GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.6.
Show more breadcrumbs
faust group
faust
66646f53
66646f53
2 years ago
hhakim
Downloads
Patches
Correct variable name for the matio static lib path in linux pip package jobs.
7ecc3dda
.gitlab-ci.yml
+4
-4
4 additions, 4 deletions
.gitlab-ci.yml
4 additions
4 deletions
.gitlab-ci.yml
4
4
66646f53
@@ -434,14 +434,14 @@ pkg_macos_purepy_release_torch_linked:
pkg_linux_purepy_release
extends
.pkg_purepy_release
variables
GIT_SUBMODULE_STRATEGY
recursive
MATIO_STATIC_LIB_PATH
$LINUX_
ZLIB
_SLIB_PATH
Z_STATIC_LIB_PATH
$LINUX_ZLIB_SLIB_PATH
HDF5_STATIC_LIB_PATH
$LINUX_HDF5_SLIB_PATH
BUILD_MULTITHREAD
ON"
NOPY2
ON"
USE_GPU_MOD
ON"
CMAKE_PREFIX_PATH
../gpu_mod"
FAUST_TORCH
OFF"
EXPERIMENTAL_PKG
OFF"
CMAKE_CXX_COMPILER
clang++"
PYTHON_PATH
/usr/local/bin/python3.9'
JOB_PYTHON
python3.9'
variables
recursive
$LINUX_
MATIO
_SLIB_PATH
Z_STATIC_LIB_PATH
BUILD_MULTITHREAD
ON"
NOPY2
ON"
USE_GPU_MOD
ON"
CMAKE_PREFIX_PATH
../gpu_mod"
FAUST_TORCH
OFF"
EXPERIMENTAL_PKG
OFF"
CMAKE_CXX_COMPILER
clang++"
PYTHON_PATH
JOB_PYTHON
python3.9'
tags
linux
tux_packager
pkg_linux_purepy_release_extra_pyver
extends
.pkg_purepy_release
variables
recursive
$LINUX_
ZLIB
_SLIB_PATH
Z_STATIC_LIB_PATH
BUILD_MULTITHREAD
ON"
NOPY2
ON"
USE_GPU_MOD
ON"
CMAKE_PREFIX_PATH
../gpu_mod"
FAUST_TORCH
OFF"
EXPERIMENTAL_PKG
OFF"
PYTHON_PATH
/usr/local/bin/python3.10'
JOB_PYTHON
python3.10'
CMAKE_CXX_COMPILER
clang++"
variables
recursive
$LINUX_
MATIO
_SLIB_PATH
Z_STATIC_LIB_PATH
BUILD_MULTITHREAD
ON"
NOPY2
ON"
USE_GPU_MOD
ON"
CMAKE_PREFIX_PATH
../gpu_mod"
FAUST_TORCH
OFF"
EXPERIMENTAL_PKG
OFF"
PYTHON_PATH
JOB_PYTHON
python3.10'
CMAKE_CXX_COMPILER
clang++"
tags
linux
tux_packager
@@ -449,13 +449,13 @@ pkg_linux_purepy_release_extra_pyver:
.pkg_linux_purepy_release_torch_linked
extends
variables
recursive
$LINUX_
ZLIB
_SLIB_PATH
Z_STATIC_LIB_PATH
BUILD_MULTITHREAD
ON"
NOPY2
ON"
FAUST_TORCH
ON"
USE_GPU_MOD
ON"
CMAKE_PREFIX_PATH
/opt/local/libtorch/share/cmake/Torch;../gpu_mod"
EXPERIMENTAL_PKG
OFF"
CMAKE_CXX_COMPILER
clang++"
variables
recursive
$LINUX_
MATIO
_SLIB_PATH
Z_STATIC_LIB_PATH
BUILD_MULTITHREAD
ON"
NOPY2
ON"
FAUST_TORCH
ON"
USE_GPU_MOD
ON"
CMAKE_PREFIX_PATH
EXPERIMENTAL_PKG
OFF"
CMAKE_CXX_COMPILER
clang++"
tags
torch
pkg_linux_purepy_release_openblaso
extends
.pkg_purepy_release
variables
recursive
$LINUX_
ZLIB
_SLIB_PATH
Z_STATIC_LIB_PATH
BUILD_MULTITHREAD
ON"
NOPY2
ON"
USE_GPU_MOD
ON"
CMAKE_PREFIX_PATH
../gpu_mod"
FAUST_TORCH
OFF"
EXPERIMENTAL_PKG
OFF"
CMAKE_CXX_COMPILER
clang++"
USE_OPENBLASO
ON"
PYTHON_PATH
JOB_PYTHON
python3.9'
variables
recursive
$LINUX_
MATIO
_SLIB_PATH
Z_STATIC_LIB_PATH
BUILD_MULTITHREAD
ON"
NOPY2
ON"
USE_GPU_MOD
ON"
CMAKE_PREFIX_PATH
../gpu_mod"
FAUST_TORCH
OFF"
EXPERIMENTAL_PKG
OFF"
CMAKE_CXX_COMPILER
clang++"
USE_OPENBLASO
ON"
PYTHON_PATH
JOB_PYTHON
python3.9'
tags
linux
tux_packager
This diff is collapsed.
Loading
Save comment
