Commit f6e20a69 authored by hhakim's avatar hhakim
Update pyfaust.Faust.concatenate for dtype consistency.
parent ffc0d012
......@@ -582,12 +582,12 @@ class Faust(numpy.lib.mixins.NDArrayOperatorsMixin):
max_ncols = np.max([a.shape[1] for a in args if isinstance(a,
(Faust,
*array_types))])
F = F@Faust(np.ones(1, max_ncols), dev=F.device)
F = F@Faust(np.ones(1, max_ncols, dtype=F.dtype), dev=F.device)
if(F.shape[0] == 1):
max_nrows = np.max([a.shape[0] for a in args if isinstance(a,
(Faust,
*array_types))])
F = Faust(np.ones(max_nrows, 1), dev=F.device)@F
F = Faust(np.ones(max_nrows, 1, dtype=F.dtype), dev=F.device)@F
def scalar2Faust(G):
if isinstance(G, int):
G = float(G)
......@@ -595,18 +595,18 @@ class Faust(numpy.lib.mixins.NDArrayOperatorsMixin):
raise TypeError("scalar must be int, float or complex")
G, Gdtype = (float(G), np.float) if isinstance(G, np.float) else (G,
np.complex)
return Faust([np.ones((F.shape[0], 1))*G,
np.ones((1, F.shape[1])).astype(Gdtype)],
return Faust([np.ones((F.shape[0], 1), dtype=F.dtype)*G,
np.ones((1, F.shape[1]), dtype=F.dtype).astype(Gdtype)],
dev=F.device)
def broadcast_to_F(G):
if G.shape[0] == 1:
if G.shape[1] != F.shape[1]:
raise ve
G = Faust(np.ones((F.shape[0], 1)), dev=F.device) @ G
G = Faust(np.ones((F.shape[0], 1), dtype=F.dtype), dev=F.device) @ G
elif G.shape[1] == 1:
if G.shape[0] != F.shape[0]:
raise ve
G = G @ Faust(np.ones((1, F.shape[1])), dev=F.device)
G = G @ Faust(np.ones((1, F.shape[1]), dtype=F.dtype), dev=F.device)
return G
# prepare the list of Fausts
largs = []
......@@ -623,14 +623,14 @@ class Faust(numpy.lib.mixins.NDArrayOperatorsMixin):
if(G.size == 1):
G = scalar2Faust(G.reshape(1,)[0])
if G.ndim == 1:
G = Faust([np.ones((F.shape[0], 1)), G.reshape(1, G.size)], dev=F.device)
G = Faust([np.ones((F.shape[0], 1), dtype=F.dtype), G.reshape(1, G.size)], dev=F.device)
else:
G = broadcast_to_F(Faust(G, dev=F.device))
elif isinstance(G,(int, float, np.complex)):
G = scalar2Faust(G)
largs.append(G)
id = np.eye(F.shape[1])
id = np.eye(F.shape[1], dtype=F.dtype)
id_vstack = np.vstack([id for i in range(0,
len(largs)+1)])
C = F.concatenate(*largs, axis=1)
