Commit 37374535 authored by hhakim's avatar hhakim
Remove empty definitions of multiply() in MatGeneric and replace by virtual pure function members.
parent c28e7c3b
...@@ -104,7 +104,7 @@ namespace Faust ...@@ -104,7 +104,7 @@ namespace Faust
//! \param opThis : character //! \param opThis : character
//! vec = (*this) * vec if opThis='N' //! vec = (*this) * vec if opThis='N'
// vec = (*this)' * vec if opThis='T' // vec = (*this)' * vec if opThis='T'
virtual void multiply(Faust::Vect<FPP,DEVICE> & vec, char opThis='N') const; virtual void multiply(Faust::Vect<FPP,DEVICE> & vec, char opThis='N') const=0;
//! \brief compute MatGeneric-MatDense multiplication //! \brief compute MatGeneric-MatDense multiplication
...@@ -112,7 +112,7 @@ namespace Faust ...@@ -112,7 +112,7 @@ namespace Faust
//! M = (*this) * M if opThis='N' //! M = (*this) * M if opThis='N'
// M = (*this)' * M if opThis='T' // M = (*this)' * M if opThis='T'
virtual void multiply(Faust::MatDense<FPP,DEVICE> & M, char opThis) const; virtual void multiply(Faust::MatDense<FPP,DEVICE> & M, char opThis) const=0;
...@@ -127,19 +127,6 @@ Faust::MatGeneric<FPP,DEVICE>::~MatGeneric() ...@@ -127,19 +127,6 @@ Faust::MatGeneric<FPP,DEVICE>::~MatGeneric()
template<typename FPP,Device DEVICE>
void Faust::MatGeneric<FPP,DEVICE>::multiply(Faust::Vect<FPP,DEVICE> & vec, char opThis) const
handleError("Faust::MatGeneric::","multiply (Vect): this function should not be called");
void Faust::MatGeneric<FPP,DEVICE>::multiply(Faust::MatDense<FPP,DEVICE> & vec, char opThis) const
handleError("Faust::MatGeneric::","multiply (MatDense): this function should not be called");
template<typename FPP,Device DEVICE> template<typename FPP,Device DEVICE>
void Faust::MatGeneric<FPP,DEVICE>::Display() const void Faust::MatGeneric<FPP,DEVICE>::Display() const
