GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
ed5f50cf
ed5f50cf
5 years ago
hhakim
Downloads
Patches
Add a new error measure in benchmark_eigtj.py. The error is measured on the largest eigenvalue.
2c1f2c6e
misc/test/src/Python/benchmark_eigtj.py
+16
-8
16 additions, 8 deletions
16 additions
8 deletions
16
8
ed5f50cf
@@ -30,16 +30,18 @@ dim_size = 128
plt
rcParams
lines.markersize
7
nruns
20
nruns
plotting
False
# types of data for the benchmark
FOURIER_ERR_ID
LAP_ERR_ID
D_ERR_ID
2
TIME_ID
3
LARGEST_EIGVAL_ERR_ID
3
TIME_ID
4
data_type_str
Fourier Error
Laplacian Error
D error
Execution Time (sec)
data_type_str
Fourier Error
Laplacian Error
D error
Largest
Eigval error
# FGFT algos/confs tested
GIVENS_REAL
@@ -65,13 +67,16 @@ algo_str += [ 'Givens //(real dense)', 'Givens //(real sparse)'
algo_str
Givens (hermit. dense)
Givens (hermit. sparse)
Givens // (hermit. dense)
Givens // (hermit. sparse)
all_data
empty
len
graph_ctors
4
len
algo_str
nruns
dtype
np
float
# arg
4
is
all_data
empty
len
graph_ctors
5
len
algo_str
nruns
dtype
np
float
# arg
5
is
# for type of
# data:
# times,
# fourier_errs,
# lap_errs,
# D err
# D err,
# Largest
# eigval
# err
#times = all_data[:, : ,TIME_ID, :]
@@ -190,6 +195,7 @@ for j in range(old_nruns,nruns):
t
clock
t
Dhata
Fa
best_permutation
U
F
toarray
Dhat
all_data
i
D_ERR_ID
a
j
norm
D
Dhat
norm
D
all_data
i
a
j
max
D
max
Dhat
max
D
Dhat
spdiags
Dhat
Lapa
shape
Lapa
shape
all_data
i
TIME_ID
a
j
t
@@ -225,6 +231,7 @@ for j in range(old_nruns,nruns):
t
clock
t
Dhata
Fa
best_permutation
U
F
toarray
Dhat
all_data
i
D_ERR_ID
a
j
norm
D
Dhat
norm
D
all_data
i
a
j
max
D
max
Dhat
max
D
Dhat
spdiags
Dhat
Lap
shape
Lap
shape
all_data
i
TIME_ID
a
j
t
if
a
in
PARGIVENS_REAL_SPARSE
PARGIVENS_REAL_AS_CPLX_SPARSE
@@ -269,6 +276,7 @@ for j in range(old_nruns,nruns):
D_err2
norm
D
Dhata
norm
D
print
D_err1, D_err2:
D_err1
D_err2
all_data
i
D_ERR_ID
a
j
D_err1
all_data
i
a
j
max
D
max
Dhat
max
D
print
Greatest/Last eigenvalues of Dhat, Dhata, and D:
Dhat
Dhata
D
Dhat
spdiags
Dhat
H
shape
H
shape
@@ -296,7 +304,7 @@ for j in range(old_nruns,nruns):
i
plt
rcParams
figure.figsize
12.0
8
for
j
in
range
# j : index for type of data
for
j
in
range
for
a
in
range
# a == 0 (Givens), a == 1 (Givens //)
nsubplots
4
f
axes
plt
subplots
nsubplots
sharey
True
@@ -306,7 +314,7 @@ for j in range(0,4): # j : index for type of data
for
i
in
range
nsubplots
# i : index for type of algo
# k is for type of graph
# plt.figure()
axes
i
set_title
Algo:
algo_str
i
a
nsubplots
axes
i
set_title
algo_str
i
a
nsubplots
if
j
TIME_ID
axes
i
semilogy
axes
i
boxplot
all_data
k
j
i
a
nsubplots
for
k
in
@@ -326,7 +334,7 @@ for j in range(0,4): # j : index for type of data
for
i
in
range
nsubplots
# i : offset for type of algo
# plt.figure()
axes
i
set_title
Algo:
algo_str
8
i
axes
i
set_title
algo_str
8
i
if
j
TIME_ID
axes
i
semilogy
axes
i
boxplot
all_data
k
j
8
i
for
k
in
This diff is collapsed.
Loading
Save comment
