Commit da72b2f4 authored by hhakim's avatar hhakim
Add commit sha in cdash build name.
parent c7156e7e
Pipeline #846809 canceled
...@@ -27,11 +27,12 @@ ...@@ -27,11 +27,12 @@
## If not, see <http://www.gnu.org/licenses/>. ## ## If not, see <http://www.gnu.org/licenses/>. ##
## Contacts: ## ## Contacts: ##
## Remi Gribonval : remi.gribonval@inria.fr ##
## Hakim Hadj-Djilani: hakim.hadj-djilani@inria.fr ##
## Nicolas Bellot : nicolas.bellot@inria.fr ## ## Nicolas Bellot : nicolas.bellot@inria.fr ##
## Adrien Leman : adrien.leman@inria.fr ## ## Adrien Leman : adrien.leman@inria.fr ##
## Thomas Gautrais : thomas.gautrais@inria.fr ## ## Thomas Gautrais : thomas.gautrais@inria.fr ##
## Luc Le Magoarou : luc.le-magoarou@inria.fr ## ## Luc Le Magoarou : luc.le-magoarou@inria.fr ##
...@@ -51,4 +52,6 @@ set(CTEST_CUSTOM_MAXIMUM_PASSED_TEST_OUTPUT_SIZE TRUE) ...@@ -51,4 +52,6 @@ set(CTEST_CUSTOM_MAXIMUM_PASSED_TEST_OUTPUT_SIZE TRUE)
set(CTEST_CUSTOM_MAXIMUM_FAILED_TEST_OUTPUT_SIZE TRUE) set(CTEST_CUSTOM_MAXIMUM_FAILED_TEST_OUTPUT_SIZE TRUE)
set(CTEST_CURL_OPTIONS "CURLOPT_SSL_VERIFYPEER_OFF") set(CTEST_CURL_OPTIONS "CURLOPT_SSL_VERIFYPEER_OFF")
if(DEFINED ENV{CI_COMMIT_SHA}) # it doesn't work without DEFINED for env. var.
set(CTEST_BUILD_NAME ${CTEST_BUILD_NAME}-$ENV{CI_COMMIT_SHA})
endif()
