Commit 32205115 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Prove generic_format_plus_ulp.
parent d98b548b
...@@ -723,6 +723,82 @@ now apply generic_format_pred_2. ...@@ -723,6 +723,82 @@ now apply generic_format_pred_2.
now apply generic_format_pred_1. now apply generic_format_pred_1.
Qed. Qed.
Theorem generic_format_plus_ulp :
forall { monotone_exp : Monotone_exp fexp },
forall x, (x <> 0)%R ->
F x -> F (x + ulp x).
Proof with auto with typeclass_instances.
intros monotone_exp x Zx Fx.
destruct (Rtotal_order x 0) as [Hx|[Hx|Hx]].
rewrite <- Ropp_involutive.
apply generic_format_opp.
rewrite Ropp_plus_distr, <- ulp_opp.
apply generic_format_opp in Fx.
destruct (Req_dec (-x) (bpow (ln_beta beta (-x) - 1))) as [Hx'|Hx'].
rewrite Hx' in Fx |- *.
apply generic_format_bpow_inv' in Fx...
unfold ulp, canonic_exp.
rewrite ln_beta_bpow.
revert Fx.
generalize (ln_beta_val _ _ (ln_beta beta (-x)) - 1)%Z.
clear -monotone_exp valid_exp.
intros e He.
destruct (Zle_lt_or_eq _ _ He) as [He1|He1].
assert (He2 : e = (e - fexp (e + 1) + fexp (e + 1))%Z) by ring.
rewrite He2 at 1.
rewrite bpow_plus.
assert (Hb := Z2R_Zpower beta _ (Zle_minus_le_0 _ _ He)).
match goal with |- F (?a * ?b + - ?b) =>
replace (a * b + -b)%R with ((a - 1) * b)%R by ring end.
rewrite <- Hb.
rewrite <- (Z2R_minus _ 1).
change (F (F2R (Float beta (Zpower beta (e - fexp (e + 1)) - 1) (fexp (e + 1))))).
apply generic_format_F2R.
intros Zb.
unfold canonic_exp.
rewrite ln_beta_F2R with (1 := Zb).
rewrite (ln_beta_unique beta _ (e - fexp (e + 1))).
apply monotone_exp.
rewrite <- He2.
apply Zle_succ.
rewrite Rabs_pos_eq.
rewrite Z2R_minus, Hb.
split.
apply Rplus_le_reg_r with (- bpow (e - fexp (e + 1) - 1) + Z2R 1)%R.
apply Rmult_le_reg_r with (bpow (-(e - fexp (e+1) - 1))).
apply bpow_gt_0.
ring_simplify.
apply Rle_trans with R1.
rewrite Rmult_1_l.
apply (bpow_le _ _ 0).
clear -He1 ; omega.
rewrite Ropp_mult_distr_l_reverse.
rewrite <- 2!bpow_plus.
ring_simplify (e - fexp (e + 1) - 1 + - (e - fexp (e + 1) - 1))%Z.
ring_simplify (- (e - fexp (e + 1) - 1) + (e - fexp (e + 1)))%Z.
simpl.
rewrite <- (Z2R_plus (-1) _).
apply (Z2R_le 1).
unfold Zpower_pos, iter_pos.
generalize (Zle_bool_imp_le _ _ (radix_prop beta)).
clear ; omega.
rewrite <- (Rplus_0_r (bpow (e - fexp (e + 1)))) at 2.
apply Rplus_lt_compat_l.
now apply (Z2R_lt (-1) 0).
rewrite Z2R_minus.
apply Rle_0_minus.
rewrite Hb.
apply (bpow_le _ 0).
now apply Zle_minus_le_0.
rewrite He1, Rplus_opp_r.
apply generic_format_0.
apply generic_format_pred_1 ; try easy.
rewrite <- Ropp_0.
now apply Ropp_lt_contravar.
now elim Zx.
now apply generic_format_succ.
Qed.
Lemma pred_plus_ulp_1 : Lemma pred_plus_ulp_1 :
forall x, (0 < x)%R -> F x -> forall x, (0 < x)%R -> F x ->
x <> bpow (ln_beta beta x - 1) -> x <> bpow (ln_beta beta x - 1) ->
