Commit 13d352a2 authored by Sylvie Boldo's avatar Sylvie Boldo
End of rnd_odd_prop with moving of lemmas
parent 0821273b
This file is part of the Flocq formalization of floating-point
arithmetic in Coq: http://flocq.gforge.inria.fr/
Copyright (C) 2010-2011 Sylvie Boldo
#<br />#
Copyright (C) 2010-2011 Guillaume Melquiond
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 3 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
COPYING file for more details.
(** * Rounding to odd and its properties, including the equivalence
between rnd_NE and double rounding with rnd_odd and then rnd_NE *)
Require Import Fcore.
Require Import Fcalc_ops.
......@@ -102,19 +125,6 @@ Definition Rnd_odd_pt (x f : R) :=
Definition Rnd_odd (rnd : R -> R) :=
forall x : R, Rnd_odd_pt x (rnd x).
Lemma Rmult_neq_reg_r: forall r1 r2 r3:R, (r2 * r1 <> r3 * r1)%R -> r2 <> r3.
intros r1 r2 r3 H1 H2.
apply H1; rewrite H2; ring.
Qed.*)
(* TODO déplacer *)
Lemma Rmult_neq_compat_r: forall r1 r2 r3:R, (r1 <> 0)%R -> (r2 <> r3)%R
-> (r2 *r1 <> r3*r1)%R.
intros r1 r2 r3 H H1 H2.
now apply H1, Rmult_eq_reg_r with r1.
Qed.
Theorem Rnd_odd_pt_sym : forall x f : R,
Rnd_odd_pt (-x) (-f) -> Rnd_odd_pt x f.
......@@ -360,37 +370,18 @@ Variable fexp : Z -> Z.
Variable fexpe : Z -> Z.
Context { valid_exp : Valid_exp fexp }.
Context { monotone_exp_ : Monotone_exp fexp }. (* grmbl Exp_not_FTZ ? *)
Context { valid_expe : Valid_exp fexpe }.
Context { exists_NE_e : Exists_NE beta fexpe }.
Hypothesis fexpe_fexp: forall e, (fexpe e <= fexp e -2)%Z.
(* todo déplacer, renommer *)
Lemma generic_format_F2R_2: forall c, forall (x:R) (f:float beta),
F2R f = x -> ((x <> 0)%R ->
(canonic_exp beta c x <= Fexp f)%Z) ->
generic_format beta c x.
Proof.
intros c x f H1 H2.
rewrite <- H1; destruct f as (m,e).
apply generic_format_F2R.
simpl in *; intros H3.
rewrite H1; apply H2.
intros Y; apply H3.
apply F2R_eq_0_reg with beta e.
now rewrite H1.
Qed.
(* todo utiliser le bon lemme *)
Lemma generic_format_fexpe_fexp: forall x,
generic_format beta fexp x -> generic_format beta fexpe x.
Proof.
intros x Hx; unfold generic_format in Hx.
apply generic_format_F2R_2 with
(Float beta (Ztrunc (scaled_mantissa beta fexp x))
(canonic_exp beta fexp x)).
now apply sym_eq.
intros; simpl; unfold canonic_exp.
intros x Hx.
apply generic_inclusion_ln_beta with fexp; trivial; intros Hx2.
generalize (fexpe_fexp (ln_beta beta x)).
omega.
Qed.
......@@ -512,18 +503,6 @@ now apply generic_format_canonic.
Qed.
Lemma Fexp_u: (fexp (ln_beta beta x) <= Fexp u)%Z.
rewrite Cu; unfold canonic_exp.
apply monotone_exp.
apply ln_beta_le.
apply Rlt_le_trans with (1:=dPos).
apply Hd.
apply Hu.
Qed.
Lemma d_le_m: (F2R d <= m)%R.
apply Rmult_le_reg_l with 2%R.
auto with real.
......@@ -714,13 +693,11 @@ Lemma fexp_m_eq_0: (0 = F2R d)%R ->
(fexp (ln_beta beta (F2R u)-1) < fexp (ln_beta beta (F2R u))+1)%Z.
Proof with auto with typeclass_instances.
intros Y.
TOTO.
Admitted. (********************************)
assert ((fexp (ln_beta beta (F2R u) - 1) <= fexp (ln_beta beta (F2R u))))%Z.
apply monotone_exp...
omega.
omega.
Qed.
Lemma Fm: generic_format beta fexpe m.
case (d_ge_0); intros Y.
......@@ -931,6 +908,7 @@ Variable fexpe : Z -> Z.
Variable choice:Z->bool.
......@@ -985,6 +963,4 @@ rewrite <- Hu1; apply round_UP_pt...
Qed.
(* TODO pred(succ)=x=succ(pred)
Section Odd_prop.
End Odd_prop.
......@@ -121,6 +121,18 @@ rewrite <- 3!(Rmult_comm r).
apply Rmult_minus_distr_l.
Qed.
Qed.
Qed.
Theorem Rmult_min_distr_r :
forall r r1 r2 : R,
(0 <= r)%R ->
......@@ -165,6 +165,22 @@ now rewrite Ztrunc_Z2R.
now apply Zle_left.
Qed.
Lemma generic_format_F2R_2: forall (x:R) (f:float beta),
(canonic_exp x <= Fexp f)%Z) ->
generic_format x.
Proof.
intros x f H1 H2.
intros Y; apply H3.
now rewrite H1.
Qed.
Theorem canonic_opp :
forall m e,
canonic (Float beta m e) ->
