Commit 456e82fc authored by hhakim's avatar hhakim
Fix missing link in lazylinop jupyter notebook.
parent 71b4aedb
Tags 3.35.7
Pipeline #834133 skipped
...@@ -14165,7 +14165,7 @@ lF shape after concatenation: (8192, 4096) ...@@ -14165,7 +14165,7 @@ lF shape after concatenation: (8192, 4096)
<div class="jp-Cell-inputWrapper"><div class="jp-InputPrompt jp-InputArea-prompt"> <div class="jp-Cell-inputWrapper"><div class="jp-InputPrompt jp-InputArea-prompt">
</div><div class="jp-RenderedHTMLCommon jp-RenderedMarkdown jp-MarkdownOutput " data-mime-type="text/markdown"> </div><div class="jp-RenderedHTMLCommon jp-RenderedMarkdown jp-MarkdownOutput " data-mime-type="text/markdown">
<p>Note that we know the shape of the resulting <code>LazyLinearOp</code> without the need to evaluate it.</p> <p>Note that we know the shape of the resulting <code>LazyLinearOp</code> without the need to evaluate it.</p>
<p>For a tour of all supported operations on <code>LazyLinearOp</code> objects please take a look at : <a href="TODO">link</a>.</p> <p>For a tour of all supported operations on <code>LazyLinearOp</code> objects please take a look at : <a href="LazyLinearOp reference">https://faustgrp.gitlabpages.inria.fr/faust/last-doc/html/classpyfaust_1_1lazylinop_1_1LazyLinearOp.html</a>.</p>
</div> </div>
</div> </div>
%% Cell type:markdown id: tags: %% Cell type:markdown id: tags:
# Using LazyLinearOp-s # Using LazyLinearOp-s
The ``LazyLinearOp`` class is a kind of linear operator (indeed, it extends the scipy [LinearOperator](https://docs.scipy.org/doc/scipy/reference/generated/scipy.sparse.linalg.LinearOperator.html) class) for which the operations you make are delayed until you choose to evaluate them. The ``LazyLinearOp`` class is a kind of linear operator (indeed, it extends the scipy [LinearOperator](https://docs.scipy.org/doc/scipy/reference/generated/scipy.sparse.linalg.LinearOperator.html) class) for which the operations you make are delayed until you choose to evaluate them.
This class is intended to lower the computational cost in situations where many operations are made on linear operators but eventually not all of them will be used / evaluated. This class is intended to lower the computational cost in situations where many operations are made on linear operators but eventually not all of them will be used / evaluated.
Theoretically, it might also be useful to distribute the calculations around many computation units. Theoretically, it might also be useful to distribute the calculations around many computation units.
In this notebook we shall see how to create a ``LazyLinearOp`` instance, make operations on it and finally how to evaluate it to get the real result of these operations. We assume the reader is familiar with at least numpy arrays and their operations. In this notebook we shall see how to create a ``LazyLinearOp`` instance, make operations on it and finally how to evaluate it to get the real result of these operations. We assume the reader is familiar with at least numpy arrays and their operations.
### 1. Creating a LazyLinearOp ### 1. Creating a LazyLinearOp
In order to create this kind of object, you simply need to use the ``asLazyLinearOp`` function. This function receives an object that represents a linear operator, for instance a ``Faust`` (but it can also be a numpy array or a scipy matrix). The function instantiates a ``LazyLinearOp`` that encapsulates the ``Faust`` you gave. In order to create this kind of object, you simply need to use the ``asLazyLinearOp`` function. This function receives an object that represents a linear operator, for instance a ``Faust`` (but it can also be a numpy array or a scipy matrix). The function instantiates a ``LazyLinearOp`` that encapsulates the ``Faust`` you gave.
%% Cell type:code id: tags: %% Cell type:code id: tags:
``` python ``` python
from pyfaust.lazylinop import asLazyLinearOp from pyfaust.lazylinop import asLazyLinearOp
import pyfaust as pf import pyfaust as pf
# create a random Faust # create a random Faust
F = pf.rand(4096, 4096, density=.001) F = pf.rand(4096, 4096, density=.001)
# create a LazyLinearOp upon it # create a LazyLinearOp upon it
lF = asLazyLinearOp(F) lF = asLazyLinearOp(F)
print(lF) print(lF)
As said earlier, it is also possible to create a ``LazyLinearOp`` upon numpy arrays or scipy matrices. As said earlier, it is also possible to create a ``LazyLinearOp`` upon numpy arrays or scipy matrices.
from scipy.sparse import random from scipy.sparse import random
from numpy.random import rand from numpy.random import rand
S = random(4096, 4096, .2, format='csr') # scipy matrix S = random(4096, 4096, .2, format='csr') # scipy matrix
lS = asLazyLinearOp(S) lS = asLazyLinearOp(S)
M = rand(4096, 4096)*1j # numpy complex array M = rand(4096, 4096)*1j # numpy complex array
lM = asLazyLinearOp(M) lM = asLazyLinearOp(M)
Then we can start to do some operations on these new objects. For example, let's multiply ``lF`` by a scalar: Then we can start to do some operations on these new objects. For example, let's multiply ``lF`` by a scalar:
lF = 2 * lF lF = 2 * lF
print(lF) print(lF)
As you can see it stays a ``LazyLinearOp`` after the scalar multiplication. That's the principle of the lazy evaluation we talked about at the beginning of this notebook. No operation is really computed, only the track of the operations asked is kept in a new LazyLinearOp object. As you can see it stays a ``LazyLinearOp`` after the scalar multiplication. That's the principle of the lazy evaluation we talked about at the beginning of this notebook. No operation is really computed, only the track of the operations asked is kept in a new LazyLinearOp object.
Let's continue asking other operations. For example, a matrix multiplication and then a concatenation. Let's continue asking other operations. For example, a matrix multiplication and then a concatenation.
import pyfaust.lazylinop as lp import pyfaust.lazylinop as lp
lFs = lF @ lF lFs = lF @ lF
print("lF shape before concatenation:", lFs.shape) print("lF shape before concatenation:", lFs.shape)
lFc = lp.vstack((lFs, lFs)) lFc = lp.vstack((lFs, lFs))
print("lF shape after concatenation:", lFc.shape) print("lF shape after concatenation:", lFc.shape)
Note that we know the shape of the resulting LazyLinearOp without the need to evaluate it. Note that we know the shape of the resulting LazyLinearOp without the need to evaluate it.
Let's try other operations with ``lM`` and ``lS``, all ``LazyLinearOp`` are compatible with each other. Let's try other operations with ``lM`` and ``lS``, all ``LazyLinearOp`` are compatible with each other.
lMSF = (2 * lM.conj().T + lS) @ lFc[:4096, :] lMSF = (2 * lM.conj().T + lS) @ lFc[:4096, :]
# then get back the imaginary part of the LazyLinearOp # then get back the imaginary part of the LazyLinearOp
lMSF_imag = lMSF.imag lMSF_imag = lMSF.imag
Note that we know the shape of the resulting ``LazyLinearOp`` without the need to evaluate it. Note that we know the shape of the resulting ``LazyLinearOp`` without the need to evaluate it.
For a tour of all supported operations on ``LazyLinearOp`` objects please take a look at : [link](TODO). For a tour of all supported operations on ``LazyLinearOp`` objects please take a look at : [LazyLinearOp reference](https://faustgrp.gitlabpages.inria.fr/faust/last-doc/html/classpyfaust_1_1lazylinop_1_1LazyLinearOp.html).
### 2. Evaluating a LazyLinearOp ### 2. Evaluating a LazyLinearOp
Now that we've seen how to create and operate a ``LazyLinearOp`` let's see how to get the evaluation done, that is obtaining the real results of our operations. Now that we've seen how to create and operate a ``LazyLinearOp`` let's see how to get the evaluation done, that is obtaining the real results of our operations.
There are several ways to get these results. The most important way is to multiply the ``LazyLinearOp`` by a dense matrix (a numpy array) or a vector. There are several ways to get these results. The most important way is to multiply the ``LazyLinearOp`` by a dense matrix (a numpy array) or a vector.
import numpy as np import numpy as np
lMSF_imag@np.random.rand(4096) lMSF_imag@np.random.rand(4096)
The other ways to evaluate is to call ``LazyLinearOp.eval`` or ``LazyLinearOp.toarray`` on our object. The former function returns an object whose type depends on the operations made so far on the starting object. The latter function returns always a numpy array which is the result of the same operations. The other ways to evaluate is to call ``LazyLinearOp.eval`` or ``LazyLinearOp.toarray`` on our object. The former function returns an object whose type depends on the operations made so far on the starting object. The latter function returns always a numpy array which is the result of the same operations.
### 3. Checking the computation times ### 3. Checking the computation times
As a last step in this notebook, we shall verify how much computation time it takes to use a ``LazyLinearOperator`` compared to a numpy array. Of course it depends on the underlying objects used behind (in the operations encoded in the ``LazyLinearOperator``). Here we make the measurement on ``lFs`` which was initialized before upon a Faust object. As a last step in this notebook, we shall verify how much computation time it takes to use a ``LazyLinearOperator`` compared to a numpy array. Of course it depends on the underlying objects used behind (in the operations encoded in the ``LazyLinearOperator``). Here we make the measurement on ``lFs`` which was initialized before upon a Faust object.
%timeit lFs@M %timeit lFs@M
%timeit lFs.toarray() %timeit lFs.toarray()
FD = lFs.toarray() # FD is a numpy array FD = lFs.toarray() # FD is a numpy array
%timeit FD@M %timeit FD@M
print("consistent results:", np.allclose(lFs@M, FD@M)) print("consistent results:", np.allclose(lFs@M, FD@M))
Great! As excepted ``lFs`` is faster than its numpy array counterpart ``FD``. Great! As excepted ``lFs`` is faster than its numpy array counterpart ``FD``.
This notebook comes to its end. We've seen quickly how to create and evaluate a ``LazyLinearOp`` objects based on a Faust object, numpy array or scipy matrices. For more information about ``LazyLinearOp`` objects you can take a look to the API documentation [here](TODO). This notebook comes to its end. We've seen quickly how to create and evaluate a ``LazyLinearOp`` objects based on a Faust object, numpy array or scipy matrices. For more information about ``LazyLinearOp`` objects you can take a look to the API documentation [here](TODO).
**NOTE**: this notebook was executed using the pyfaust version: **NOTE**: this notebook was executed using the pyfaust version:
pf.version() pf.version()
