GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.6.
Show more breadcrumbs
faust group
faust
b311e9a6
b311e9a6
2 years ago
hhakim
Downloads
Patches
Set different error tolerances for each scalar types in MatBSR tests.
c0413055
Branches containing commit
Tags containing commit
misc/test/src/C++/test_MatBSR.cpp.in
+47
-36
47 additions, 36 deletions
47 additions
36 deletions
47
36
b311e9a6
@@ -12,13 +12,24 @@ typedef @TEST_FPP@ FPP;
using namespace std;
using namespace Faust;
double tol()
if(is_same<FPP, complex<double>>::value)
return 1e-4;
else if(is_same<FPP, complex<float>>::value || is_same<FPP,float>::value)
return 1e-3;
else // double
return 1e-6;
void test_fro_norm(const MatBSR<FPP, Cpu>& bmat)
cout << "=== Testing MatBSR::norm:" << std::endl;
auto dmat = bmat.to_dense();
cout << "bsr mat fro-norm:" << bmat.norm() << std::endl;
cout << "dense mat fro-norm:" << dmat.norm() << std::endl;
assert(std::abs(bmat.norm()-dmat.norm()) < 1e-6);
cout << "error:" << std::abs(bmat.norm()-dmat.norm()) << std::endl;
assert(std::abs(bmat.norm()-dmat.norm()) < tol());
cout << "OK." << std::endl;
@@ -28,7 +39,7 @@ void test_1_norm(const MatBSR<FPP, Cpu>& bmat)
cout << "bsr mat fro-normL1:" << bmat.normL1() << std::endl;
cout << "dense mat fro-normL1:" << dmat.normL1() << std::endl;
assert(std::abs(bmat.normL1()-dmat.normL1()) <
1e-6
tol()
@@ -38,7 +49,7 @@ void test_clone(const MatBSR<FPP, Cpu>& bmat)
auto clone = bmat.Clone();
cout << "clone bsr mat fro-norm:" << clone->norm() << std::endl;
assert(std::abs(bmat.norm()-clone->norm()) <
1e-6
tol()
cout << "OK" << std::endl;
@@ -59,19 +70,19 @@ void test_mul_vec(const MatBSR<FPP, Cpu>& bmat)
dmat.multiply(vec_cpy, 'N');
// cout << "ref vec:";vec_cpy.Display(); cout << "norm: " << vec_cpy.norm() << std::endl;
// cout << "test vec:";vec.Display(); cout << "norm: " << vec.norm() << std::endl;
assert(std::abs(vec.norm()-vec_cpy.norm()) <
1e-6
tol()
cout << "MatBSR::multiply(Vect, 'N') OK" << endl;
bmat.multiply(vec_t, 'T');
dmat.multiply(vec_t_cpy, 'T');
// cout << "ref vec_t:";vec_t_cpy.Display(); cout << "norm: " << vec_t_cpy.norm() << std::endl;
// cout << "test vec_t:";vec_t.Display(); cout << "norm: " << vec_t.norm() << std::endl;
assert(std::abs(vec_t.norm()-vec_t_cpy.norm()) <
1e-6
tol()
cout << "MatBSR::multiply(Vect, 'T') OK" << endl;
bmat.multiply(vec_h, 'H');
dmat.multiply(vec_h_cpy, 'H');
// cout << "ref vec:";vec_h_cpy.Display(); cout << "norm: " << vec_h_cpy.norm() << std::endl;
// cout << "test vec_h:";vec_h.Display(); cout << "norm: " << vec_h.norm() << std::endl;
assert(std::abs(vec_h.norm()-vec_h_cpy.norm()) <
1e-6
tol()
cout << "MatBSR::multiply(Vect, 'H') OK" << endl;
cout << "OK" << endl;
@@ -84,7 +95,7 @@ void test_mul_vec2(const MatBSR<FPP, Cpu>& bmat)
Vect<FPP, Cpu> test_vec = bmat.multiply(vec);
Vect<FPP, Cpu> ref_vect = dmat.multiply(vec);
assert(std::abs(test_vec.norm()-ref_vect.norm()) <
1e-6
tol()
delete md;
@@ -99,7 +110,7 @@ void test_mul_dense(const MatBSR<FPP, Cpu>& bmat)
bmat.multiply(rmd_copy, 'N');
assert((*rmd).getNbRow() == rmd_copy.getNbRow() && (*rmd).getNbCol() == rmd_copy.getNbCol());
rmd_copy -= *rmd;
assert(rmd_copy.norm() <
1e-6
tol()
delete rmd;
@@ -118,7 +129,7 @@ void test_mul_dense_transp(const MatBSR<FPP, Cpu>& bmat)
rmd_copy.Display();
rmd_copy -= *rmd;
1e-6
tol()
delete rmd;
@@ -133,7 +144,7 @@ void test_mul_dense_transconj(const MatBSR<FPP, Cpu>& bmat)
bmat.multiply(rmd_copy, 'H');
rmd_copy -= *rmd;
1e-6
tol()
delete rmd;
@@ -152,7 +163,7 @@ void test_mul_sparse(const MatBSR<FPP, Cpu>& bmat)
*rmd = rms;
MatDense<FPP, Cpu> rmd_copy(rms_copy);
rmd_copy -= *rmd;
1e-6
tol()
delete rmd;
@@ -170,7 +181,7 @@ void test_mul_sparse_transp(const MatBSR<FPP, Cpu>& bmat)
*rmd = rms;
rmd_copy -= *rmd;
1e-6
tol()
delete rmd;
@@ -188,7 +199,7 @@ void test_mul_sparse_transconj(const MatBSR<FPP, Cpu>& bmat)
*rmd = rms;
rmd_copy -= *rmd;
1e-6
tol()
delete rmd;
@@ -207,7 +218,7 @@ void test_mul_sparse_right(const MatBSR<FPP, Cpu>& bmat_orig)
// bmat.Display();
assert(bmat.getNbRow() == dmat.getNbRow() && bmat.getNbCol() == dmat.getNbCol());
dmat -= dmat_copy;
assert(dmat.norm() <
1e-6
tol()
delete rmd;
@@ -223,7 +234,7 @@ void test_gemm_NN(const MatBSR<FPP, Cpu>& bmat)
dmat.faust_gemm(*B, C_copy, (*B)(0,0), C_copy(0,0), 'N', 'N');
MatDense<FPP, Cpu> test = *C;
test -= C_copy;
assert(test.norm() <
1e-6
tol()
delete B;
delete C;
@@ -241,7 +252,7 @@ void test_gemm_NT(const MatBSR<FPP, Cpu>& bmat)
dmat.faust_gemm(*B, C_copy, (*B)(0,0), C_copy(0,0), 'N', 'T');
test -= C_copy;
1e-6
tol()
delete B;
delete C;
@@ -258,7 +269,7 @@ void test_gemm_TT(const MatBSR<FPP, Cpu>& bmat)
dmat.faust_gemm(*B, C_copy, (*B)(0,0), C_copy(0,0), 'T', 'T');
test -= C_copy;
1e-6
tol()
delete B;
delete C;
@@ -275,7 +286,7 @@ void test_gemm_HH(const MatBSR<FPP, Cpu>& bmat)
dmat.faust_gemm(*B, C_copy, (*B)(0,0), C_copy(0,0), 'H', 'H');
test -= C_copy;
1e-6
tol()
delete B;
delete C;
@@ -294,7 +305,7 @@ void test_transpose(const MatBSR<FPP, Cpu>& bmat)
test -= dmat;
dmat.print_file("dmat.txt");
bmat_t.to_dense().print_file("bmat_t.txt");
1e-6
tol()
@@ -308,7 +319,7 @@ void test_conjugate(const MatBSR<FPP, Cpu>& bmat)
assert(bmat_c.getNbRow() == dmat.getNbRow() && bmat_c.getNbCol() == dmat.getNbCol());
MatDense<FPP, Cpu> test = bmat_c.to_dense();
test -= dmat;
1e-6
tol()
@@ -322,7 +333,7 @@ void test_adjoint(const MatBSR<FPP, Cpu>& bmat)
assert(bmat_a.getNbRow() == dmat.getNbRow() && bmat_a.getNbCol() == dmat.getNbCol());
MatDense<FPP, Cpu> test = bmat_a.to_dense();
test -= dmat;
1e-6
tol()
@@ -360,7 +371,7 @@ void test_mul_scal(const MatBSR<FPP, Cpu>& bmat)
bmat_copy *= scal;
MatDense<FPP, Cpu> test(dmat);
test -= bmat_copy.to_dense();
1e-6
tol()
delete rmd;
@@ -379,7 +390,7 @@ void test_get_col(const MatBSR<FPP, Cpu>& bmat)
bcol = bmat.get_col(j);
test = dcol;
test -= bcol;
1e-6
tol()
@@ -405,7 +416,7 @@ void test_get_cols(const MatBSR<FPP, Cpu>& bmat)
test -= MatDense<FPP, Cpu>(*bcols);
delete dcols;
delete bcols;
1e-6
tol()
@@ -430,7 +441,7 @@ void test_get_rows(const MatBSR<FPP, Cpu>& bmat)
test -= MatDense<FPP, Cpu>(*brows);
delete drows;
delete brows;
1e-6
tol()
@@ -459,7 +470,7 @@ void test_get_cols2(const MatBSR<FPP, Cpu>& bmat)
delete dcols;
delete bcols;
delete []col_ids;
1e-6
tol()
@@ -488,7 +499,7 @@ void test_get_rows2(const MatBSR<FPP, Cpu>& bmat)
delete drows;
delete brows;
delete []row_ids;
1e-6
tol()
@@ -555,13 +566,13 @@ void test_getitem(const MatBSR<FPP, Cpu>& bmat)
cout << "=== Testing MatBSR::operator(int,int)" << endl;
assert(abs(dmat.norm()-bmat.norm()) <
1e-6
tol()
for(int i=0;i < bmat.getNbRow();i++)
for(int j=0;j < bmat.getNbCol();j++)
// cout << dmat(i,j) << "==" << bmat(i,j) <<" ?" << endl;
assert(abs(dmat(i,j)-bmat(i,j)) <
1e-6
tol()
@@ -575,7 +586,7 @@ void test_tosparse(const MatBSR<FPP, Cpu>& bmat)
test -= dmat;
cout << test.norm() << endl;
1e-6
tol()
@@ -615,7 +626,7 @@ void test_faust()
std::cout << "Faust with dense matrix time: " << elapsed_seconds.count() << "s\n";
cout << endl;
toarray_ref -= toarray;
assert(toarray_ref.norm() <
1e-6
tol()
MatSparse<FPP, Cpu> *rand_smat = new MatSparse<FPP, Cpu>(*rand_dmat);
F->replace(rand_smat, rep_id);
F->display();
@@ -679,7 +690,7 @@ void test_faust2()
elapsed_seconds = end-start;
auto test = bsr_prod;
test -= ds_prod;
assert(test.norm()/bsr_prod.norm() <
1e-6
tol()
std::cout << "Dense Faust-dense matrix mul time: " << elapsed_seconds.count() << "s\n";
/**************** test prod by mat_sparse */
auto mat_sparse = MatDense<FPP, Cpu>::randMat(faust_nrows, faust_ncols, .02);
@@ -705,7 +716,7 @@ void test_faust2()
test = bsr_prod;
test -= ds_prod;
1e-6
tol()
std::cout << "Dense Faust-sparse matrix mul time: " << elapsed_seconds.count() << "s\n";
delete mat_sparse;
@@ -757,13 +768,13 @@ int main(int argc, char** argv)
test_mul_sparse_transp(*bmat);
test_mul_sparse_transconj(*bmat);
test_mul_sparse_right(*bmat);
test_transpose(*bmat);
test_conjugate(*bmat);
test_adjoint(*bmat);
test_gemm_NN(*bmat);
test_gemm_NT(*bmat);
test_gemm_TT(*bmat);
test_gemm_HH(*bmat);
test_nnz(*bmat);
test_nbytes(*bmat);
test_get_type(*bmat);
This diff is collapsed.
Loading
Save comment
