Commit 7ab8672c authored by hhakim's avatar hhakim
Add permutation argument to C++ butterfly_hierarchical.
parent 90fb1aa7
...@@ -49,7 +49,7 @@ namespace Faust ...@@ -49,7 +49,7 @@ namespace Faust
Faust::TransformHelper<FPP, Cpu>* butterfly_hierarchical_balanced(const Faust::MatDense<FPP, Cpu>& A, const std::vector<Faust::MatSparse<FPP, Cpu>*> &supports, FactMeth meth = LIFTING); Faust::TransformHelper<FPP, Cpu>* butterfly_hierarchical_balanced(const Faust::MatDense<FPP, Cpu>& A, const std::vector<Faust::MatSparse<FPP, Cpu>*> &supports, FactMeth meth = LIFTING);
template<typename FPP> template<typename FPP>
Faust::TransformHelper<FPP, Cpu>* butterfly_hierarchical(const Faust::MatDense<FPP, Cpu>& A, const ButterflyFactDir &dir=RIGHT); Faust::TransformHelper<FPP, Cpu>* butterfly_hierarchical(const Faust::MatDense<FPP, Cpu>& A, const ButterflyFactDir &dir=RIGHT, const Faust::MatSparse<FPP, Cpu>* P=nullptr);
...@@ -349,7 +349,7 @@ namespace Faust ...@@ -349,7 +349,7 @@ namespace Faust
bit_reversal_factor(nfactors, out); bit_reversal_factor(nfactors, out);
else else
out.push_back(P); out.push_back(P); // the caller is responsible to delete the matrix P
return out; return out;
...@@ -663,14 +663,14 @@ namespace Faust ...@@ -663,14 +663,14 @@ namespace Faust
Faust::TransformHelper<FPP, Cpu>* butterfly_hierarchical(const Faust::MatDense<FPP, Cpu>& A, const ButterflyFactDir &dir/*=RIGHT*/) Faust::TransformHelper<FPP, Cpu>* butterfly_hierarchical(const Faust::MatDense<FPP, Cpu>& A, const ButterflyFactDir &dir/*=RIGHT*/, Faust::MatSparse<FPP, Cpu>* P/*=nullptr*/)
double log2_size = log2((double)A.getNbRow()); double log2_size = log2((double)A.getNbRow());
if(A.getNbRow() != A.getNbCol()) if(A.getNbRow() != A.getNbCol())
throw std::runtime_error("The matrix to factorize must be square."); throw std::runtime_error("The matrix to factorize must be square.");
if(log2_size - int(log2_size) > std::numeric_limits<Real<FPP>>::epsilon()) if(log2_size - int(log2_size) > std::numeric_limits<Real<FPP>>::epsilon())
throw std::runtime_error("The matrix to factorize must be of a size equal to a power of two."); throw std::runtime_error("The matrix to factorize must be of a size equal to a power of two.");
auto support = butterfly_support<FPP>((int) log2_size); auto support = butterfly_support<FPP>((int) log2_size, P);
// std::cout << "support norms" << std::endl; // std::cout << "support norms" << std::endl;
// for(auto s: support) // for(auto s: support)
// std::cout << s->norm() << std::endl; // std::cout << s->norm() << std::endl;
...@@ -679,8 +679,8 @@ namespace Faust ...@@ -679,8 +679,8 @@ namespace Faust
th = butterfly_hierarchical_balanced(A, support); th = butterfly_hierarchical_balanced(A, support);
else else
th = butterfly_hierarchical(A, support, dir); th = butterfly_hierarchical(A, support, dir);
for(auto s: support) for(int i = 0; i < (P == nullptr?support.size():support.size()-1);i++)
delete s; delete support[i];
return th; return th;
