Commit 8a03e5ea authored by hhakim's avatar hhakim
Fix two bugs related to the recent refactoring of matfaust.
Faust.complex was errored because of factors variable which is now a function.
FaustTest has errors due to the same reason and because of rand function conflicts between matfaust and matlab builtin.
parent ed5f50cf
......@@ -446,7 +446,6 @@ classdef FaustTest < matlab.unittest.TestCase
this.verifyEqual(norm(full_test_F), norm(ref), 'RelTol', 10^-2)
disp('test plus(Faust1,Faust2)')
import matfaust.FaustFactory
fausts = {matfaust.rand(5,size(F,1))*Faust(rand(size(F,1),size(F,2))), matfaust.rand(5,size(F,1), .5, 'complex')*Faust(rand(size(F,1),size(F,2)))}
for i=1:length(fausts)
......@@ -467,7 +466,6 @@ classdef FaustTest < matlab.unittest.TestCase
this.verifyEqual(full_test_F, ref, 'RelTol', 10^-2)
disp('test minus(Faust1,Faust2)')
fausts = {matfaust.rand(5,size(F,1))*Faust(rand(size(F,1),size(F,2)))} %, matfaust.rand(5,size(F,1), .5, 'complex')*rand(size(F,2),size(F,2))} %TODO: re-enable complex Faust when #72 is solved
......@@ -477,7 +475,6 @@ classdef FaustTest < matlab.unittest.TestCase
function testcat(this)
import matfaust.rand
disp('Test cat')
FAUST=0;
......@@ -503,6 +500,7 @@ classdef FaustTest < matlab.unittest.TestCase
H_facs{i} = factors(G, i);
H_facs
H = Faust(H_facs);
if(typeG == SPARSE)
H_ = sparse(full(H));
......@@ -1913,17 +1913,17 @@ classdef Faust
cF = F;
else
n = numfactors(F);
factors = cell(1,n);
facs = cell(1,n);
for i=1:n
factors{i} = factors(F,i);
if(issparse(factors{i}))
facs{i} = factors(F,i);
if(issparse(facs{i}))
% avoid complex() error: Input A must be numeric and full.
factors{i} = sparse(complex(full(factors{i})));
facs{i} = sparse(complex(full(facs{i})));
else
factors{i} = complex(factors{i});
facs{i} = complex(facs{i});
cF = matfaust.Faust(factors);
cF = matfaust.Faust(facs);
