Commit 2f8bda26 authored by hhakim's avatar hhakim
Replace truncated SVD by a rank-1 approximation using power iteration in butterfly solveDTO.
Try also to parallelize the approximation with OpenMP but it was'nt conclusive (already in a OpenMP parallelized loop).
parent 606e0789
...@@ -105,6 +105,7 @@ namespace Faust ...@@ -105,6 +105,7 @@ namespace Faust
retrieveCEC(s1, s2, cec, noncec); retrieveCEC(s1, s2, cec, noncec);
for(auto ce: cec) for(auto ce: cec)
// Faust::MatDense<FPP, Cpu> submat;
auto r = (*ce)[0]; auto r = (*ce)[0];
auto RP = s1.col_nonzero_inds(r); auto RP = s1.col_nonzero_inds(r);
auto CP = s2.row_nonzero_inds(r); auto CP = s2.row_nonzero_inds(r);
...@@ -150,14 +151,22 @@ namespace Faust ...@@ -150,14 +151,22 @@ namespace Faust
// #pragma omp parallel for // Tested but non-efficient because of solveDTO already parallelized
// for(int i=0;i<noncec.size();i++)
// Faust::MatDense<FPP, Cpu> submat, bestx, besty;
// auto ce = noncec[i];
for(auto ce: noncec) for(auto ce: noncec)
A.submatrix(RP, CP, submat); A.submatrix(RP, CP, submat);
#ifdef BUTTERFLY_TUNCATED_SVD
submat.best_low_rank(ce->size(), bestx, besty); submat.best_low_rank(ce->size(), bestx, besty);
//TODO: OpenMP ? #else
submat.approx_rank1(bestx, besty);
#endif
for(int i=0;i< ce->size();i++) for(int i=0;i< ce->size();i++)
...@@ -350,9 +359,9 @@ namespace Faust ...@@ -350,9 +359,9 @@ namespace Faust
for(size_t i=0;i<d-1;i++) for(size_t i=0;i<d-1;i++)
next_lvl_facs.resize(tree_supports[i+1].size()); next_lvl_facs.resize(tree_supports[i+1].size());
size_t j_bound = std::min(tree_supports[i].size(), tree_supports[i+1].size()/2); int j_bound = std::min(tree_supports[i].size(), tree_supports[i+1].size()/2);
#pragma omp parallel for schedule(static) #pragma omp parallel for schedule(static)
for(size_t j=0;j < j_bound;j++) for(int j=0;j < j_bound;j++)
solveDTO(input_facs[j], tree_supports[i+1][2*j], tree_supports[i+1][2*j+1], next_lvl_facs[j*2], next_lvl_facs[j*2+1]); solveDTO(input_facs[j], tree_supports[i+1][2*j], tree_supports[i+1][2*j+1], next_lvl_facs[j*2], next_lvl_facs[j*2+1]);
if(i < d - 2) if(i < d - 2)
