Commit 163e4579 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Partial of proof of FLX_format_satisfies_any.
parent 20b97dd0
...@@ -40,6 +40,17 @@ exact H. ...@@ -40,6 +40,17 @@ exact H.
now rewrite 2!(Rmult_comm r). now rewrite 2!(Rmult_comm r).
Qed. Qed.
Lemma exp_increasing_weak :
forall x y : R,
(x <= y)%R -> (exp x <= exp y)%R.
Proof.
intros x y [H|H].
apply Rlt_le.
now apply exp_increasing.
rewrite H.
apply Rle_refl.
Qed.
End Rmissing. End Rmissing.
Section Z2R. Section Z2R.
...@@ -183,7 +194,7 @@ End Z2R. ...@@ -183,7 +194,7 @@ End Z2R.
Section pow. Section pow.
Record radix := { radix_val :Z ; radix_prop : (2 <= radix_val )%Z }. Record radix := { radix_val : Z ; radix_prop : (2 <= radix_val )%Z }.
Variable r: radix. Variable r: radix.
...@@ -245,7 +256,7 @@ destruct r; simpl; auto with zarith. ...@@ -245,7 +256,7 @@ destruct r; simpl; auto with zarith.
Qed. Qed.
Lemma epow_add : Lemma epow_add :
forall e1 e2 : Z, (epow (e1+e2) = epow e1 * epow e2)%R. forall e1 e2 : Z, (epow (e1 + e2) = epow e1 * epow e2)%R.
Proof. Proof.
intros. intros.
repeat rewrite epow_powerRZ. repeat rewrite epow_powerRZ.
...@@ -262,5 +273,197 @@ unfold epow, Zpower_pos, iter_pos. ...@@ -262,5 +273,197 @@ unfold epow, Zpower_pos, iter_pos.
now rewrite Zmult_1_r. now rewrite Zmult_1_r.
Qed. Qed.
End pow. Lemma Z2R_Zpower :
forall e : Z,
(0 <= e)%Z ->
Z2R (Zpower (radix_val r) e) = epow e.
Proof.
intros [|e|e] H.
split.
split.
now elim H.
Qed.
Lemma epow_lt_aux :
forall e1 e2 : Z,
(e1 < e2)%Z -> (epow e1 < epow e2)%R.
Proof.
intros e1 e2 H.
replace e2 with (e1 + (e2 - e1))%Z by ring.
rewrite <- (Rmult_1_r (epow e1)).
rewrite epow_add.
apply Rmult_lt_compat_l.
apply epow_gt_0.
assert (0 < e2 - e1)%Z by omega.
destruct (e2 - e1)%Z ; try discriminate H0.
clear.
unfold epow.
apply (Z2R_lt 1).
rewrite Zpower_pos_nat.
case_eq (nat_of_P p).
intros H.
elim (lt_irrefl 0).
pattern O at 2 ; rewrite <- H.
apply lt_O_nat_of_P.
intros n _.
assert (1 < Zpower_nat (radix_val r) 1)%Z.
unfold Zpower_nat, iter_nat.
rewrite Zmult_1_r.
generalize (radix_prop r).
omega.
induction n.
exact H.
change (S (S n)) with (1 + (S n))%nat.
rewrite Zpower_nat_is_exp.
change 1%Z with (1 * 1)%Z.
apply Zmult_lt_compat.
now split.
now split.
Qed.
Lemma epow_lt :
forall e1 e2 : Z,
(e1 < e2)%Z <-> (epow e1 < epow e2)%R.
Proof.
intros e1 e2.
split.
apply epow_lt_aux.
intros H.
apply Zgt_lt.
apply Znot_le_gt.
intros H'.
apply Rlt_not_le with (1 := H).
destruct (Zle_lt_or_eq _ _ H').
apply Rlt_le.
now apply epow_lt_aux.
apply Req_le.
now apply f_equal.
Qed.
Lemma epow_le :
forall e1 e2 : Z,
(e1 <= e2)%Z <-> (epow e1 <= epow e2)%R.
Proof.
intros e1 e2.
split.
intros H.
apply Rnot_lt_le.
intros H'.
apply Zle_not_gt with (1 := H).
apply Zlt_gt.
now apply <- epow_lt.
intros H.
apply Znot_gt_le.
intros H'.
apply Rle_not_lt with (1 := H).
apply -> epow_lt.
now apply Zgt_lt.
Qed.
Lemma epow_eq :
forall e1 e2 : Z,
e1 = e2 -> epow e1 = epow e2.
Proof.
intros.
apply Rle_antisym.
apply -> epow_le.
now apply Zeq_le.
apply -> epow_le.
apply Zeq_le.
now apply eq_sym.
Qed.
Lemma epow_exp :
forall e : Z,
epow e = exp (Z2R e * ln (Z2R (radix_val r))).
Proof.
(* positive case *)
assert (forall e, epow (Zpos e) = exp (Z2R (Zpos e) * ln (Z2R (radix_val r)))).
intros e.
unfold epow.
unfold Z2R at 2.
rewrite P2R_INR.
induction (nat_of_P e).
rewrite Rmult_0_l.
now rewrite exp_0.
change (S n) with (1 + n)%nat.
rewrite plus_INR.
rewrite Rmult_plus_distr_r.
rewrite exp_plus.
rewrite Rmult_1_l.
rewrite exp_ln.
rewrite <- IHn.
rewrite <- mult_Z2R.
apply f_equal.
unfold Zpower_nat at 1, iter_nat.
apply (Z2R_lt 0).
omega.
(* general case *)
intros [|e|e].
rewrite Rmult_0_l.
now rewrite exp_0.
apply H.
unfold epow.
change (Z2R (Zpower_pos (radix_val r) e)) with (epow (Zpos e)).
rewrite H.
rewrite <- exp_Ropp.
rewrite <- Ropp_mult_distr_l_reverse.
now rewrite <- opp_Z2R.
Qed.
Lemma ln_beta :
forall x : R, (0 < x)%R ->
{e | (epow (e - 1)%Z <= x < epow e)%R}.
Proof.
intros x Hx.
set (fact := ln (Z2R (radix_val r))).
assert (0 < fact)%R.
apply exp_lt_inv.
rewrite exp_0.
unfold fact.
rewrite exp_ln.
apply (Z2R_lt 1).
omega.
apply (Z2R_lt 0).
omega.
exists (up (ln x / fact))%Z.
rewrite 2!epow_exp.
fold fact.
pattern x at 2 3 ; replace x with (exp (ln x / fact * fact)).
split.
rewrite minus_Z2R.
apply exp_increasing_weak.
apply Rmult_le_compat_r.
now apply Rlt_le.
simpl (Z2R 1).
pattern (ln x / fact)%R at 2 ; replace (ln x / fact)%R with (1 + (ln x / fact - 1))%R by ring.
replace (Z2R (up (ln x / fact)) - 1)%R with ((Z2R (up (ln x / fact)) - ln x / fact) + (ln x / fact - 1))%R by ring.
apply Rplus_le_compat_r.
rewrite Z2R_IZR.
eapply for_base_fp.
apply Rmult_lt_compat_r.
exact H.
rewrite Z2R_IZR.
apply Rplus_lt_reg_r with (- (ln x / fact))%R.
rewrite Rplus_opp_l.
rewrite Rplus_comm.
eapply for_base_fp.
unfold Rdiv.
rewrite Rmult_assoc.
rewrite Rinv_l.
rewrite Rmult_1_r.
now apply exp_ln.
now apply Rgt_not_eq.
Qed.
End pow.
Require Import Flocq_Raux.
Require Import Flocq_defs.
Require Import Flocq_rnd_ex.
Require Import Flocq_rnd_prop.
Require Import Flocq_rnd_FIX.
Section RND_FIX.
Open Scope R_scope.
Variable beta : radix.
Notation bpow := (epow beta).
Lemma F2R_pos_imp_Fnum_pos :
forall f : float beta,
0 <= F2R f ->
(0 <= Fnum f)%Z.
Proof.
intros f H.
apply le_Z2R.
apply Rmult_le_reg_l with (bpow (Fexp f)).
apply epow_gt_0.
rewrite Rmult_0_r.
now rewrite Rmult_comm.
Qed.
Lemma F2R_constrain :
forall m e e' p : Z,
(Zabs m < Zpower (radix_val beta) p)%Z ->
bpow e' <= F2R (Float beta m e) ->
exists m' : Z,
F2R (Float beta m e) = F2R (Float beta m' (e' - (p - 1))).
Proof.
intros m e e' p Hm Hf.
exists (m * Zpower (radix_val beta) (e - (e' - (p - 1))))%Z.
unfold F2R.
simpl.
rewrite mult_Z2R.
apply Rmult_eq_compat_l.
rewrite Z2R_Zpower.
rewrite <- epow_add.
apply f_equal.
ring.
assert (e' <= e + (p - 1))%Z.
2: omega.
apply Zlt_succ_le.
unfold Zsucc.
replace (e + (p - 1) + 1)%Z with (e + p)%Z by ring.
apply <- epow_lt.
apply Rle_lt_trans with (1 := Hf).
unfold F2R.
rewrite epow_add.
rewrite Rmult_comm.
apply epow_gt_0.
simpl.
apply Rle_lt_trans with (1 := RRle_abs _).
rewrite Z2R_IZR.
rewrite Rabs_Zabs.
rewrite <- Z2R_IZR.
replace (bpow p) with (Z2R (Zpower (radix_val beta) p)).
now apply Z2R_lt.
rewrite Z2R_Zpower.
apply refl_equal.
clear -Hm.
destruct p as [_|p|p] ; try discriminate.
simpl in Hm.
elim Zlt_not_le with (1 := Hm).
apply Zabs_pos.
Qed.
Variable prec : Z.
Variable Hp : Zlt 0 prec.
Theorem FLX_format_satisfies_any :
satisfies_any (FLX_format beta prec).
Proof.
refine ((fun D => Satisfies_any _ _ _ (projT1 D) (projT2 D)) _).
(* symmetric set *)
exists (Float beta 0 0).
split.
unfold F2R.
now rewrite Rmult_0_l.
apply lt_Z2R.
rewrite Z2R_Zpower.
apply epow_gt_0.
now apply Zlt_le_weak.
intros x ((m,e),(H1,H2)).
exists (Float beta (-m) e).
split.
rewrite H1.
unfold F2R.
simpl.
now rewrite opp_Z2R, Ropp_mult_distr_l_reverse.
simpl.
now rewrite Zabs_Zopp.
(* rounding down *)
assert (Hh : forall x, 0 > x -> 0 < -x).
intros x Hx.
apply Ropp_gt_lt_0_contravar.
exact Hx.
exists (fun x =>
let e :=
Zminus match total_order_T 0 x with
| inleft (left Hx) => projS1 (ln_beta beta _ Hx)
| inleft (right Hx) => Z0
| inright Hx => projS1 (ln_beta beta _ (Hh _ Hx))
end prec in
match FIX_format_satisfies_any beta e with
| Satisfies_any _ _ rnd Hr => rnd x
end).
intros x.
destruct (total_order_T 0 x) as [[Hx|Hx]|Hx].
(* x positive *)
clear Hh.
set (e := (projT1 (ln_beta beta x Hx) - prec)%Z).
destruct (FIX_format_satisfies_any beta e) as (_,_,rnd,Hr).
destruct (Hr x) as ((f,(Hr1,Hr2)),(Hr3,Hr4)).
destruct (ln_beta beta x Hx) as (e', Hb).
simpl in e.
split.
(* - f is compatible with the format *)
assert (Hm: (Zabs (Fnum f) < Zpower (radix_val beta) prec)%Z).
apply Zgt_lt.
apply Znot_le_gt.
intros Hm.
apply Rlt_not_le with (1 := proj2 Hb).
apply Rle_trans with (2 := Hr3).
rewrite Hr1.
unfold F2R.
rewrite Hr2.
replace e' with (prec + e)%Z by ( unfold e ; ring ).
rewrite epow_add.
apply epow_ge_0.
rewrite <- Z2R_Zpower.
apply Z2R_le.
rewrite <- (Zabs_eq (Fnum f)).
exact Hm.
apply F2R_pos_imp_Fnum_pos.
rewrite <- Hr1.
apply Rnd_pos_imp_pos with (FIX_format beta e).
exists (Float beta 0 e).
repeat split.
unfold F2R.
split.
now apply Rnd_DN_monotone with (FIX_format beta e).
now apply Rnd_DN_idempotent.
now apply Rlt_le.
now exists f ; split.
(* - f is the biggest float smaller than x *)
split.
exact Hr3.
intros g ((mg,eg),(Hg1,Hg2)) Hgx.
destruct (Rle_or_lt g (bpow (e' - 1)%Z)).
apply Rle_trans with (1 := H).
apply Hr4.
exists (Float beta (Zpower (radix_val beta) (prec - 1)) e).
repeat split.
unfold F2R.
simpl.
rewrite Z2R_Zpower.
unfold e.
apply f_equal.
ring.
omega.
apply Hb.
apply Hr4.
destruct (F2R_constrain mg eg (e' - 1) prec Hg2) as (mg',Hg).
rewrite <- Hg1.
now apply Rlt_le.
rewrite Hg1, Hg.
replace (e' - 1 - (prec - 1))%Z with (e' - prec)%Z by ring.
now exists (Float beta mg' (e' - prec)).
exact Hgx.
(* x zero *)
admit.
(* x negative *)
admit.
Qed.
End RND_FIX.
...@@ -2,6 +2,7 @@ FILES = \ ...@@ -2,6 +2,7 @@ FILES = \
Flocq_Raux.v \ Flocq_Raux.v \
Flocq_defs.v \ Flocq_defs.v \
Flocq_rnd_FIX.v \ Flocq_rnd_FIX.v \
Flocq_rnd_FLX.v \
Flocq_rnd_ex.v \ Flocq_rnd_ex.v \
Flocq_rnd_prop.v Flocq_rnd_prop.v
...@@ -13,7 +14,7 @@ datadir = $(libdir) ...@@ -13,7 +14,7 @@ datadir = $(libdir)
.v.vo: .v.vo:
@echo COQC $< @echo COQC $<
@$(COQC) $(COQRFLAG) $< @$(COQC) $(COQRFLAG) -dont-load-proofs $<
.v.vd: .v.vd:
@echo COQDEP $< @echo COQDEP $<
