Commit 41a2f966 authored by hhakim's avatar hhakim
Fix hierarchicalFactorization_double/float C++ test (lambda value).
parent 3c2fc13b
......@@ -308,7 +308,7 @@ if(NOT NOCPPTESTS)
foreach(TEST_FPP float double)
add_test(NAME MATFILE_FACT_HADAMARD_${TEST_FPP} COMMAND ${FAUST_BIN_TEST_BIN_DIR}/hierarchicalFactorization_${TEST_FPP} ${FAUST_DATA_MAT_DIR}/matrix_HADAMARD_32.mat ${FAUST_CONFIG_MAT_DIR}/config_HADAMARD_32.mat 5930 30)
add_test(NAME MATFILE_FACT_HIER_${TEST_FPP} COMMAND ${FAUST_BIN_TEST_BIN_DIR}/hierarchicalFactorization_${TEST_FPP} ${FAUST_DATA_MAT_DIR}/matrix_hierarchical_fact.mat ${FAUST_CONFIG_MAT_DIR}/config_hierarchical_fact.mat 9407.8 0.1)
add_test(NAME MATFILE_FACT_HIER_${TEST_FPP} COMMAND ${FAUST_BIN_TEST_BIN_DIR}/hierarchicalFactorization_${TEST_FPP} ${FAUST_DATA_MAT_DIR}/matrix_hierarchical_fact.mat ${FAUST_CONFIG_MAT_DIR}/config_hierarchical_fact.mat 10196.6 0.1)
add_test(NAME MATFILE_MULTIPLICATION_MEG_${TEST_FPP} COMMAND ${FAUST_BIN_TEST_BIN_DIR}/faust_multiplication_${TEST_FPP} ${FAUST_DATA_MAT_DIR}/matrix_MEG.mat T ${FAUST_DATA_MAT_DIR}/faust_MEG_rcg_6.mat ${FAUST_DATA_MAT_DIR}/faust_MEG_rcg_8.mat ${FAUST_DATA_MAT_DIR}/faust_MEG_rcg_16.mat ${FAUST_DATA_MAT_DIR}/faust_MEG_rcg_25.mat)
