Commit 808ae0a6 authored by hhakim's avatar hhakim
Optimize eval_slice/fancy_idx_Transform() by removing in-heap arrays and fix...
Optimize eval_slice/fancy_idx_Transform() by removing in-heap arrays and fix by the way a bug introduced/revealed by 66166131.
The bug was that when size <= 2 gen_facs arrays could have negative or zero size.
parent cdf824f6
Loading
