GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
992ba784
992ba784
6 years ago
hhakim
Downloads
Patches
Re-enable the slicing test using negative step thanks to
e6faabc8
It should resolve the regression issue #11.
1fc6e6d6
misc/test/src/Matlab/test_matlab_faust.m
+7
-8
7 additions, 8 deletions
7 additions
8 deletions
7
8
992ba784
@@ -675,16 +675,15 @@ if (full(F_slice_slice_2) ~= full(F_dense))
error
'F(1:dim1,1:dim2) ~= F_dense'
%TODO: re-enable later when negative step will be implemented
%F_inv=F(dim1:-1:1,dim2:-1:1);
%if (size(F_inv,1) ~= dim1) | (size(F_inv,2) ~= dim2)
% error('invalid dimension');
%end
F_inv
F
dim1
dim2
if
size
F_inv
dim1
size
F_inv
2
dim2
error
'invalid dimension'
if (F_inv ~= F_dense(dim1:-1:1,dim2:-1:1))
error('F(1:dim1,1:dim2) ~= F_dense(dim1:-1:1,dim2:-1:1)');
if
full
F_inv
full
F_dense
dim1
dim2
error
%% operator end with slicing
This diff is collapsed.
Loading
Save comment
