GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
ffc466c6
ffc466c6
3 years ago
hhakim
Downloads
Patches
Fix issue #229. PY3_MINOR_VER wrongly set for python3.10.
36a30d45
Pipeline
#834022
skipped
wrapper/python/CMakeLists.txt
+8
-8
8 additions, 8 deletions
8 additions
8 deletions
8
8
ffc466c6
@@ -380,13 +380,13 @@ list(LENGTH CYTHON_EXES CYTHON_EXES_LEN)
#message(STATUS "CYTHON_EXES_LEN=${CYTHON_EXES_LEN}, CYTHON_EXES=${CYTHON_EXES}")
if
UNIX
foreach
PYTHON_EXE IN LISTS PYTHON_EXES
exec_program
PYTHON_EXE
ARGS
"--version"
OUTPUT_VARIABLE PY_VER RETURN_VALUE PY_RES
exec_program
PYTHON_EXE
ARGS
"--version"
_
RETURN_VALUE PY_RES
#message(STATUS "PY_VER=${PY_VER}")
string
REGEX REPLACE
"Python ([0-9]
.[0-9]).*$"
1"
PY_VER_WITH_POINTS
PY_VER
string
REGEX REPLACE
"Python ([0-9])
.([0-9]).*$"
2"
PY_VER
PY_VER
string
REGEX REPLACE
"Python ([0-9]
.[0-9]
1"
PY_VER_WITH_POINTS
PY_VER
_
string
REGEX REPLACE
"Python ([0-9])
.([0-9]
2"
PY_VER
PY_VER
_
if
PY_VER MATCHES 3
set
PY3_VER
PY_VER_WITH_POINTS
PARENT_SCOPE
string
REGEX REPLACE
([0-9]
PY3_MINOR_VER
PY_VER
string
REGEX REPLACE
Python ([0-9])
.([0-9]
2
PY3_MINOR_VER
PY_VER
_
set
PY3_MINOR_VER
PY3_MINOR_VER
PARENT_SCOPE
endif
add_custom_command
TARGET
FAUST_PYTHON_TARGET
@@ -411,10 +411,10 @@ if(UNIX)
elseif
WIN32
if
CMAKE_GENERATOR
MATCHES
"Visual Studio"
foreach
exec_program
PYTHON_EXE
ARGS
"--version"
exec_program
PYTHON_EXE
ARGS
"--version"
_
RETURN_VALUE PY_RES
string
REGEX REPLACE
"Python ([0-9]
.[0-9]).*$"
1"
PY_VER_WITH_POINTS
PY_VER
string
REGEX REPLACE
"Python ([0-9])
.([0-9]).*$"
2"
PY_VER
PY_VER
string
REGEX REPLACE
"Python ([0-9]
.[0-9]
1"
PY_VER_WITH_POINTS
PY_VER
_
string
REGEX REPLACE
"Python ([0-9])
.([0-9]
2"
PY_VER
PY_VER
_
# ONLY Python 3 for Faust built with Visual Studio
if
PY_VER MATCHES 3
set
PY3_VER
PY_VER_WITH_POINTS
PARENT_SCOPE
@@ -422,7 +422,7 @@ elseif(WIN32)
COMMAND
PYTHON_EXE
ARGS
FAUST_PYTHON_BIN_DIR
/setup.py"
"build_ext"
"--inplace"
COMMENT
"Creating pyfaust
PY_VER
string
REGEX REPLACE
([0-9]
1"
PY3_MINOR_VER
PY_VER
string
REGEX REPLACE
Python ([0-9])
.([0-9]
2
PY3_MINOR_VER
PY_VER
_
set
PY3_MINOR_VER
PY3_MINOR_VER
PARENT_SCOPE
endif
endforeach
This diff is collapsed.
Loading
Save comment
