Commit 7d36c31c authored by hhakim's avatar hhakim
Avoid building the the python wrapper shared lib again if it already exists...
Avoid building the the python wrapper shared lib again if it already exists (it must be asked explicitely)
It completes a414c959.
parent c241f731
...@@ -2,6 +2,7 @@ ...@@ -2,6 +2,7 @@
# @PYFAUST_LICENSE_HEADER@ # @PYFAUST_LICENSE_HEADER@
from setuptools import setup, Extension from setuptools import setup, Extension
import sysconfig
#from distutils.core import setup, Extension #from distutils.core import setup, Extension
from Cython.Build import cythonize from Cython.Build import cythonize
import numpy import numpy
...@@ -40,6 +41,11 @@ elif platform == 'darwin': ...@@ -40,6 +41,11 @@ elif platform == 'darwin':
elif platform == 'win32': elif platform == 'win32':
lib_ext = 'dll' lib_ext = 'dll'
lib_path = "_FaustCorePy"+sysconfig.get_config_vars()['EXT_SUFFIX']
from os.path import exists, dirname, join
if sys.argv[1] == "build_ext" and exists(join(dirname(sys.argv[0]),lib_path)):
print("The shared library", lib_path, "already exists, please delete it to build again.")
exit(0)
PyFaust = Extension('_FaustCorePy', PyFaust = Extension('_FaustCorePy',
sources = @PY_EXT_SOURCES@, sources = @PY_EXT_SOURCES@,
...@@ -79,3 +85,5 @@ setup( ...@@ -79,3 +85,5 @@ setup(
'pyfaust': [ 'data/*.mat', 'license*.txt', 'lib/*.'+lib_ext] 'pyfaust': [ 'data/*.mat', 'license*.txt', 'lib/*.'+lib_ext]
