Commit 45dab9b3 authored by hhakim's avatar hhakim
Add pyfaust.Faust.insert/replace.
parent 75493775
Pipeline #849510 passed
......@@ -2385,6 +2385,71 @@ class Faust(numpy.lib.mixins.NDArrayOperatorsMixin):
return lF.factors(0)
return lF
def replace(F, i, new_factor):
Replaces factor of index i by new_factor in a new Faust copy of F.
NOTE: this is not a true copy, only references to pre-existed factors
are copied.
Args:
i: (int)
The factor index to replace.
new_factor: (a numpy array or a scipy matrix)
The factor replacing the i-th factor of F.
Returns:
a copy of F with the i-th factor replaced by new_factor.
Example:
>>> import numpy as np
>>> import pyfaust as pf
>>> from scipy.sparse import random
>>> F = pf.rand(10, 10, num_factors=5)
>>> S = random(10, 10, .2)
>>> G = F.replace(2, S)
>>> np.allclose((F.left(1) @ pf.Faust(S) @ F.right(3)).toarray(), G.toarray())
True
\see :py:func:`Faust.factors`, :py:func:`Faust.left`, :py:func:`Faust.right`, :py:func:`Faust.insert`
F._check_factor_idx(i)
return F.left(i-1, as_faust=True) @ Faust(new_factor) @ F.right(i+1,
as_faust=True)
def insert(F, i, new_factor):
Inserts new_factor at index i in a new Faust copy of F.
are copied.
Args:
i: (int)
The index of insertion.
The factor to insert as the i-th factor of F.
Returns:
a copy of F with the i-th factor being new_factor.
Example:
>>> import numpy as np
>>> G = F.insert(2, S)
>>> np.allclose((F.left(1) @ pf.Faust(S) @ F.right(2)).toarray(), G.toarray())
True
\see :py:func:`Faust.factors`, :py:func:`Faust.left`, :py:func:`Faust.right`, :py:func:`Faust.replace`
return F.left(i-1, as_faust=True) @ Faust(new_factor) @ F.right(i,
as_faust=True)
def _check_factor_idx(F, i):
if not np.isscalar(i) or not np.isreal(i):
raise TypeError('i must be an integer.')
