Commit 7bb78ee5 authored by hhakim's avatar hhakim
Clean the code of complex type uses when floating type actually needed: norms,...
Clean the code of complex type uses when floating type actually needed: norms, step size and lambda for PALM algorithms.
A template alias Real<FPP> has been added in this purpose in faust_constant.h.in
Fix in spectralNorm for complex matrices, use the adjoint matrix instead of transpose to compute the eigenvalue.
parent 62b1c2e7
with 302 additions and 302 deletions
Loading
