Commit e6aa48a2 authored by hhakim's avatar hhakim
Use (optionally) a RefManager into FaustGPU and update ctors and methods for...
Use (optionally) a RefManager into FaustGPU and update ctors and methods for the last update of gpu_mod.
- It avoids to duplicate matrices on gpu.
- new member functions: is_cpu_mat_known, are_cpu_mat_all_known.
- Add map between cpu and gpu mats to keep the relationship consistent.
parent 14930262
Subproject commit 36e384c65dada20ef0f6d832216afa45b2e1304d
Subproject commit 4c6cf5bc52c8aff0c832c72c38c19cdbaae22b15
#ifndef __FAUST_GPU__
#define __FAUST_GPU__
#define __GM_LOADER__
#include "faust_RefManager.h"
#include "gm_interf.h"
#include <exception>
#include <iostream>
#include <vector>
#include <map>
#include "faust_MatGeneric.h"
#include "faust_Transform.h"
namespace Faust
template<typename FPP>
class FaustGPU
static RefManager ref_man;
static void *gm_handle;
static int *gm_users;
static void* marr_funcs; //void because we don't know FPP yet and templates aren't available through shared lib interface (extern C, no name mangling)
static void* dsm_funcs;
static void* gp_funcs;
gm_MatArray_t gpu_mat_arr;
std::vector<void*> cpu_mat_ptrs; // addresses stored in gpu_mat_arr
size_t size;
// this map is used to retrieve a cpu mat addr from a gpu mat addr
// this is needed because the RefManager works on cpu mat (to use gpu mat, bijection relationship)
static std::map<void*,void*> cpu_gpu_map;
int32_t nrows;
int32_t ncols;
bool use_ref_man; // default to true
public:
FaustGPU(std::vector<Faust::MatGeneric<FPP,Cpu>*>&);
FaustGPU(const std::vector<Faust::MatGeneric<FPP,Cpu>*>&);
// FaustGPU(const Transform<FPP,Cpu>*);
~FaustGPU();
MatDense<FPP, Cpu> get_product(const bool transpose = false, const bool conjugate = false);
MatDense<FPP, Cpu> multiply(const Faust::MatGeneric<FPP,Cpu>*, const bool transpose = false, const bool conjugate = false);
Vect<FPP, Cpu> multiply(const Faust::Vect<FPP,Cpu>&, const bool transpose = false, const bool conjugate = false);
/* Update on gpu the copy matrix of M (M must have already been loaded otherwise an exception is raised) */
void update(const Faust::MatGeneric<FPP,Cpu>* M, int32_t id);
/* Returns true if the matrix has already been loaded on GPU, false otherwise */
static bool is_cpu_mat_known(const Faust::MatGeneric<FPP,Cpu>*);
/* Returns true if is_cpu_mat_known returns true for each matrix in mats, false otherwise */
static bool are_cpu_mat_all_known(const std::vector<MatGeneric<FPP,Cpu>*> mats);
static void* init_gpu_mod(const std::string& libpath = "libgm.so", const bool silent = false, void* gm_handle = nullptr);
static void check_gpu_mod_loaded();
......@@ -10,7 +10,12 @@ void* Faust::FaustGPU<FPP>::marr_funcs = nullptr;
template <typename FPP>
void* Faust::FaustGPU<FPP>::dsm_funcs = nullptr;
void* Faust::FaustGPU<FPP>::gp_funcs = nullptr;
std::map<void*,void*> Faust::FaustGPU<FPP>::cpu_gpu_map;
void Faust::FaustGPU<FPP>::check_gpu_mod_loaded()
......@@ -33,6 +38,20 @@ void* Faust::FaustGPU<FPP>::init_gpu_mod(const std::string& libpath, const bool
return Faust::FaustGPU<FPP>::gm_handle;
bool Faust::FaustGPU<FPP>::is_cpu_mat_known(const Faust::MatGeneric<FPP,Cpu> *m)
return cpu_gpu_map.find(const_cast<MatGeneric<FPP,Cpu>*>(m)) != cpu_gpu_map.end();
bool Faust::FaustGPU<FPP>::are_cpu_mat_all_known(const std::vector<MatGeneric<FPP,Cpu>*> mats)
for(auto m: mats)
if(! is_cpu_mat_known(m)) return false;
return true;
namespace Faust
template<>
#include "faust_TransformHelper.h"
namespace Faust
template<>
FaustGPU<@FAUST_SCALAR_FOR_GM@>::FaustGPU(std::vector<MatGeneric<@FAUST_SCALAR_FOR_GM@,Cpu>*>& factors)
// std::cout << "FaustGPU<@FAUST_SCALAR_FOR_GM@>::FaustGPU()" << " marr_funcs:" << marr_funcs << std::endl;
MatSparse<@FAUST_SCALAR_FOR_GM@, Cpu>* sp_mat;
MatDense<@FAUST_SCALAR_FOR_GM@, Cpu>* ds_mat;
gm_DenseMatFunc_@GM_SCALAR@* dsm_funcs;
gm_MatArrayFunc_@GM_SCALAR@* marr_funcs;
if(this->marr_funcs == nullptr)
marr_funcs = new gm_MatArrayFunc_@GM_SCALAR@();
dsm_funcs = new gm_DenseMatFunc_@GM_SCALAR@();
load_marr_funcs_@GM_SCALAR@(gm_handle, marr_funcs);
load_dsm_funcs_@GM_SCALAR@(gm_handle, dsm_funcs);
this->marr_funcs = marr_funcs;
this->dsm_funcs = dsm_funcs;
else
dsm_funcs = (gm_DenseMatFunc_@GM_SCALAR@*) this->dsm_funcs;
marr_funcs = (gm_MatArrayFunc_@GM_SCALAR@*) this->marr_funcs;
// std::cout << "FaustGPU<@FAUST_SCALAR_FOR_GM@>::FaustGPU() factors size: " << factors.size() << " marr_funcs:" << marr_funcs << std::endl;
gpu_mat_arr = marr_funcs->create();
// std::cout << "FaustGPU<@FAUST_SCALAR_FOR_GM@>::FaustGPU() factors size: " << factors.size() << std::endl;
size = 0;
nrows = factors[0]->getNbRow();
ncols = (*(factors.end()-1))->getNbCol();
for(auto m: factors)
if(sp_mat = dynamic_cast<MatSparse<@FAUST_SCALAR_FOR_GM@,Cpu>*>(m))
// std::cout << "FaustGPU(): " << sp_mat->getNbRow() << " " << sp_mat->getNbCol()<< " " << sp_mat->getNonZeros()<< std::endl;
marr_funcs->togpu_spm(gpu_mat_arr, sp_mat->getNbRow(), sp_mat->getNbCol(), sp_mat->getNonZeros(), sp_mat->getOuterIndexPtr(), sp_mat->getInnerIndexPtr(), (@GM_SCALAR@*) reinterpret_cast<@GM_REINTERPRET_CAST_SCALAR@*>(sp_mat->getValuePtr()));
else if(ds_mat = dynamic_cast<MatDense<@FAUST_SCALAR_FOR_GM@,Cpu>*>(m))
// std::cout << "FaustGPU(): " << ds_mat->getNbRow() << " " << ds_mat->getNbCol()<< " " << ds_mat->getNonZeros()<< std::endl;
marr_funcs->togpu_dsm(gpu_mat_arr, ds_mat->getNbRow(), ds_mat->getNbCol(), (@GM_SCALAR@*) reinterpret_cast<@GM_REINTERPRET_CAST_SCALAR@*>(ds_mat->getData()));
size++;
template <>
MatDense<@FAUST_SCALAR_FOR_GM@,Cpu> FaustGPU<@FAUST_SCALAR_FOR_GM@>::get_product(const bool transpose /* = false */, const bool conjugate /* = false */)
......@@ -143,12 +97,141 @@ namespace Faust
gm_users--;
gm_MatArrayFunc_@GM_SCALAR@* marr_funcs = (gm_MatArrayFunc_@GM_SCALAR@*) this->marr_funcs;
marr_funcs->free(gpu_mat_arr, true);
if(use_ref_man)
// release all gpu mats
for(auto m: cpu_mat_ptrs)
ref_man.release(m);
marr_funcs->free(gpu_mat_arr, ! use_ref_man); // delete used mats only if it doesn't use ref_man
if(gm_users <= 0)
gm_close_lib(gm_handle);
delete (gm_MatArrayFunc_@GM_SCALAR@*) marr_funcs;
// gm_GenPurposeFunc_@GM_SCALAR@* marr_funcs = (gm_GenPurposeFunc_@GM_SCALAR@*) this->gp_funcs;
delete (gm_DenseMatFunc_@GM_SCALAR@*) dsm_funcs;
// delete (gm_GenPurposeFunc_@GM_SCALAR@*) gp_funcs;
template<>
Faust::RefManager FaustGPU<@FAUST_SCALAR_FOR_GM@>::ref_man([](void *fact)
gm_GenPurposeFunc_@GM_SCALAR@* gp_funcs = (gm_GenPurposeFunc_@GM_SCALAR@*) Faust::FaustGPU<@FAUST_SCALAR_FOR_GM@>::gp_funcs;
//normally cpu_gpu_map must contains a the key fac if ref_man knew it (see ctor)
gp_funcs->free_mat(Faust::FaustGPU<@FAUST_SCALAR_FOR_GM@>::cpu_gpu_map[fact]);
Faust::FaustGPU<@FAUST_SCALAR_FOR_GM@>::cpu_gpu_map.erase(fact);
template<>
FaustGPU<@FAUST_SCALAR_FOR_GM@>::FaustGPU(const std::vector<MatGeneric<@FAUST_SCALAR_FOR_GM@,Cpu>*>& factors) : use_ref_man(true)
gm_GenPurposeFunc_@GM_SCALAR@* gp_funcs;
void* gpu_ref; //sp or ds mat
marr_funcs = new gm_MatArrayFunc_@GM_SCALAR@(); // on the heap because it cannot be shared among FaustGPU instances if on the stack
gp_funcs = new gm_GenPurposeFunc_@GM_SCALAR@();
load_gp_funcs_@GM_SCALAR@(gm_handle, gp_funcs);
this->gp_funcs = gp_funcs;
else
gp_funcs = (gm_GenPurposeFunc_@GM_SCALAR@*) this->gp_funcs;
size = 0;
if(cpu_gpu_map.find(m) != cpu_gpu_map.end())
// already known cpu, gpu mats
if(use_ref_man)
ref_man.acquire(m);
// add the gpu matrix to gpu mat list
if(dynamic_cast<MatDense<@FAUST_SCALAR_FOR_GM@,Cpu>*>(m))
marr_funcs->addgpu_dsm(gpu_mat_arr, cpu_gpu_map[m]);
else
// m is sparse
marr_funcs->addgpu_spm(gpu_mat_arr, cpu_gpu_map[m]);
cpu_mat_ptrs.push_back(m);
continue;
gpu_ref = marr_funcs->togpu_spm(gpu_mat_arr, sp_mat->getNbRow(), sp_mat->getNbCol(), sp_mat->getNonZeros(), sp_mat->getOuterIndexPtr(), sp_mat->getInnerIndexPtr(), (@GM_SCALAR@*) reinterpret_cast<@GM_REINTERPRET_CAST_SCALAR@*>(sp_mat->getValuePtr()));
gpu_ref = marr_funcs->togpu_dsm(gpu_mat_arr, ds_mat->getNbRow(), ds_mat->getNbCol(), (@GM_SCALAR@*) reinterpret_cast<@GM_REINTERPRET_CAST_SCALAR@*>(ds_mat->getData()));
size++;
cpu_gpu_map[m] = gpu_ref;
if(use_ref_man)
ref_man.acquire(m);
// this def. must be located after called ctor and class dtor to avoid error of type "specialization after instantiation"
// template<>
// FaustGPU<@FAUST_SCALAR_FOR_GM@>::FaustGPU(const Transform<@FAUST_SCALAR_FOR_GM@,Cpu>* src_t) : FaustGPU<@FAUST_SCALAR_FOR_GM@>(src_t->data)
template <>
void FaustGPU<@FAUST_SCALAR_FOR_GM@>::update(const Faust::MatGeneric<@FAUST_SCALAR_FOR_GM@,Cpu>* M, int32_t id)
MatGeneric<@FAUST_SCALAR_FOR_GM@,Cpu>* M_ = const_cast<MatGeneric<@FAUST_SCALAR_FOR_GM@,Cpu>*>(M);
// I promise I won't touch M_ data!
if(cpu_gpu_map.find(M_) == cpu_gpu_map.end())
throw std::runtime_error("It's not authorized to update from an unknown host matrix.");
// if the dims are not equal between M_ and the gpu mat, an exception will be raised by gpu_mod
if(sp_mat = dynamic_cast<MatSparse<@FAUST_SCALAR_FOR_GM@,Cpu>*>(M_))
// std::cout << "FaustGPU::update(): " << sp_mat->getNbRow() << " " << sp_mat->getNbCol()<< " " << sp_mat->getNonZeros()<< std::endl;
/* gpu_ref = */marr_funcs->cpu_set_spm_at(gpu_mat_arr, sp_mat->getNbRow(), sp_mat->getNbCol(), sp_mat->getNonZeros(), sp_mat->getOuterIndexPtr(), sp_mat->getInnerIndexPtr(), (@GM_SCALAR@*) reinterpret_cast<@GM_REINTERPRET_CAST_SCALAR@*>(sp_mat->getValuePtr()), id);
else if(ds_mat = dynamic_cast<MatDense<@FAUST_SCALAR_FOR_GM@,Cpu>*>(M_))
// std::cout << "FaustGPU::update(): " << ds_mat->getNbRow() << " " << ds_mat->getNbCol()<< " " << ds_mat->getNonZeros()<< std::endl;
/* gpu_ref = */ marr_funcs->cpu_set_dsm_at(gpu_mat_arr, ds_mat->getNbRow(), ds_mat->getNbCol(), (@GM_SCALAR@*) reinterpret_cast<@GM_REINTERPRET_CAST_SCALAR@*>(ds_mat->getData()), id);
// gpu_ref is not recorded because this is an assignment, so the pointers don't change
