Commit d05f54cc authored by hhakim's avatar hhakim
Fix indicated Python minor version in setup.py and anaconda guide.
parent e1a0b8b9
Pipeline #852436 skipped
...@@ -50,7 +50,7 @@ Within Anaconda you can also create a virtual environment and install pyfaust th ...@@ -50,7 +50,7 @@ Within Anaconda you can also create a virtual environment and install pyfaust th
Create the virtual environment: Create the virtual environment:
conda create -n pyfaust_venv python==3.9 conda create -n pyfaust_venv python==@PY3_VER@
Add conda-forge channel (it is necessary for the pyfaust dependencies): Add conda-forge channel (it is necessary for the pyfaust dependencies):
...@@ -86,7 +86,7 @@ setup( ...@@ -86,7 +86,7 @@ setup(
long_description_content_type='text/markdown', long_description_content_type='text/markdown',
classifiers = [ 'License :: OSI Approved :: BSD License', classifiers = [ 'License :: OSI Approved :: BSD License',
'Programming Language :: Python :: 3', 'Programming Language :: Python :: @PY3_VER@',
@GPU_CUDA_VERSION_PYPI_CLASSIFIER@], @GPU_CUDA_VERSION_PYPI_CLASSIFIER@],
install_requires = [@PYFAUST_PYTHON_REQUIREMENTS_AS_PYLIST@], install_requires = [@PYFAUST_PYTHON_REQUIREMENTS_AS_PYLIST@],
license = "3-clause BSD 2.0", license = "3-clause BSD 2.0",
