GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
f8001b28
"README.md" did not exist on "be93c51d5"
f8001b28
4 years ago
hhakim
Downloads
Patches
Add static member function pyfaust.factparams.ParamsFact.factor_format_int2str.
91ca664c
wrapper/python/pyfaust/factparams.py
+14
-2
14 additions, 2 deletions
14 additions
2 deletions
14
2
f8001b28
@@ -841,7 +841,7 @@ class ParamsFact(ABC):
map
dense
sparse
dynamic
2
if
isinstance
factor_format
str
if
factor_format
not
in
map
keys
raise
ValueError
factor_format must be in
repr
map
keys
raise
ValueError
factor_format
as str
must be in
repr
map
keys
return
map
factor_format
elif
isinstance
factor_format
int
if
factor_format
not
in
map
values
@@ -849,6 +849,18 @@ class ParamsFact(ABC):
repr
map
values
return
factor_format
@staticmethod
def
factor_format
a
dense
sparse
dynamic
if
isinstance
factor_format
str
if
factor_format
not
in
a
raise
ValueError
factor_format as str must be in
a
return
factor_format
elif
isinstance
factor_format
int
if
factor_format
not
in
range
len
a
raise
ValueError
factor_format as int must be in
repr
range
len
a
return
factor_format
class
ParamsHierarchical
ParamsFact
@@ -906,7 +918,7 @@ class ParamsHierarchical(ParamsFact):
otherwise it
s the rightmost.
is_verbose: True to enable the verbose mode.
factor_format:
dynamic
(by default),
dense
, or
sparse
. If
dense
sparse
then all factors will be numpy.ndarray or
dense
sparse
respectively
numpy.ndarray or
scipy.sparse.csr_matrix. If
dynamic
is used then the algorithm
determines the format of each factor automatically in order to
decrease the memory footprint of the Faust. This option is
This diff is collapsed.
Loading
Save comment
