GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
cd73786a
cd73786a
2 years ago
hhakim
Downloads
Patches
Add pyfaust.LazyLinearOperator and aslazylinearoperator.
Update related unit tests to use those functions.
013aae0d
2
2 changed files
wrapper/python/pyfaust/lazylinop.py
+99
-8
99 additions, 8 deletions
wrapper/python/pyfaust/tests/TestLazyLinearOp2.py
+9
-8
108 additions
16 deletions
99
8
cd73786a
@@ -716,7 +716,45 @@ def asLazyLinearOp(obj):
<b>See also:</b> pyfaust.rand.
return
LazyLinearOp
create
obj
return
LazyLinearOp2
create_from_op
obj
def
obj
Creates a LazyLinearOp based on the object obj which must be of a linear operator compatible type.
NOTE: obj must support operations and attributes defined in the
LazyLinearOp class.
Any operation not supported would raise an exception at the evaluation
time.
Args:
obj: the root object on which the LazyLinearOp is based (it could
be a numpy array, a scipy matrix, a Faust object or almost any
object that supports the same kind of functions).
Returns:
a LazyLinearOp instance based on obj.
Example:
from
pyfaust.lazylinop
import
asLazyLinearOp
import
numpy
as
np
np
random
rand
10
12
lM
azlazylinearoperator
twolM
lM
lM
twolM
pyfaust
lazylinop
LazyLinearOp
at
0x7fcd7d7750f0
import
pyfaust
as
pf
F
pf
rand
10
12
lF
F
twolF
lF
lF
twolF
pyfaust
lazylinop
LazyLinearOp
at
0x7fcd7d774730
return
LazyLinearOp2
create_from_op
obj
def
hstack
tup
def
hstack
tup
@@ -912,7 +950,7 @@ class LazyLinearOp2(LinearOperator):
Warning: This code is in a beta status.
def
__init__
self
lambdas
shape
root_obj
def
__init__
self
lambdas
shape
root_obj
dtype
None
Constructor. Not meant to be used directly.
@@ -936,7 +974,7 @@ class LazyLinearOp2(LinearOperator):
self
shape
shape
self
shape
shape
self
_root_obj
root_obj
#TODO: delete because it can't always be
self
_root_obj
root_obj
# defined (create_from_funcs and hybrid operations)
self
dtype
Non
e
self
dtype
dtyp
e
super
LazyLinearOp2
self
__init__
self
dtype
self
shape
super
LazyLinearOp2
self
__init__
self
dtype
self
shape
def
_check_lambdas
self
def
_check_lambdas
self
@@ -987,10 +1025,10 @@ class LazyLinearOp2(LinearOperator):
l
T
None
l
T
None
l
H
None
l
H
None
l
slice
None
l
slice
None
lop
LazyLinearOp2
lambdas
obj
shape
obj
lop
LazyLinearOp2
lambdas
obj
shape
obj
dtype
obj
dtype
lopT
LazyLinearOp2
lambdasT
obj
shape
obj
shape
obj
lopT
LazyLinearOp2
lambdasT
obj
shape
obj
shape
obj
dtype
obj
dtype
lopH
LazyLinearOp2
lambdasH
obj
shape
obj
shape
obj
lopH
LazyLinearOp2
lambdasH
obj
shape
obj
shape
obj
dtype
obj
dtype
lopC
LazyLinearOp2
lambdasC
obj
shape
obj
shape
obj
lopC
LazyLinearOp2
lambdasC
obj
shape
obj
shape
obj
dtype
obj
dtype
# TODO: refactor with create_from_funcs (in ctor)
lambdas
T
lambda
lopT
lambdas
T
lambda
lopT
@@ -1015,7 +1053,7 @@ class LazyLinearOp2(LinearOperator):
return
create_from_op
a
return
create_from_op
a
@staticmethod
@staticmethod
def
create_from_funcs
matmat
rmatmat
shape
def
create_from_funcs
matmat
rmatmat
shape
dtype
None
from
scipy.sparse
import
eye
as
seye
from
scipy.sparse
import
eye
as
seye
#MX = lambda X: matmat(np.eye(shape[1])) @ X
@@ -1722,3 +1760,56 @@ class LazyLinearOp2(LinearOperator):
if
not
all
issubclass
t
LazyLinearOp
for
t
in
types
if
not
all
issubclass
t
LazyLinearOp
for
t
in
types
return
NotImplemented
return
NotImplemented
return
HANDLED_FUNCTIONS
func
args
kwargs
return
HANDLED_FUNCTIONS
func
args
kwargs
def
LazyLinearOperator
shape
kwargs
Returns a LazyLinearOp defined by shape and at least matvec.
NOTE: At least a matvec or a matmat function must be passed in kwargs.
Args:
shape: (tuple) dimensions (M, N).
matvec: (callable) returns A * v (v a vector).
rmatvec: (callable) returns A^H * v (v a vector of size N).
matmat: (callable) returns A * V (V a dense matrix of dimensions (N, K)).
rmatmat: (callable) returns A^H * V (V a dense matrix of dimensions (M, K)).
dtype: data type of the matrix (can be None).
matvec
rmatvec
matmat
rmatmat
None
for
i
in
range
4
def
callable_err
k
return
TypeError
k
in kwargs must be a callable/function
for
k
in
kwargs
keys
if
k
dtype
not
callable
kwargs
k
raise
callable_err
k
if
matvec
in
kwargs
keys
matvec
kwargs
matvec
if
rmatvec
in
kwargs
keys
rmatvec
kwargs
rmatvec
if
matmat
in
kwargs
keys
matmat
kwargs
matmat
if
rmatmat
in
kwargs
keys
rmatmat
kwargs
rmatmat
if
dtype
in
kwargs
keys
dtype
kwargs
dtype
else
dtype
None
if
matvec
is
None
matmat
is
None
raise
ValueError
passed in kwargs.
def
_matmat
_matvec
out
np
empty
shape
shape
dtype
dtype
if
dtype
is
not
None
else
dtype
for
i
in
range
shape
out
i
_matvec
i
return
out
if
matmat
is
None
matmat
lambda
_matmat
matvec
if
rmatmat
is
None
rmatvec
is
not
None
rmatmat
lambda
_matmat
rmatvec
return
LazyLinearOp2
create_from_funcs
matmat
rmatmat
shape
dtype
dtype
This diff is collapsed.
9
8
cd73786a
import
unittest
import
unittest
import
pyfaust
as
pf
import
pyfaust
as
pf
from
pyfaust.lazylinop
import
LazyLinearOp2
vstack
hstack
LazyLinearOp2
from
pyfaust.lazylinop
import
LazyLinearOp2
vstack
hstack
LazyLinearOp2
LazyLinearOperator
import
numpy.linalg
as
LA
import
numpy.linalg
as
LA
import
numpy
as
np
import
numpy
as
np
class
TestLazyLinearOpFaust
unittest
TestCase
class
unittest
TestCase
def
setUp
self
def
setUp
self
self
lop
L
azy
L
inear
Op2
create_from_op
pf
rand
10
15
self
lop
asl
azy
l
inear
operator
pf
rand
10
15
self
lopA
self
lop
toarray
self
lopA
self
lop
toarray
self
lop2
L
azy
L
inear
Op2
create_from_op
pf
rand
self
lop
shape
self
lop
shape
self
lop2
asl
azy
l
inear
operator
pf
rand
self
lop
shape
self
lop
shape
self
lop2A
self
lop2
toarray
self
lop2A
self
lop2
toarray
self
lop3
L
azy
L
inear
Op2
create_from_op
pf
rand
self
lop
shape
self
lop
shape
self
lop3
asl
azy
l
inear
operator
pf
rand
self
lop
shape
self
lop
shape
self
lop3A
self
lop3
toarray
self
lop3A
self
lop3
toarray
def
test_shape
self
def
test_shape
self
@@ -234,12 +235,12 @@ class TestLazyLinearOpFFTFunc(TestLazyLinearOpFaust):
from
scipy.fft
import
fft
ifft
from
scipy.fft
import
fft
ifft
# axis = 0 to be consistent with LazyLinearOp2.toarray() which applies
# fft on columns of the matrix, not on the rows (axis=1)
self
lop
LazyLinearOp
2
create_from_funcs
lambda
x
fft
x
axis
self
lop
LazyLinearOp
erator
8
8
matmat
lambda
x
fft
x
axis
lambda
x
8
ifft
x
axis
8
rmatmat
lambda
x
8
ifft
x
axis
self
lopA
self
lop
toarray
self
lopA
self
lop
toarray
self
lop2
L
azy
L
inear
Op2
create_from_op
pf
rand
self
lop
shape
self
lop
shape
self
lop2
asl
azy
l
inear
operator
pf
rand
self
lop
shape
self
lop
shape
self
lop2A
self
lop2
toarray
self
lop2A
self
lop2
toarray
self
lop3
L
azy
L
inear
Op2
create_from_op
pf
rand
self
lop
shape
self
lop
shape
self
lop3
asl
azy
l
inear
operator
pf
rand
self
lop
shape
self
lop
shape
self
lop3A
self
lop3
toarray
self
lop3A
self
lop3
toarray
if
__main__
__name__
if
__main__
__name__
Loading
Save comment
