Commit 719455b5 authored by hhakim's avatar hhakim
Add unit tests for MatButterfly getType and operator*=(FPP) + refactor equality tests in functions.
parent 722728d9
...@@ -7,6 +7,21 @@ typedef @TEST_FPP@ FPP; ...@@ -7,6 +7,21 @@ typedef @TEST_FPP@ FPP;
using namespace Faust; using namespace Faust;
using namespace std; using namespace std;
bool verifyVecEq(Vect<FPP, Cpu> refv, Vect<FPP, Cpu> testv, double tol)
auto err = refv;
err -= testv;
return err.norm() <= 1e-6;
bool verifyMatEq(MatDense<FPP, Cpu> refm, MatDense<FPP, Cpu> testm, double tol)
auto err = refm;
err -= testm;
void testClone(MatButterfly<FPP, Cpu>& butterflyMat) void testClone(MatButterfly<FPP, Cpu>& butterflyMat)
auto size = butterflyMat.getNbRow(); auto size = butterflyMat.getNbRow();
...@@ -18,10 +33,7 @@ void testClone(MatButterfly<FPP, Cpu>& butterflyMat) ...@@ -18,10 +33,7 @@ void testClone(MatButterfly<FPP, Cpu>& butterflyMat)
butterflyMat.multiply(refY_, 'N'); butterflyMat.multiply(refY_, 'N');
clone->multiply(testY_, 'N'); clone->multiply(testY_, 'N');
assert(verifyMatEq(refY_, testY_, 1e-6));
auto errY_ = testY_;
errY_ -= refY_;
assert(errY_.norm() <= 1e-6);
std::cout << "MatButterfly cloning OK" << std::endl; std::cout << "MatButterfly cloning OK" << std::endl;
delete X; delete X;
...@@ -111,6 +123,38 @@ void testNNZSize(MatButterfly<FPP, Cpu>& butterflyMat, MatSparse<FPP, Cpu>& spBu ...@@ -111,6 +123,38 @@ void testNNZSize(MatButterfly<FPP, Cpu>& butterflyMat, MatSparse<FPP, Cpu>& spBu
std::cout << "MatButterfly getNonZeros() and getNBytes() OK" << std::endl; std::cout << "MatButterfly getNonZeros() and getNBytes() OK" << std::endl;
void testType(MatButterfly<FPP, Cpu>& butterflyMat)
assert(butterflyMat.getType() == Butterfly);
std::cout << "MatButterfly getType() OK" << std::endl;
void testScalMul(const MatButterfly<FPP, Cpu>& butterflyMat, const MatSparse<FPP, Cpu>& spButterflyMat)
auto size = spButterflyMat.getNbRow();
auto X = MatDense<FPP, Cpu>::randMat(size, size);
auto alpha = FPP(2.0);
MatButterfly<FPP, Cpu> mButterflyMat(butterflyMat);
MatSparse<FPP, Cpu> mspButterflyMat(spButterflyMat);
mButterflyMat *= alpha;
mspButterflyMat *= alpha;
Vect<FPP, Cpu> refy(X->getNbRow(), X->getData());
Vect<FPP, Cpu> testy(X->getNbRow(), X->getData());
mButterflyMat.multiply(refy, 'N');
mspButterflyMat.multiply(testy, 'N');
assert(verifyVecEq(refy, testy, 1e-6));
delete X;
std::cout << "MatButterfly scal. mul OK" << std::endl;
int main(int argc, char** argv) int main(int argc, char** argv)
int log2size = 4; int log2size = 4;
...@@ -148,7 +192,6 @@ int main(int argc, char** argv) ...@@ -148,7 +192,6 @@ int main(int argc, char** argv)
spButterflyMat.multiply(refY, 'N'); spButterflyMat.multiply(refY, 'N');
butterflyMat.multiply(testY, 'N'); butterflyMat.multiply(testY, 'N');
auto errY = testY; auto errY = testY;
errY -= refY; errY -= refY;
assert(errY.norm() <= 1e-6); assert(errY.norm() <= 1e-6);
...@@ -174,7 +217,8 @@ int main(int argc, char** argv) ...@@ -174,7 +217,8 @@ int main(int argc, char** argv)
testTranspose(butterflyMat, spButterflyMat); testTranspose(butterflyMat, spButterflyMat);
testNNZSize(butterflyMat, spButterflyMat); testNNZSize(butterflyMat, spButterflyMat);
testType(butterflyMat);
testScalMul(butterflyMat, spButterflyMat);
return EXIT_SUCCESS; return EXIT_SUCCESS;
