_0.
unfold canonic_exp in ex.
destruct (ln_beta beta x) as (ex', He).
simpl in ex.
specialize (He Hx0).
apply Rlt_le_trans with (1 := proj2 He).
apply bpow_le.
cut (ex' - p <= ex)%Z. omega.
unfold ex, FLT_exp.
apply Zle_max_l.
apply Zle_max_r.
Qed.
Lemma format_is_pff_format: forall r, Lemma format_is_pff_format: forall r,
(generic_format beta (FLT_exp (-dExp b) p) r) (generic_format beta (FLT_exp (-dExp b) p) r)
-> exists f, FtoR beta f = r /\ Fbounded b f. -> exists f, FtoR beta f = r /\ Fbounded b f.
intros r Hr. intros r Hr.
apply FLT_format_generic in Hr; auto with zarith. eexists; split.
destruct Hr as (f,(Hf1,(Hf2,Hf3))). 2: apply (format_is_pff_format' _ Hr).
exists (Float.Float (Fnum f) (Fexp f)); split. rewrite Hr at 3; unfold FtoR, F2R; simpl.
rewrite Hf1. now rewrite Z2R_IZR, bpow_powerRZ, Z2R_IZR.
unfold F2R, FtoR; simpl.
rewrite Z2R_IZR.
rewrite bpow_powerRZ.
rewrite Z2R_IZR; reflexivity.
split.
apply Zlt_le_trans with (1:=Hf2).
rewrite pGivesBound.
rewrite Zpower_Zpower_nat; auto with zarith.
exact Hf3.
unfold Prec_gt_0;auto with zarith.
Qed. Qed.
Lemma equiv_RNDs_aux: forall z, Zeven z = true -> Even z. Lemma equiv_RNDs_aux: forall z, Zeven z = true -> Even z.
intros z; unfold Zeven, Even. intros z; unfold Zeven, Even.
case z. case z.
Require Import Fcore. Require Import Fcore.
Require Import Fprop_plus_error. Require Import Fprop_plus_error.
Require Import Fprop_mult_error. Require Import Fprop_mult_error.
Require Import Fast2Sum.
Require Import FmaErr. Require Import FmaErr.
Require Import Ftranslate_flocq2Pff. Require Import Ftranslate_flocq2Pff.
Open Scope R_scope. Open Scope R_scope.
Section FTS.
Variable emin prec : Z.
Hypothesis precisionNotZero : (1 < prec)%Z.
Context { prec_gt_0_ : Prec_gt_0 prec }.
Hypothesis emin_neg: (emin <= 0)%Z.
Notation format := (generic_format radix2 (FLT_exp emin prec)).
Notation round_flt :=(round radix2 (FLT_exp emin prec) ZnearestE).
Notation bpow e := (bpow radix2 e).
(** inputs *)
Variable x y:R.
Hypothesis Fx: format x.
Hypothesis Fy: format y.
(** algorithm *)
Let a := round_flt (x+y).
Let b := round_flt (round_flt (a-x)-y).
(** Theorem *)
Theorem FastTwoSum: Rabs y <= Rabs x -> a+b=x+y.
Proof with auto with typeclass_instances.
intros H.
destruct (format_is_pff_format radix2 (make_bound radix2 prec emin)
prec (make_bound_p radix2 prec emin precisionNotZero) precisionNotZero x)
as (fx,(Hfx,Hfx')).
rewrite make_bound_Emin; try assumption.
replace (--emin)%Z with emin by omega; assumption.
prec (make_bound_p radix2 prec emin precisionNotZero) precisionNotZero y)
as (fy,(Hfy,Hfy')).
pose (Iplus := fun (f g:float) => (Float.Float
(Ztrunc (scaled_mantissa radix2 (FLT_exp (emin) prec) (FtoR radix2 f+FtoR radix2 g)))
(canonic_exp radix2 (FLT_exp (emin) prec) (round_flt (FtoR radix2 f+FtoR radix2 g))))).
pose (Iminus := fun (f g:float) => (Float.Float
(Ztrunc (scaled_mantissa radix2 (FLT_exp (emin) prec) (FtoR radix2 f-FtoR radix2 g)))
(canonic_exp radix2 (FLT_exp (emin) prec) (round_flt (FtoR radix2 f-FtoR radix2 g))))).
assert (H1: forall x y, FtoR 2 (Iplus x y) = round_flt (FtoR 2 x + FtoR 2 y)).
clear; intros x y.
assert (format (round_flt (FtoR 2 x + FtoR 2 y))).
apply generic_format_round...
BLOP.
admit.
rewrite H; unfold Iplus.
change 2%Z with (radix_val radix2).
apply FtoR_F2R; try easy.
assert (K: FtoR 2 (Iminus fy (Iminus (Iplus fx fy) fx)) =
FtoR 2 fx + FtoR 2 fy - FtoR 2 (Iplus fx fy)).
apply Dekker with (make_bound radix2 prec emin) (Zabs_nat prec); try assumption.
apply Nat2Z.inj_lt.
rewrite inj_abs; simpl; omega.
apply make_bound_p; omega.
admit.
admit.
admit.
rewrite Hfx, Hfy; assumption.
replace 2%nat with (Zabs_nat 2) by easy.
apply Zabs_nat_le; omega.
apply Nat2Z.inj_le.
rewrite inj_minus, Zmax_r; rewrite inj_abs; simpl; omega.
rewrite Hfx; rewrite inj_abs; try omega.
rewrite bpow_powerRZ in Hfp'; rewrite Z2R_IZR i
destruct (round_NE_is_pff_round radix2 (make_bound radix2 prec emin)
(x+y))
as (fa,(Hfa, (Hfa',Hfa''))).
rewrite make_bound_Emin in Hfa''; try assumption.
replace (--emin)%Z with emin in Hfa'' by omega.
apply Rplus_eq_reg_r with (-y).
ring_simplify (x+y+-y).
unfold a; rewrite <- Hfa'', <- Hfx, <- Hfy.
apply Dekker.
Qed.
End FTS.
Section Veltkamp. Section Veltkamp.
Variable beta : radix. Variable beta : radix.
...@@ -160,14 +272,79 @@ apply make_bound_p; omega. ...@@ -160,14 +272,79 @@ apply make_bound_p; omega.
Qed. Qed.
Theorem Veltkamp_tail: Theorem Veltkamp_Tail:
x = hx+tx /\ generic_format beta (FLT_exp emin s) tx. x = hx+tx /\ generic_format beta (FLT_exp emin s) tx.
Proof with auto with typeclass_instances. Proof with auto with typeclass_instances.
destruct (format_is_pff_format beta (make_bound beta prec emin)
TODO. prec (make_bound_p beta prec emin precisionNotZero) precisionNotZero x)
as (fx,(Hfx,Hfx')).
destruct (round_NE_is_pff_round beta (make_bound beta prec emin)
(x*(bpow s+1)))
as (fp,(Hfp, (Hfp',Hfp''))).
rewrite make_bound_Emin in Hfp''; try assumption.
replace (--emin)%Z with emin in Hfp'' by omega.
(x-p))
as (fq,(Hfq, (Hfq',Hfq''))).
rewrite make_bound_Emin in Hfq''; try assumption.
replace (--emin)%Z with emin in Hfq'' by omega.
(q+p))
as (fhx,(Hfhx, (Hfhx',Hfhx''))).
rewrite make_bound_Emin in Hfhx''; try assumption.
replace (--emin)%Z with emin in Hfhx'' by omega.
(x-hx))
as (ftx,(Hftx, (Hftx',Hftx''))).
rewrite make_bound_Emin in Hftx''; try assumption.
replace (--emin)%Z with emin in Hftx'' by omega.
destruct Veltkamp_tail with beta (make_bound beta prec emin) (Zabs_nat s)
(Zabs_nat prec) fx fp fq fhx ftx as (tx', (H1,(H2,(H3,H4)))); try assumption.
apply radix_gt_1.
apply Nat2Z.inj_le.
rewrite bpow_powerRZ in Hfp'; rewrite Z2R_IZR in Hfp'; apply Hfp'.
rewrite Hfx, Hfp''; apply Hfq'.
rewrite Hfp'', Hfq''; apply Hfhx'.
rewrite Hfhx'', Hfx; apply Hftx'.
split.
rewrite <- Hfx, <-H2, Hfhx'', H1, Hftx''; easy.
unfold tx; rewrite <- Hftx'', <- H1.
replace emin with (-dExp (Bound
(Pos.of_succ_nat
(Peano.pred (Z.abs_nat (Zpower_nat beta (Z.abs_nat s)))))
(dExp (make_bound beta prec emin))))%Z.
apply pff_format_is_format; try assumption; try omega.
simpl.
rewrite Zpos_P_of_succ_nat, inj_pred.
rewrite <- Zsucc_pred.
apply inj_abs.
apply Zpower_NR0.
apply Zlt_le_weak; apply radix_gt_0.
apply notEqLt, lt_Zlt_inv.
rewrite inj_abs.
apply Zpower_nat_less.
apply radix_gt_1.
apply Zpower_NR0.
simpl.
rewrite Zabs2N.id_abs.
rewrite Z.abs_neq; omega.
Qed. Qed.
End Veltkamp. End Veltkamp.
Section ErrFMA. Section ErrFMA.
