Commit e8e874d0 authored by hhakim's avatar hhakim
Add py wrapper for factorization (both palm4msa and hierarchical fact.).
Adding unit tests for these algos also.
parent 186df11e
......@@ -5,7 +5,7 @@ import tempfile
import os
import sys
from scipy.io import savemat # , loadmat
from scipy.io import savemat,loadmat
from numpy.linalg import norm
import math
......@@ -301,6 +301,80 @@ class TestFaustPyCplx(TestFaustPy):
self.r = r
self.num_factors = num_factors
class TestFaustFactory(unittest.TestCase):
def testFactPalm4MSA(self):
print("Test FaustFactory.fact_palm4msa()")
from pyfaust import FaustFactory, ParamsPalm4MSA, ConstraintScalar,\
ConstraintName, StoppingCriterion
num_facts = 2
is_update_way_R2L = False
init_lambda = 1.0
init_facts = list()
init_facts.append(np.zeros([500,32]))
init_facts.append(np.eye(32))
#M = np.random.rand(500, 32)
M = \
loadmat(sys.path[-1]+"/../../../misc/data/mat/config_compared_palm2.mat")['data']
# default step_size
cons1 = ConstraintScalar(ConstraintName(ConstraintName.SPLIN), 500, 32, 5)
cons2 = ConstraintScalar(ConstraintName(ConstraintName.NORMCOL), 32,
32, 1.0)
stop_crit = StoppingCriterion(num_its=200)
param = ParamsPalm4MSA(num_facts, is_update_way_R2L, init_lambda,
init_facts, [cons1, cons2], stop_crit,
is_verbose=False, constant_step_size=False)
F = FaustFactory.fact_palm4msa(M, param)
self.assertEqual(F.shape, M.shape)
E = F.todense()-M
#print("err.:",norm(F.todense(), "fro"), norm(E,"fro"), norm (M,"fro"))
print("err: ", norm(E,"fro")/norm(M,"fro"))
# matrix to factorize and reference relative error come from
# misc/test/src/C++/test_palm4MSA.cpp
self.assertAlmostEqual(norm(E,"fro")/norm(M,"fro"), 0.98162, places=4)
def testFactHierarch(self):
print("Test FaustFactory.fact_hierarchical()")
from pyfaust import FaustFactory, ParamsHierarchicalFact, ConstraintScalar,\
num_facts = 4
init_lambda = 1.0
init_facts = list()
for i in range(1,num_facts):
init_facts.append(np.zeros([32,32]))
M = \
loadmat(sys.path[-1]+"/../../../misc/data/mat/matrix_hierarchical_fact.mat")['matrix']
# default step_size
cons2 = ConstraintScalar(ConstraintName(ConstraintName.SP), 32,
32, 96)
cons3 = ConstraintScalar(ConstraintName(ConstraintName.SP), 32, 32,
96)
cons4 = ConstraintScalar(ConstraintName(ConstraintName.NORMCOL), 32, 32,
1)
cons5 = ConstraintScalar(ConstraintName(ConstraintName.SP), 32, 32,
666)
cons6 = ConstraintScalar(ConstraintName(ConstraintName.SP), 32, 32,
333)
stop_crit1 = StoppingCriterion(num_its=200)
stop_crit2 = StoppingCriterion(num_its=200)
param = ParamsHierarchicalFact(num_facts, is_update_way_R2L, init_lambda,
init_facts, [cons1, cons2, cons3, cons4,
cons5, cons6],
M.shape[0],M.shape[1],[stop_crit1,
stop_crit2],
is_verbose=False)
F = FaustFactory.fact_hierarchical(M, param)
E = F.todense()-M
#print("err.:",norm(F.todense(), "fro"), norm(E,"fro"), norm (M,"fro"),
# misc/test/src/C++/hierarchicalFactorization.cpp
self.assertAlmostEqual(norm(E,"fro")/norm(M,"fro"),0.268513, places=5)
if __name__ == "__main__":
if(len(sys.argv)> 1):
......@@ -116,7 +116,7 @@ class Faust:
scale: a multiplicative scalar (see examples below).
core_obj: for internal purpose only. Please don't fill this argument.
WARNING: filepath and factors arguments are multually exclusive. If you
WARNING: filepath and factors arguments are mutually exclusive. If you
use filepath you must explicitely set argument with the keyword.
Examples:
......@@ -195,11 +195,11 @@ class Faust:
>>> F = Faust.rand(2, 10, .5, is_real=False)
>>> G = Faust.rand([2, 5], [10, 20], .5, fac_type="dense")
>>> F
Faust size 10x10, density 0.99, nnz_sum 99, 2 factor(s):<br/>
Faust size 10x10, density 0.99, nnz_sum 99, 2 factors:<br/>
FACTOR 0 (complex) SPARSE, size 10x10, density 0.4, nnz 40<br/>
FACTOR 1 (complex) DENSE, size 10x10, density 0.59, nnz 59<br/>
>>> G
Faust size 19x16, density 1.37171, nnz_sum 417, 4 factor(s):<br/>
Faust size 19x16, density 1.37171, nnz_sum 417, 4 factors:<br/>
FACTOR 0 (real) DENSE, size 19x17, density 0.49226, nnz 159<br/>
FACTOR 1 (real) DENSE, size 17x10, density 0.517647, nnz 88<br/>
FACTOR 2 (real) DENSE, size 10x13, density 0.515385, nnz 67<br/>
......@@ -457,12 +457,12 @@ class Faust:
>>> F = Faust.rand([1, 2], [50, 100], .5)
>>> F.display()
Faust size 98x82, density 0.686909, nnz_sum 5520, 2 factor(s):<br/>
Faust size 98x82, density 0.686909, nnz_sum 5520, 2 factors:<br/>
FACTOR 0 (real) SPARSE, size 98x78, density 0.395081, nnz 3020<br/>
FACTOR 1 (real) SPARSE, size 78x82, density 0.390869, nnz 2500<br/>
>>> F
......@@ -544,7 +544,7 @@ class Faust:
Examples:
>>> F = Faust.rand(5, 10**6, .00001, 'sparse')
Faust size 1000000x1000000, density 5e-05, nnz_sum 49999995, 5 factor(s):<br/>
Faust size 1000000x1000000, density 5e-05, nnz_sum 49999995, 5 factors:<br/>
FACTOR 0 (real) SPARSE, size 1000000x1000000, density 1e-05, nnz 9999999<br/>
FACTOR 1 (real) SPARSE, size 1000000x1000000, density 1e-05, nnz 9999999<br/>
FACTOR 2 (real) SPARSE, size 1000000x1000000, density 1e-05, nnz 9999999<br/>
......@@ -582,7 +582,7 @@ class Faust:
>>> F
......@@ -926,3 +926,233 @@ class Faust:
return np.dtype(np.float64)
else:
return np.dtype(np.complex)
class FaustFactory:
@staticmethod
def fact_palm4msa(M, p):
Factorizes the matrix M using the parameters set in p.
Args:
M: the numpy matrix to factorize.
p: the ParamsPalm4MSA instance to define the algorithm parameters.
Returns:
A Faust object as the result of the factorization.
Examples:
>>> import numpy as np
>>> num_facts = 2
>>> init_lambda = 1.0
>>> init_facts = list()
>>> cons2 = ConstraintScalar(ConstraintName(ConstraintName.NORMCOL), 32, 32, 1.0)
>>> # default step_size is 1e-16
>>> is_verbose=False)
>>> F.display()
Faust size 500x32, density 0.22025, nnz_sum 3524, 2 factor(s):<br/>
FACTOR 0 (real) SPARSE, size 500x32, density 0.15625, nnz 2500<br/>
FACTOR 1 (real) SPARSE, size 32x32, density 1, nnz 1024<br/>
>>> # verify if NORMCOL constraint is respected by the 2nd factor
>>> for i in range(0, F.get_factor(1).shape[1]):
>>> if(i<F.get_factor(1).shape[1]-1):
>>> end=' '
>>> else:
>>> end='\n'
>>> print(norm(F.get_factor(1)[:,i]), end=end)
1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0
if(not isinstance(p, ParamsPalm4MSA)):
raise ValueError("p must be a ParamsPalm4MSA object.")
return Faust(core_obj=FaustCorePy.FaustFact.fact_palm4MSA(M, p))
@staticmethod
def fact_hierarchical(M, p):
Args:
p: the ParamsHierarchicalFact instance to define the algorithm parameters.
Returns:
Examples:
>>> import numpy as np
>>> num_facts = 4
>>> init_lambda = 1.0
>>> init_facts = list()
>>> cons2 = ConstraintScalar(ConstraintName(ConstraintName.SP), 32, 32, 96)
>>> cons3 = ConstraintScalar(ConstraintName(ConstraintName.SP), 32, 32, 96)
>>> cons4 = ConstraintScalar(ConstraintName(ConstraintName.NORMCOL), 32, 32, 1)
>>> cons5 = ConstraintScalar(ConstraintName(ConstraintName.SP), 32, 32, 666)
>>> cons6 = ConstraintScalar(ConstraintName(ConstraintName.SP), 32, 32, 333)
>>> cons5, cons6],
>>> stop_crit2],
>>> is_verbose=False)
Faust::HierarchicalFact<FPP,DEVICE>::compute_facts : factorisation
1/3<br/>
2/3<br/>
3/3<br/>
>>> F.display()
Faust size 500x32, density 0.189063, nnz_sum 3025, 4 factor(s):
- FACTOR 0 (real) SPARSE, size 500x32, density 0.15625, nnz 2500
- FACTOR 1 (real) SPARSE, size 32x32, density 0.09375, nnz 96
- FACTOR 2 (real) SPARSE, size 32x32, density 0.09375, nnz 96
- FACTOR 3 (real) DENSE, size 32x32, density 0.325195, nnz 333
if(not isinstance(p, ParamsHierarchicalFact)):
return Faust(core_obj=FaustCorePy.FaustFact.fact_hierarchical(M, p))
class ParamsFact(object):
def __init__(self, num_facts, is_update_way_R2L, init_lambda, init_facts,
constraints, step_size, constant_step_size = False, is_verbose = False,
self.num_facts = num_facts
self.is_update_way_R2L = is_update_way_R2L
self.init_lambda = init_lambda
self.init_facts = init_facts
self.step_size = step_size
self.constraints = constraints
self.is_verbose = is_verbose
self.constant_step_size = constant_step_size
#TODO: raise exception if num_facts != len(init_facts)
#TODO: likewise for constraints
class ParamsPalm4MSA(ParamsFact):
constraints, stop_crit, step_size = 10.0**-16,
is_verbose = False):
super(ParamsPalm4MSA, self).__init__(num_facts, is_update_way_R2L, init_lambda, init_facts,
constant_step_size,
is_verbose)
self.stop_crit = stop_crit
# TODO: raise exception if stop_crit not a StoppingCriterion object
class ParamsHierarchicalFact(ParamsFact):
constraints, data_num_rows, data_num_cols, stop_crits,
step_size = 10.0**-16, constant_step_size = False,
is_verbose = False,
is_fact_side_left = False):
super(ParamsHierarchicalFact, self).__init__(num_facts, is_update_way_R2L, init_lambda, init_facts,
constant_step_size,
is_verbose)
self.data_num_rows = data_num_rows
self.data_num_cols = data_num_cols
self.stop_crits = stop_crits
self.is_fact_side_left = is_fact_side_left
# TODO: raise exception if stop_crits len != 2 or not StoppingCriterion
# objects
class StoppingCriterion(object):
def __init__(self, is_criterion_error = False , error_treshold = 0.3,
num_its = 500,
max_num_its = 1000):
self.is_criterion_error = is_criterion_error
self.error_treshold = error_treshold
self.num_its = num_its
self.max_num_its = max_num_its
#TODO: check_validity() like C++ code does
class ConstraintName:
SP = 0 # Int Constraint
SPCOL = 1 # Int Constraint
SPLIN=2 # Int Constraint
NORMCOL = 3 # Real Constraint
SPLINCOL = 4 # Int Constraint
CONST = 5 # Mat Constraint
SP_POS = 6 # Int Constraint
#BLKDIAG = 7 # ?? Constraint #TODO
SUPP = 8 # Mat Constraint
NORMLIN = 9 # Real Constraint
def __init__(self, name):
if(name < ConstraintName.SP or name > ConstraintName.NORMLIN):
raise ValueError("name must be an integer among ConstraintName.SP,"
"ConstraintName.SPCOL, ConstraintName.NORMCOL,"
"ConstraintName.SPLINCOL, ConstraintName.CONST,"
"ConstraintName.SP_POS," # ConstraintName.BLKDIAG,
"ConstraintName.SUPP, ConstraintName.NORMLIN")
self.name = name
def is_int_constraint(self):
return self.name in [ ConstraintName.SP, ConstraintName.SPCOL,
ConstraintName.SPLIN, ConstraintName.SPLINCOL,
ConstraintName.SP_POS ]
def is_real_constraint(self):
return self.name in [ ConstraintName.NORMCOL, ConstraintName.NORMLIN ]
def is_mat_constraint(self):
return self.name in [ConstraintName.SUPP, ConstraintName.CONST ]
class ConstraintGeneric(object):
def __init__(self, name , num_rows, num_cols):
self.value = name
self.num_rows = num_rows
self.num_cols = num_cols
@property
def name(self):
return self.value.name
return self.value.is_int_constraint()
return self.value.is_real_constraint()
return self.value.is_mat_constraint()
class ConstraintScalar(ConstraintGeneric):
def __init__(self, name, num_rows, num_cols, param):
super(ConstraintScalar, self).__init__(name, num_rows, num_cols)
self.param = param # raise value error if not np.number (can be complex
# or float/double or integer
class ConstraintMat(ConstraintGeneric):
super(ConstraintMat, self).__init__(name, num_rows, num_cols)
self.param = param #TODO: raise ValueError if not np.ndarray
......@@ -45,7 +45,6 @@
#ifndef FAUSTCORECPP_H
#define FAUSTCORECPP_H
//#include "faust_transform.h"
#include "faust_MatDense.h"
#include "faust_TransformHelper.h"
......@@ -56,7 +55,8 @@ class FaustCoreCpp
public :
//FaustCoreCpp(): transform(){}
FaustCoreCpp(Faust::TransformHelper<FPP,Cpu> &th);
void Display() const { transform.display();}
const char* to_string() const;
void push_back(FPP* valueMat,unsigned int nbrow,unsigned int nbcol);
......@@ -46,6 +46,15 @@
#include <iostream>
#include <exception>
template<typename FPP>
FaustCoreCpp<FPP>::FaustCoreCpp(Faust::TransformHelper<FPP,Cpu> &th)
this->transform = th;
void FaustCoreCpp<FPP>::push_back(FPP* valueMat, unsigned int nbrow,unsigned int nbcol)
......@@ -73,3 +73,52 @@ cdef extern from "FaustCoreCpp.h" :
unsigned int min_num_factors, unsigned int max_num_factors,
unsigned int min_dim_size,
unsigned int max_dim_size, float density)
cdef extern from "FaustFact.h":
cdef cppclass PyxConstraintGeneric:
int name
unsigned long num_rows
unsigned long num_cols
cdef cppclass PyxConstraintInt(PyxConstraintGeneric):
unsigned long parameter
cdef cppclass PyxConstraintScalar[FPP](PyxConstraintGeneric):
FPP parameter
cdef cppclass PyxConstraintMat[FPP](PyxConstraintGeneric):
FPP* parameter # shape = num_rows, num_cols
cdef cppclass PyxStoppingCriterion[FPP]:
bool is_criterion_error
int num_its
FPP error_treshold
unsigned long max_num_its
cdef cppclass PyxParamsFact[FPP]:
int num_facts
bool is_update_way_R2L
FPP init_lambda
FPP** init_facts # num_facts elts
unsigned long* init_fact_sizes
FPP step_size
PyxConstraintGeneric** constraints # (num_facts-1)*2 elts
unsigned int num_constraints
bool is_verbose
bool constant_step_size
cdef cppclass PyxParamsFactPalm4MSA[FPP](PyxParamsFact[FPP]):
PyxStoppingCriterion stop_crit
cdef cppclass PyxParamsHierarchicalFact[FPP](PyxParamsFact[FPP]):
unsigned int num_rows
unsigned int num_cols
PyxStoppingCriterion* stop_crits #must be of size 2
bool is_fact_side_left
cdef FaustCoreCpp[FPP]* fact_palm4MSA[FPP](FPP*,unsigned int, unsigned int,
PyxParamsFactPalm4MSA[FPP]*)
cdef FaustCoreCpp[FPP]* fact_hierarchical[FPP](FPP*,unsigned int, unsigned int,
PyxParamsHierarchicalFact[FPP]*)
......@@ -39,6 +39,8 @@
# importer le module Cython faisant le lien avec la class C++
cimport FaustCoreCy
from FaustCoreCy cimport PyxConstraintGeneric, PyxConstraintInt, \
PyxConstraintMat, PyxConstraintScalar, PyxStoppingCriterion, PyxParamsFactPalm4MSA
cimport numpy as np
......@@ -47,8 +49,7 @@ import copy
from libc.stdlib cimport malloc, free;
from libc.stdio cimport printf
from libc.string cimport memcpy, strlen;
from libcpp cimport bool
from libcpp cimport complex
from libcpp cimport bool, complex
from cpython.mem cimport PyMem_Malloc, PyMem_Realloc, PyMem_Free
from scipy import sparse
from re import match
......@@ -205,13 +206,14 @@ cdef class FaustCore:
if not isinstance(M, (np.ndarray) ):
raise ValueError('input M must a numpy ndarray')
if(self._isReal):
M=M.astype(float,'F')
if not M.dtype=='float':
raise ValueError('input M must be double array')
else:
M=M.astype(complex,'F')
if(M.dtype not in ['complex', 'complex128', 'complex64'] ): #could fail if complex128 etc.
raise ValueError('input M must be complex array')
#TODO: raise exception if not real nor complex
if not M.flags['F_CONTIGUOUS']:
raise ValueError('input M must be Fortran contiguous (Colmajor)')
......@@ -219,7 +221,8 @@ cdef class FaustCore:
if (ndim_M > 2) | (ndim_M < 1):
raise ValueError('input M invalid number of dimensions')
check_matrix(self._isReal, M)
ndim_M=M.ndim
cdef unsigned int nbrow_x=M.shape[0]
cdef unsigned int nbcol_x #can't be assigned because we don't know yet if the input vector is 1D or 2D
......@@ -279,7 +282,7 @@ cdef class FaustCore:
return y
# print information about the faust (size, number of factor, type of factor (dense/sparse) ...)
def display(self):
......@@ -419,3 +422,319 @@ cdef class FaustCore:
del self.core_faust_dbl
else:
del self.core_faust_cplx
cdef check_matrix(isReal, M):
if(isReal):
else:
ndim_M=M.ndim;
cdef class FaustFact:
@staticmethod
def fact_palm4MSA(M, p):
isReal = M.dtype in [ 'float', 'float128',
'float16', 'float32',
'float64', 'double']
# double == float64
#TODO: it not float nor complex, raise exception
cdef unsigned int M_num_rows=M.shape[0]
cdef unsigned int M_num_cols=M.shape[1]
cdef double[:,:] Mview
cdef complex[:,:] Mview_cplx
cdef double[:,:] tmp_mat
cdef complex[:,:] tmp_mat_cplx
cdef FaustCoreCy.PyxParamsFactPalm4MSA[double] cpp_params
cdef FaustCoreCy.PyxParamsFactPalm4MSA[complex] cpp_params_cplx
cdef PyxStoppingCriterion[double] cpp_stop_crit
# template parameter is always double (never complex) because no need
# to have a treshold error of complex type (it wouldn't make sense)
cdef PyxConstraintGeneric** cpp_constraints
cpp_stop_crit.is_criterion_error = p.stop_crit.is_criterion_error
cpp_stop_crit.error_treshold = p.stop_crit.error_treshold
cpp_stop_crit.num_its = p.stop_crit.num_its
cpp_stop_crit.max_num_its = p.stop_crit.max_num_its
if(isReal):
Mview=M
cpp_params.num_facts = p.num_facts
cpp_params.is_update_way_R2L = p.is_update_way_R2L
cpp_params.init_lambda = p.init_lambda
cpp_params.step_size = p.step_size
cpp_params.stop_crit = cpp_stop_crit
cpp_params.init_facts = <double**> \
PyMem_Malloc(sizeof(double*)*p.num_facts)
cpp_params.init_fact_sizes = <unsigned long*> \
PyMem_Malloc(sizeof(unsigned long)*2*p.num_facts)
cpp_params.is_verbose = p.is_verbose
cpp_params.constant_step_size = p.constant_step_size
else:
Mview_cplx=M
cpp_params_cplx.num_facts = p.num_facts
cpp_params_cplx.is_update_way_R2L = p.is_update_way_R2L
cpp_params_cplx.init_lambda = p.init_lambda
cpp_params_cplx.step_size = p.step_size
cpp_params_cplx.init_facts = <complex**> \
PyMem_Malloc(sizeof(complex*)*p.num_facts)
cpp_params_cplx.init_fact_sizes = <unsigned long*> \
cpp_params_cplx.is_verbose = p.is_verbose
cpp_params_cplx.constant_step_size = p.constant_step_size
cpp_constraints = \
<PyxConstraintGeneric**> \
PyMem_Malloc(sizeof(PyxConstraintGeneric*)*len(p.constraints))
for i in range(0,len(p.constraints)):
cons = p.constraints[i]
#print("FaustFact.fact_palm4MSA() cons.name =", cons.name)
if(cons.is_int_constraint()):
#print("FaustFact.fact_palm4MSA() Int Constraint")
cpp_constraints[i] = <PyxConstraintInt*> PyMem_Malloc(sizeof(PyxConstraintInt))
(<PyxConstraintInt*>cpp_constraints[i]).parameter = cons.param
elif(cons.is_real_constraint()):
#print("FaustFact.fact_palm4MSA() Real Constraint")
cpp_constraints[i] = <PyxConstraintScalar[double]*> \
PyMem_Malloc(sizeof(PyxConstraintScalar[double]))
(<PyxConstraintScalar[double]*>cpp_constraints[i]).parameter =\
cons.param
elif(cons.is_mat_constraint()):
#print("FaustFact.fact_palm4MSA() Matrix Constraint")
if(isReal):
cpp_constraints[i] = <PyxConstraintMat[double]*> \
PyMem_Malloc(sizeof(PyxConstraintMat[double]))
tmp_mat = cons.param
(<PyxConstraintMat[double]*>cpp_constraints[i]).parameter =\
&tmp_mat[0,0]
else:
cpp_constraints[i] = <PyxConstraintMat[complex]*> \
PyMem_Malloc(sizeof(PyxConstraintMat[complex]))
tmp_mat_cplx = cons.param
(<PyxConstraintMat[complex]*>cpp_constraints[i]).parameter =\
&tmp_mat_cplx[0,0]
else:
raise ValueError("Constraint type/name is not recognized.")
cpp_constraints[i].name = cons.name
cpp_constraints[i].num_rows = cons.num_rows
cpp_constraints[i].num_cols = cons.num_cols
if(isReal):
cpp_params.constraints = cpp_constraints
cpp_params.num_constraints = len(p.constraints)
else:
cpp_params_cplx.constraints = cpp_constraints
cpp_params_cplx.num_constraints = len(p.constraints)
for i in range(0,p.num_facts):
if(isReal):
tmp_mat = p.init_facts[i]
cpp_params.init_facts[i] = &tmp_mat[0,0]
cpp_params.init_fact_sizes[i*2+0] = p.init_facts[i].shape[0]
cpp_params.init_fact_sizes[i*2+1] = p.init_facts[i].shape[1]
else:
tmp_mat_cplx = p.init_facts[i]
cpp_params_cplx.init_facts[i] = &tmp_mat_cplx[0,0]
cpp_params_cplx.init_fact_sizes[i*2+0] = p.init_facts[i].shape[0]
cpp_params_cplx.init_fact_sizes[i*2+1] = p.init_facts[i].shape[1]
core = FaustCore(core=True)
if(isReal):
core.core_faust_dbl = FaustCoreCy.fact_palm4MSA(&Mview[0,0], M_num_rows, M_num_cols,
# FaustCoreCy.fact_palm4MSA(&Mview[0,0], M_num_rows, M_num_cols,
&cpp_params)
core._isReal = True
#TODO: FPP == complex not yet supported by C++ code
# else:
# core.core_faust_cplx = FaustCoreCy.fact_palm4MSA(&Mview_cplx[0,0], M_num_rows, M_num_cols,
# &cpp_params_cplx)
# core._isReal = False
PyMem_Free(cpp_constraints[i])
PyMem_Free(cpp_constraints)
if(isReal):
PyMem_Free(cpp_params.init_facts)
PyMem_Free(cpp_params.init_fact_sizes)
else:
PyMem_Free(cpp_params_cplx.init_facts)
PyMem_Free(cpp_params_cplx.init_fact_sizes)
return core
@staticmethod
# double == float64
cdef FaustCoreCy.PyxParamsHierarchicalFact[double] cpp_params
cdef FaustCoreCy.PyxParamsHierarchicalFact[complex] cpp_params_cplx
cdef PyxStoppingCriterion[double]* cpp_stop_crits
cpp_stop_crits = <PyxStoppingCriterion[double]*>\
PyMem_Malloc(sizeof(PyxStoppingCriterion[double])*2)
cpp_stop_crits[0].is_criterion_error = p.stop_crits[0].is_criterion_error
cpp_stop_crits[0].error_treshold = p.stop_crits[0].error_treshold
cpp_stop_crits[0].num_its = p.stop_crits[0].num_its
cpp_stop_crits[0].max_num_its = p.stop_crits[0].max_num_its
cpp_stop_crits[1].is_criterion_error = p.stop_crits[1].is_criterion_error
cpp_stop_crits[1].error_treshold = p.stop_crits[1].error_treshold
cpp_stop_crits[1].num_its = p.stop_crits[1].num_its
cpp_stop_crits[1].max_num_its = p.stop_crits[1].max_num_its
if(isReal):
Mview=M
cpp_params.stop_crits = cpp_stop_crits
cpp_params.is_fact_side_left = p.is_fact_side_left
else:
Mview_cplx=M
cpp_params_cplx.is_fact_side_left = p.is_fact_side_left
cpp_constraints = \
#print("FaustFact.fact_hierarchical() cons.name =", cons.name)
#print("FaustFact.fact_hierarchical() Int Constraint")
#print("FaustFact.fact_hierarchical() Real Constraint")
cons.param
#print("FaustFact.fact_hierarchical() Matrix Constraint")
if(isReal):
&tmp_mat[0,0]
else:
&tmp_mat_cplx[0,0]
else:
if(isReal):
cpp_params.num_rows = p.data_num_rows
cpp_params.num_cols = p.data_num_cols
else:
cpp_params_cplx.num_rows = p.data_num_rows
cpp_params_cplx.num_cols = p.data_num_cols
if(isReal):
else:
if(isReal):
core.core_faust_dbl = FaustCoreCy.fact_hierarchical(&Mview[0,0], M_num_rows, M_num_cols,
# FaustCoreCy.fact_hierarchical(&Mview[0,0], M_num_rows, M_num_cols,
&cpp_params)
core._isReal = True
# else:
# core.core_faust_cplx = FaustCoreCy.fact_hierarchical(&Mview_cplx[0,0], M_num_rows, M_num_cols,
# &cpp_params_cplx)
if(isReal):
else:
PyMem_Free(cpp_stop_crits)
return core
#ifndef FAUST_FACT_H
#define FAUST_FACT_H
public:
int name;
unsigned long num_rows;
unsigned long num_cols;
bool is_int_constraint();
bool is_real_constraint();
bool is_mat_constraint();
class PyxConstraintInt : public PyxConstraintGeneric
public:
unsigned long parameter;
class PyxConstraintScalar : public PyxConstraintGeneric
public:
FPP parameter;
class PyxConstraintMat : public PyxConstraintGeneric
public:
FPP* parameter;
public:
bool is_criterion_error;
int num_its;
FPP error_treshold;
unsigned long max_num_its;
class PyxParamsFact
public:
int num_facts;
bool is_update_way_R2L;
FPP init_lambda;
FPP** init_facts;// num_facts elts
unsigned long* init_fact_sizes;
FPP step_size;
PyxConstraintGeneric** constraints; // size: (num_facts-1)*2
unsigned int num_constraints;
bool is_verbose;
bool constant_step_size;
class PyxParamsFactPalm4MSA : public PyxParamsFact<FPP>
public:
PyxStoppingCriterion<FPP> stop_crit;
class PyxParamsHierarchicalFact : public PyxParamsFact<FPP>
public:
unsigned int num_rows;
unsigned int num_cols;
PyxStoppingCriterion<FPP>* stop_crits; // must be of size 2
bool is_fact_side_left;
FaustCoreCpp<FPP>* fact_palm4MSA(FPP*, unsigned int, unsigned int, PyxParamsFactPalm4MSA<FPP>*, bool);
FaustCoreCpp<FPP>* fact_hierarchical(FPP*, unsigned int, unsigned int, PyxParamsHierarchicalFact<FPP>*, bool);
#include "FaustFact.hpp"
#endif
#include <iostream>
#include "faust_Params.h"
#include "faust_ParamsPalm.h"
#include "faust_StoppingCriterion.h"
#include "faust_Palm4MSA.h"
#include "faust_HierarchicalFact.h"
#include "faust_BlasHandle.h"
#include "faust_ConstraintGeneric.h"
using namespace std;
bool PyxConstraintGeneric::is_int_constraint()
switch(static_cast<faust_constraint_name>(this->name))
case CONSTRAINT_NAME_SP:
case CONSTRAINT_NAME_SPCOL:
case CONSTRAINT_NAME_SPLIN:
case CONSTRAINT_NAME_SP_POS:
return true;
default:
return false;
bool PyxConstraintGeneric::is_real_constraint()
case CONSTRAINT_NAME_NORMCOL:
case CONSTRAINT_NAME_NORMLIN:
return true;
default:
return false;
bool PyxConstraintGeneric::is_mat_constraint()
case CONSTRAINT_NAME_CONST:
case CONSTRAINT_NAME_SUPP:
case CONSTRAINT_NAME_BLKDIAG:
return true;
default:
return false;
void prepare_fact(const FPP* mat, const unsigned int num_rows, const unsigned int num_cols, const PyxParamsFact<FPP>* p,
/* out args */vector<const Faust::ConstraintGeneric<FPP,Cpu>*>& cons, vector<Faust::MatDense<FPP,Cpu> > &initFacts)
Faust::ConstraintGeneric<FPP, Cpu>* tmp_cons;
if(p->is_verbose)
cout << "fact_palm4MSA() mat[0]= " << mat[0] << endl;
cout << "p->num_facts: " << p->num_facts << endl;
cout << "p->is_update_way_R2L: " << p->is_update_way_R2L << endl;
cout << "p->init_lambda: " << p->init_lambda << endl;
cout << "p->step_size: " << p->step_size << endl;
cout << "p->is_verbose: " << p->is_verbose << endl;
cout << "p->constant_step_size: " << p->constant_step_size << endl;
PyxConstraintInt* cons_int;
PyxConstraintScalar<FPP>* cons_real;
PyxConstraintMat<FPP>* cons_mat;
for(int i=0; i < p->num_constraints;i++)
if(p->is_verbose) {
cout << "constraint[" << i << "]->name: " << p->constraints[i]->name << endl;
cout << "constraint[" << i << "]->num_rows: " << p->constraints[i]->num_rows << endl;
cout << "constraint[" << i << "]->num_cols: " << p->constraints[i]->num_cols << endl;
//TODO: make ConstraintGeneric virtual and add a display() function to
//avoid this mess and also a function to convert to Faust::Constraint*
// corresponding object
if(p->constraints[i]->is_int_constraint())
cons_int = static_cast<PyxConstraintInt*>(p->constraints[i]);
if(p->is_verbose)
cout << "constraint[" << i << "]->parameter: " << cons_int->parameter << endl;
tmp_cons = new Faust::ConstraintInt<FPP,Cpu>(static_cast<faust_constraint_name>(p->constraints[i]->name), cons_int->parameter, p->constraints[i]->num_rows, p->constraints[i]->num_cols);
cons.push_back(tmp_cons);
else if(p->constraints[i]->is_real_constraint())
cons_real = static_cast<PyxConstraintScalar<FPP>*>(p->constraints[i]);
if(p->is_verbose)
cout << "constraint[" << i << "]->parameter: " << cons_real->parameter << endl;
tmp_cons = new Faust::ConstraintFPP<FPP,Cpu>(static_cast<faust_constraint_name>(p->constraints[i]->name), cons_real->parameter, p->constraints[i]->num_rows, p->constraints[i]->num_cols);
else if(p->constraints[i]->is_mat_constraint())
cons_mat = static_cast<PyxConstraintMat<FPP>*>(p->constraints[i]);
if(p->is_verbose)
cout << "constraint[" << i << "]->parameter: " << cons_mat->parameter[0] << endl;
tmp_cons = new Faust::ConstraintMat<FPP,Cpu>(static_cast<faust_constraint_name>(p->constraints[i]->name), Faust::MatDense<FPP, Cpu>(cons_mat->parameter, p->constraints[i]->num_rows, p->constraints[i]->num_cols), p->constraints[i]->num_rows, p->constraints[i]->num_cols);
else
handleError("FaustFact", "Invalid constraint.");
for(int i=0; i < p->num_facts;i++) {
if(p->is_verbose)
cout << "init_facts[" << i << "] ele[0][0]: " << p->init_facts[i][0] << " size: " << p->init_fact_sizes[i*2] << "x"<< p->init_fact_sizes[i*2+1] << endl;
initFacts.push_back(Faust::MatDense<FPP, Cpu>(p->init_facts[i], p->init_fact_sizes[i*2], p->init_fact_sizes[i*2+1]));
FaustCoreCpp<FPP>* fact_palm4MSA(FPP* mat, unsigned int num_rows, unsigned int num_cols, PyxParamsFactPalm4MSA<FPP>* p)
FaustCoreCpp<FPP>* core;
Faust::MatDense<FPP,Cpu> inMat(mat, num_rows, num_cols);
vector<const Faust::ConstraintGeneric<FPP,Cpu>*> cons;
vector<Faust::MatDense<FPP,Cpu> > initFacts;
if(p->is_verbose) {
cout << "stop_crit.is_criterion_error: " << p->stop_crit.is_criterion_error << endl;
cout << "stop_crit.error_treshold: " << p->stop_crit.error_treshold << endl;
cout << "stop_crit.num_its: " << p->stop_crit.num_its << endl;
cout << "stop_crit.max_num_its: " << p->stop_crit.max_num_its << endl;
prepare_fact(mat, num_rows, num_cols, p, cons, initFacts);
// set all constructor arguments because they could be at non-default
// values
Faust::StoppingCriterion<FPP> crit(p->stop_crit.num_its, p->stop_crit.is_criterion_error, p->stop_crit.error_treshold, p->stop_crit.max_num_its);
Faust::ParamsPalm<FPP,Cpu> params(inMat, p->num_facts, cons, initFacts, crit, p->is_verbose, p->is_update_way_R2L, p->init_lambda, p->constant_step_size, p->step_size);
if(p->is_verbose) params.Display();
Faust::BlasHandle<Cpu> blasHandle;
Faust::Palm4MSA<FPP,Cpu> palm(params,blasHandle,true);
palm.compute_facts();
// palm.get_facts(faust);
const std::vector<Faust::MatDense<FPP,Cpu> >& full_facts = palm.get_facts();
Faust::Transform<FPP, Cpu> faust(full_facts, true);
if(p->is_verbose) faust.Display();
Faust::TransformHelper<FPP, Cpu> th(faust);
core = new FaustCoreCpp<FPP>(th);
blasHandle.Destroy();
for (typename std::vector<const Faust::ConstraintGeneric<FPP,Cpu>*>::iterator it = cons.begin() ; it != cons.end(); ++it)
delete *it;
return core;
FaustCoreCpp<FPP>* fact_hierarchical(FPP* mat, unsigned int num_rows, unsigned int num_cols, PyxParamsHierarchicalFact<FPP>* p)
vector<std::vector<const Faust::ConstraintGeneric<FPP,Cpu>*>> cons_;
vector<const Faust::ConstraintGeneric<FPP,Cpu>*> fact_cons;
vector<const Faust::ConstraintGeneric<FPP,Cpu>*> residuum_cons;
if(p->is_verbose)
cout << "p->num_rows: " << p->num_rows << endl;
cout << "p->num_cols: " << p->num_cols << endl;
cout << "p->is_fact_side_left: " << p->is_fact_side_left;
cout << "stop_crits[0].is_criterion_error: " << p->stop_crits[0].is_criterion_error << endl;
cout << "stop_crits[0].error_treshold: " << p->stop_crits[0].error_treshold << endl;
cout << "stop_crits[0].num_its: " << p->stop_crits[0].num_its << endl;
cout << "stop_crits[0].max_num_its: " << p->stop_crits[0].max_num_its << endl;
cout << "stop_crits[1].is_criterion_error: " << p->stop_crits[1].is_criterion_error << endl;
cout << "stop_crits[1].error_treshold: " << p->stop_crits[1].error_treshold << endl;
cout << "stop_crits[1].num_its: " << p->stop_crits[1].num_its << endl;
cout << "stop_crits[1].max_num_its: " << p->stop_crits[1].max_num_its << endl;
// values
Faust::StoppingCriterion<FPP> crit0(p->stop_crits[0].num_its, p->stop_crits[0].is_criterion_error, p->stop_crits[0].error_treshold, p->stop_crits[0].max_num_its); //2 facts
Faust::StoppingCriterion<FPP> crit1(p->stop_crits[1].num_its, p->stop_crits[1].is_criterion_error, p->stop_crits[1].error_treshold, p->stop_crits[1].max_num_its); //global
for(int i=0;i<p->num_facts-1;i++)
fact_cons.push_back(cons[i]);
residuum_cons.push_back(cons[i+p->num_facts-1]);
cons_.push_back(fact_cons);
cons_.push_back(residuum_cons);
Faust::Params<FPP,Cpu> params(p->num_rows, p->num_cols, p->num_facts, cons_, initFacts, crit0, crit1, p->is_verbose, p->is_update_way_R2L, p->is_fact_side_left, p->init_lambda, p->constant_step_size, p->step_size);
Faust::SpBlasHandle<Cpu> spblasHandle;
Faust::HierarchicalFact<FPP,Cpu> hierFact(inMat, params,blasHandle,spblasHandle);
hierFact.compute_facts();
vector<Faust::MatSparse<FPP,Cpu> > facts;
hierFact.get_facts(facts);
FPP lambda = hierFact.get_lambda();
(facts[0]) *= lambda;
// transform the sparse matrix into generic one
std::vector<Faust::MatGeneric<FPP,Cpu> *> list_fact_generic;
list_fact_generic.resize(facts.size());
for (int i=0;i<list_fact_generic.size();i++)
list_fact_generic[i]=facts[i].Clone();
Faust::Transform<FPP,Cpu> faust(list_fact_generic);
delete list_fact_generic[i];
spblasHandle.Destroy();
delete *it;
return core;
