Commit 6ab7ab4f authored by hhakim's avatar hhakim
Refactor data URL and filename into variables.
parent 4de04228
variables:
# variables defining where to find the FAµST external data
# used by package build scripts
DURL: "https://gforge.inria.fr/frs/download.php/file/37960"
DFILE: "faust_data-2.4.2.zip"
.ctest_template: &ctest_script .ctest_template: &ctest_script
script: script:
- ctest -O ctest.log -S ./CDashConfScript.cmake - ctest -O ctest.log -S ./CDashConfScript.cmake
...@@ -67,7 +73,7 @@ package_macos: ...@@ -67,7 +73,7 @@ package_macos:
script: script:
- SHA_START=$(echo $CI_COMMIT_SHA | sed -e 's/^\(.\{8\}\).*/\1/') - SHA_START=$(echo $CI_COMMIT_SHA | sed -e 's/^\(.\{8\}\).*/\1/')
- if [[ ! -d 'build' ]]; then mkdir build;fi; cd build - if [[ ! -d 'build' ]]; then mkdir build;fi; cd build
- 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=ON -DBUILD_DOCUMENTATION=ON -DCPACK_PACKAGE_VERSION=$SHA_START -DCMAKE_INSTALL_PREFIX=/opt/local/faust-$SHA_START -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="https://gforge.inria.fr/frs/download.php/file/37960" -DREMOTE_DATA_FILE="faust_data-2.4.2.zip" ..' - 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=ON -DBUILD_DOCUMENTATION=ON -DCPACK_PACKAGE_VERSION=$SHA_START -DCMAKE_INSTALL_PREFIX=/opt/local/faust-$SHA_START -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" ..'
- make LANG=en_GB.UTF-8 - make LANG=en_GB.UTF-8
- 'echo $MACOS_PASS | sudo -S make install' - 'echo $MACOS_PASS | sudo -S make install'
#- 'echo $MACOS_PASS | sudo -S hdiutil create -volname Faust-$SHA_START-MatlabR2016a-Py2.7 -srcfolder /opt/local/faust-$SHA_START -ov -format UDRW faust-$SHA_START' #- 'echo $MACOS_PASS | sudo -S hdiutil create -volname Faust-$SHA_START-MatlabR2016a-Py2.7 -srcfolder /opt/local/faust-$SHA_START -ov -format UDRW faust-$SHA_START'
...@@ -98,7 +104,7 @@ package_win: ...@@ -98,7 +104,7 @@ package_win:
- 'set SHA_START=%CI_COMMIT_SHA:~0,8%' - 'set SHA_START=%CI_COMMIT_SHA:~0,8%'
- if NOT EXIST build (mkdir build) else rmdir /S /Q build - if NOT EXIST build (mkdir build) else rmdir /S /Q build
- cd build - cd build
- 'cmake -G "MinGW Makefiles" -DBUILD_WRAPPER_MATLAB=ON -DBUILD_WRAPPER_PYTHON=ON -DSLOW_TESTS=OFF -DCPACK_PACKAGE_VERSION=%SHA_START% -DBUILD_DOCUMENTATION=ON -DEXCLUDE_FAUST_LIB_INSTALL=ON -DCMAKE_INSTALL_PREFIX=win_pkg_build -DBUILD_TESTING=OFF -DAPI_DOC_BASE_URL="file:///C:/Program Files/Faust/doc/" -DREMOTE_DATA_URL="https://gforge.inria.fr/frs/download.php/file/37960" -DREMOTE_DATA_FILE="faust_data-2.4.2.zip" ..' - 'cmake -G "MinGW Makefiles" -DBUILD_WRAPPER_MATLAB=ON -DBUILD_WRAPPER_PYTHON=ON -DSLOW_TESTS=OFF -DCPACK_PACKAGE_VERSION=%SHA_START% -DBUILD_DOCUMENTATION=ON -DEXCLUDE_FAUST_LIB_INSTALL=ON -DCMAKE_INSTALL_PREFIX=win_pkg_build -DBUILD_TESTING=OFF -DAPI_DOC_BASE_URL="file:///C:/Program Files/Faust/doc/" -DREMOTE_DATA_URL="%DURL%" -DREMOTE_DATA_FILE="%DFILE%" ..'
- make - make
- makensis faust.nsi - makensis faust.nsi
artifacts: artifacts:
...@@ -116,7 +122,7 @@ package_linux: ...@@ -116,7 +122,7 @@ package_linux:
script: script:
- 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=ON -DBUILD_DOCUMENTATION=ON -DCMAKE_INSTALL_PREFIX=/opt/local/faust-$SHA_START -DCPACK_PACKAGE_FILE_NAME=faust-$SHA_START -DCPACK_PACKAGE_VERSION=$SHA_START -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="https://gforge.inria.fr/frs/download.php/file/37960" -DREMOTE_DATA_FILE="faust_data-2.4.2.zip" ..' - 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=ON -DBUILD_DOCUMENTATION=ON -DCMAKE_INSTALL_PREFIX=/opt/local/faust-$SHA_START -DCPACK_PACKAGE_FILE_NAME=faust-$SHA_START -DCPACK_PACKAGE_VERSION=$SHA_START -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" ..'
- make - make
- cpack -G RPM -C CPackConfig.cmake - cpack -G RPM -C CPackConfig.cmake
- cpack -G DEB -C CPackConfig.cmake - cpack -G DEB -C CPackConfig.cmake
...@@ -140,7 +146,7 @@ package_linux: ...@@ -140,7 +146,7 @@ package_linux:
package_macos_release: package_macos_release:
script: script:
- 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=ON -DBUILD_DOCUMENTATION=ON -DCMAKE_INSTALL_PREFIX=/opt/local/faust -DCPACK_PACKAGE_VERSION=$CI_COMMIT_TAG -DCMAKE_BUILD_TYPE=Release -DEXCLUDE_FAUST_LIB_INSTALL=ON -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="https://gforge.inria.fr/frs/download.php/file/37960" -DREMOTE_DATA_FILE="faust_data-2.4.2.zip" ..' - 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=ON -DBUILD_DOCUMENTATION=ON -DCMAKE_INSTALL_PREFIX=/opt/local/faust -DCPACK_PACKAGE_VERSION=$CI_COMMIT_TAG -DCMAKE_BUILD_TYPE=Release -DEXCLUDE_FAUST_LIB_INSTALL=ON -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" ..'
- 'echo $MACOS_PASS | sudo -S hdiutil create -volname Faust-$CI_COMMIT_TAG-MatlabR2016a-Py2.7 -srcfolder /opt/local/faust -ov -format UDRW faust-$CI_COMMIT_TAG' - 'echo $MACOS_PASS | sudo -S hdiutil create -volname Faust-$CI_COMMIT_TAG-MatlabR2016a-Py2.7 -srcfolder /opt/local/faust -ov -format UDRW faust-$CI_COMMIT_TAG'
...@@ -167,7 +173,7 @@ package_win_release: ...@@ -167,7 +173,7 @@ package_win_release:
script: script:
- 'cmake -G "MinGW Makefiles" -DBUILD_WRAPPER_MATLAB=ON -DBUILD_WRAPPER_PYTHON=ON -DSLOW_TESTS=OFF -DCPACK_PACKAGE_VERSION=%CI_COMMIT_TAG% -DBUILD_DOCUMENTATION=ON -DEXCLUDE_FAUST_LIB_INSTALL=ON -DCMAKE_INSTALL_PREFIX=win_pkg_build -DBUILD_TESTING=OFF -DAPI_DOC_BASE_URL="file:///C:/Program Files/Faust/doc/" -DREMOTE_DATA_URL="https://gforge.inria.fr/frs/download.php/file/37960" -DREMOTE_DATA_FILE="faust_data-2.4.2.zip" ..' - 'cmake -G "MinGW Makefiles" -DBUILD_WRAPPER_MATLAB=ON -DBUILD_WRAPPER_PYTHON=ON -DSLOW_TESTS=OFF -DCPACK_PACKAGE_VERSION=%CI_COMMIT_TAG% -DBUILD_DOCUMENTATION=ON -DEXCLUDE_FAUST_LIB_INSTALL=ON -DCMAKE_INSTALL_PREFIX=win_pkg_build -DBUILD_TESTING=OFF -DAPI_DOC_BASE_URL="file:///C:/Program Files/Faust/doc/" -DREMOTE_DATA_URL="%DURL%" -DREMOTE_DATA_FILE="%DFILE%" ..'
- make - make
...@@ -182,7 +188,7 @@ package_win_release: ...@@ -182,7 +188,7 @@ package_win_release:
package_linux_release: package_linux_release:
script: script:
- 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=ON -DBUILD_DOCUMENTATION=ON -DCMAKE_INSTALL_PREFIX=/opt/local/faust -DCPACK_PACKAGE_FILE_NAME=faust-$CI_COMMIT_TAG -DCPACK_PACKAGE_VERSION=$CI_COMMIT_TAG -DEXCLUDE_FAUST_LIB_INSTALL=ON -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="https://gforge.inria.fr/frs/download.php/file/37960" -DREMOTE_DATA_FILE="faust_data-2.4.2.zip" ..' - 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=ON -DBUILD_DOCUMENTATION=ON -DCMAKE_INSTALL_PREFIX=/opt/local/faust -DCPACK_PACKAGE_FILE_NAME=faust-$CI_COMMIT_TAG -DCPACK_PACKAGE_VERSION=$CI_COMMIT_TAG -DEXCLUDE_FAUST_LIB_INSTALL=ON -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" ..'
- make - make
...@@ -203,7 +209,7 @@ package_linux_release: ...@@ -203,7 +209,7 @@ package_linux_release:
package_linux_release_static: package_linux_release_static:
script: script:
- 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=ON -DBUILD_DOCUMENTATION=ON -DCMAKE_INSTALL_PREFIX=/opt/local/faust -DCPACK_PACKAGE_FILE_NAME=faust-$CI_COMMIT_TAG-static -DCPACK_PACKAGE_VERSION=$CI_COMMIT_TAG -DEXCLUDE_FAUST_LIB_INSTALL=ON -DUSE_MATIO_STATIC_LIBS=ON -DMATIO_STATIC_LIB_PATH=/opt/local/matio-1.5.7/src/.libs/libmatio.a -DZ_STATIC_LIB_PATH=/opt/local/zlib-1.2.11/libz.a -DHDF5_STATIC_LIB_PATH=/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="https://gforge.inria.fr/frs/download.php/file/37960" -DREMOTE_DATA_FILE="faust_data-2.4.2.zip" ..' - 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=ON -DBUILD_DOCUMENTATION=ON -DCMAKE_INSTALL_PREFIX=/opt/local/faust -DCPACK_PACKAGE_FILE_NAME=faust-$CI_COMMIT_TAG-static -DCPACK_PACKAGE_VERSION=$CI_COMMIT_TAG -DEXCLUDE_FAUST_LIB_INSTALL=ON -DUSE_MATIO_STATIC_LIBS=ON -DMATIO_STATIC_LIB_PATH=/opt/local/matio-1.5.7/src/.libs/libmatio.a -DZ_STATIC_LIB_PATH=/opt/local/zlib-1.2.11/libz.a -DHDF5_STATIC_LIB_PATH=/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a -DBUILD_TESTING=OFF -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" ..'
- make - make
...@@ -241,7 +247,7 @@ pages: ...@@ -241,7 +247,7 @@ pages:
.package_purepy: &package_purepy .package_purepy: &package_purepy
script: script:
- 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=OFF -DBUILD_DOCUMENTATION=ON -DCPACK_PACKAGE_VERSION=$VERSION -DCMAKE_INSTALL_PREFIX=/opt/local/faust-$SHA_START -DBUILD_TESTING=OFF -DEXCLUDE_FAUST_LIB_INSTALL=ON -DUSE_MATIO_STATIC_LIBS=ON -DMATIO_STATIC_LIB_PATH=$MATIO_STATIC_LIB_PATH -DZ_STATIC_LIB_PATH=$Z_STATIC_LIB_PATH -DHDF5_STATIC_LIB_PATH=$HDF5_STATIC_LIB_PATH -DREMOTE_DATA_URL="https://gforge.inria.fr/frs/download.php/file/37960" -DREMOTE_DATA_FILE="faust_data-2.4.2.zip" ..' - 'cmake -DBUILD_WRAPPER_PYTHON=ON -DBUILD_WRAPPER_MATLAB=OFF -DBUILD_DOCUMENTATION=ON -DCPACK_PACKAGE_VERSION=$VERSION -DCMAKE_INSTALL_PREFIX=/opt/local/faust-$SHA_START -DBUILD_TESTING=OFF -DEXCLUDE_FAUST_LIB_INSTALL=ON -DUSE_MATIO_STATIC_LIBS=ON -DMATIO_STATIC_LIB_PATH=$MATIO_STATIC_LIB_PATH -DZ_STATIC_LIB_PATH=$Z_STATIC_LIB_PATH -DHDF5_STATIC_LIB_PATH=$HDF5_STATIC_LIB_PATH -DREMOTE_DATA_URL="$DURL" -DREMOTE_DATA_FILE="$DFILE" ..'
- make - make
- cd wrapper/python - cd wrapper/python
- python3 setup.py bdist_wheel - python3 setup.py bdist_wheel
...@@ -308,7 +314,7 @@ package_linux_purepy_release: ...@@ -308,7 +314,7 @@ package_linux_purepy_release:
script: script:
- 'cmake -G "Visual Studio 14 2015" -DBUILD_WRAPPER_MATLAB=OFF -DBUILD_WRAPPER_PYTHON=ON -DSLOW_TESTS=OFF -DCPACK_PACKAGE_VERSION=%VERSION% -DCMAKE_INSTALL_PREFIX=win_pkg_build -DBUILD_TESTING=OFF -DUSE_MATIO_STATIC_LIBS=ON -DMATIO_STATIC_LIB_PATH="C:/Users/faust/Downloads/matio-1.5.13/visual_studio/x64/Release/libmatio.lib" -DZ_STATIC_LIB_PATH="C:/Users/faust/Downloads/zlib-1.2.11/contrib/vstudio/vc14/x64/ZlibStatDebug/zlibstat.lib" -DHDF5_STATIC_LIB_PATH="C:/Users/faust/Downloads/hdf5-1.10.3/build/bin/Release/libhdf5.lib" -DREMOTE_DATA_URL="https://gforge.inria.fr/frs/download.php/file/37960" -DREMOTE_DATA_FILE="faust_data-2.4.2.zip" ..' - 'cmake -G "Visual Studio 14 2015" -DBUILD_WRAPPER_MATLAB=OFF -DBUILD_WRAPPER_PYTHON=ON -DSLOW_TESTS=OFF -DCPACK_PACKAGE_VERSION=%VERSION% -DCMAKE_INSTALL_PREFIX=win_pkg_build -DBUILD_TESTING=OFF -DUSE_MATIO_STATIC_LIBS=ON -DMATIO_STATIC_LIB_PATH="C:/Users/faust/Downloads/matio-1.5.13/visual_studio/x64/Release/libmatio.lib" -DZ_STATIC_LIB_PATH="C:/Users/faust/Downloads/zlib-1.2.11/contrib/vstudio/vc14/x64/ZlibStatDebug/zlibstat.lib" -DHDF5_STATIC_LIB_PATH="C:/Users/faust/Downloads/hdf5-1.10.3/build/bin/Release/libhdf5.lib" -DREMOTE_DATA_URL="%DURL%" -DREMOTE_DATA_FILE="%DFILE%" ..'
#- make #- make
- cmake --build . --target FAUST - cmake --build . --target FAUST
