Commit 202eebc3 authored by hhakim's avatar hhakim
Add the c++ function TransformHelperButterfly::opt_faust to optimize any Faust...
Add the c++ function TransformHelperButterfly::opt_faust to optimize any Faust with butterfly factors.
parent f233c202
...@@ -34,6 +34,7 @@ namespace Faust ...@@ -34,6 +34,7 @@ namespace Faust
using VecMap = Eigen::Map<Eigen::Matrix<FPP, Eigen::Dynamic, 1>>; using VecMap = Eigen::Map<Eigen::Matrix<FPP, Eigen::Dynamic, 1>>;
using DiagMat = Eigen::DiagonalMatrix<FPP, Eigen::Dynamic>; using DiagMat = Eigen::DiagonalMatrix<FPP, Eigen::Dynamic>;
bool has_permutation;
FPP *perm_d_ptr; FPP *perm_d_ptr;
DiagMat D; DiagMat D;
std::vector<unsigned int> bitrev_perm; std::vector<unsigned int> bitrev_perm;
...@@ -52,6 +53,7 @@ namespace Faust ...@@ -52,6 +53,7 @@ namespace Faust
MatDense<FPP, Cpu> multiply(const MatDense<FPP,Cpu> &A); MatDense<FPP, Cpu> multiply(const MatDense<FPP,Cpu> &A);
MatDense<FPP, Cpu> multiply(const MatSparse<FPP,Cpu> &A); MatDense<FPP, Cpu> multiply(const MatSparse<FPP,Cpu> &A);
static TransformHelper<FPP,Cpu>* fourierFaust(unsigned int n, const bool norma=true); static TransformHelper<FPP,Cpu>* fourierFaust(unsigned int n, const bool norma=true);
static TransformHelper<FPP, Cpu>* optFaust(const TransformHelper<FPP, Cpu>* F);
#include <cmath>
namespace Faust namespace Faust
...@@ -6,26 +7,33 @@ namespace Faust ...@@ -6,26 +7,33 @@ namespace Faust
int i = 0; int i = 0;
auto size = this->getNbRow(); auto size = this->getNbRow();
D.resize(size);
// for(auto csr_fac: facts) // for(auto csr_fac: facts)
// use rather recorded factors in the Faust::Transform because one might have been multiplied with lambda_ // use rather recorded factors in the Faust::Transform because one might have been multiplied with lambda_
for(auto csr_fac_it = this->begin(); csr_fac_it != this->end(); csr_fac_it++) auto log2nf = 1 << (this->size() - 1);
has_permutation = (log2nf - this->getNbRow()) == 0;
auto end_it = has_permutation?this->end()-1:this->end();
for(auto csr_fac_it = this->begin(); csr_fac_it != end_it; csr_fac_it++)
auto csr_fac = *csr_fac_it; auto csr_fac = *csr_fac_it;
if(i < facts.size()-1) opt_factors.insert(opt_factors.begin(), ButterflyMat<FPP>(*dynamic_cast<const MatSparse<FPP, Cpu>*>(csr_fac), i++));
opt_factors.insert(opt_factors.begin(), ButterflyMat<FPP>(*dynamic_cast<const MatSparse<FPP, Cpu>*>(csr_fac), i++)); }
if(has_permutation)
// set the permutation factor
auto csr_fac = *(this->end()-1);
D.resize(size);
perm_d_ptr = D.diagonal().data();
// only a setOnes should be enough because this is a permutation matrix (but it could be normalized)
memcpy(perm_d_ptr, dynamic_cast<const MatSparse<FPP, Cpu>*>(csr_fac)->getValuePtr(), size*sizeof(FPP));
// auto bitrev_perm_ids = new unsigned int[size];
// iota(bitrev_perm_ids, bitrev_perm_ids+size, 0);
// bit_rev_permu(facts.size()-1, bitrev_perm_ids);
bitrev_perm.resize(size);
// copy(bitrev_perm_ids, bitrev_perm_ids+size, bitrev_perm.begin());
// delete[] bitrev_perm_ids;
//TODO: rename bitrev_perm to something generic (this class is not limited to the FFT)
copy(dynamic_cast<const MatSparse<FPP, Cpu>*>(csr_fac)->getColInd(), dynamic_cast<const MatSparse<FPP, Cpu>*>(csr_fac)->getColInd()+size, bitrev_perm.begin());
template<typename FPP> template<typename FPP>
...@@ -39,7 +47,6 @@ namespace Faust ...@@ -39,7 +47,6 @@ namespace Faust
fft_factors(n, factors); fft_factors(n, factors);
FPP alpha = norma?FPP(1/sqrt((double)(1 << n))):FPP(1.0); FPP alpha = norma?FPP(1/sqrt((double)(1 << n))):FPP(1.0);
fourierFaust = new TransformHelperButterfly<FPP, Cpu>(factors, alpha, false, false, /* internal call */ true); fourierFaust = new TransformHelperButterfly<FPP, Cpu>(factors, alpha, false, false, /* internal call */ true);
catch(std::bad_alloc e) catch(std::bad_alloc e)
...@@ -49,6 +56,17 @@ namespace Faust ...@@ -49,6 +56,17 @@ namespace Faust
TransformHelper<FPP, Cpu>* TransformHelperButterfly<FPP,Cpu>::optFaust(const TransformHelper<FPP, Cpu>* F)
//TODO: verify a few assertions to detect if F factors do not match a butterfly structure
std::vector<MatGeneric<FPP,Cpu>*> factors(F->size());
copy(F->begin(), F->end(), factors.begin());
auto oF = new TransformHelperButterfly<FPP, Cpu>(factors, FPP(1.0), false, false, /* internal call */ true);
return oF;
Vect<FPP, Cpu> TransformHelperButterfly<FPP,Cpu>::multiply(const Vect<FPP, Cpu>& x) Vect<FPP, Cpu> TransformHelperButterfly<FPP,Cpu>::multiply(const Vect<FPP, Cpu>& x)
...@@ -62,34 +80,45 @@ namespace Faust ...@@ -62,34 +80,45 @@ namespace Faust
VecMap x_vec(const_cast<FPP*>(x), size); // const_cast is harmless VecMap x_vec(const_cast<FPP*>(x), size); // const_cast is harmless
VecMap y_vec(y, size); Vect<FPP, Cpu> z(size);
if(x == y) int i = 0;
if(has_permutation)
// an intermediate vector is needed to index x VecMap y_vec(y, size);
auto x_ = new FPP[size]; if(x == y)
#pragma omp parallel for {
for(int i=0;i < size; i++) // an intermediate vector is needed to index x
x_[i] = x[bitrev_perm[i]]; auto x_ = new FPP[size];
#pragma omp parallel for #pragma omp parallel for
for(int i=0;i < size; i++) for(int i=0;i < size; i++)
y[i] = perm_d_ptr[i] * x_[i]; x_[i] = x[bitrev_perm[i]];
delete[] x_; #pragma omp parallel for
} for(int i=0;i < size; i++)
else y[i] = perm_d_ptr[i] * x_[i];
delete[] x_;
else
#define BUTTERFLY_MUL_VEC_OMP_LOOP #define BUTTERFLY_MUL_VEC_OMP_LOOP
#ifdef BUTTERFLY_MUL_VEC_OMP_LOOP #ifdef BUTTERFLY_MUL_VEC_OMP_LOOP
// faster // faster
for(int i=0;i < this->getNbRow(); i++) for(int i=0;i < this->getNbRow(); i++)
y[i] = perm_d_ptr[i] * x[bitrev_perm[i]]; y[i] = perm_d_ptr[i] * x[bitrev_perm[i]];
#else #else
y_vec = D * x_vec(bitrev_perm); y_vec = D * x_vec(bitrev_perm);
#endif #endif
else
ButterflyMat<FPP>& fac = opt_factors[0];
fac.multiply(x, z.getData(), this->getNbRow());
i = 1;
Vect<FPP, Cpu> z(size); while(i < opt_factors.size())
int i = 0; // for(auto fac: opt_factors)
ButterflyMat<FPP>& fac = opt_factors[i];
if(i & 1) if(i & 1)
fac.multiply(z.getData(), y, this->getNbRow()); fac.multiply(z.getData(), y, this->getNbRow());
else else
...@@ -113,19 +142,32 @@ namespace Faust ...@@ -113,19 +142,32 @@ namespace Faust
using MatMap = Eigen::Map<Eigen::Matrix<FPP, Eigen::Dynamic, Eigen::Dynamic>>; using MatMap = Eigen::Map<Eigen::Matrix<FPP, Eigen::Dynamic, Eigen::Dynamic>>;
MatMap X_mat(const_cast<FPP*>(X) /* harmless, no modification*/, this->getNbCol(), X_ncols); MatMap X_mat(const_cast<FPP*>(X) /* harmless, no modification*/, this->getNbCol(), X_ncols);
auto Z = new FPP[this->getNbRow()*X_ncols];
int i = 0;
MatMap Y_mat(Y, this->getNbRow(), X_ncols); MatMap Y_mat(Y, this->getNbRow(), X_ncols);
if(has_permutation)
#if defined(BUTTERFLY_MUL_MAT_OMP_LOOP) || ! EIGEN_VERSION_AT_LEAST(3, 4, 0) #if defined(BUTTERFLY_MUL_MAT_OMP_LOOP) || ! EIGEN_VERSION_AT_LEAST(3, 4, 0)
// this is slower // this is slower
#pragma parallel omp for #pragma parallel omp for
for(int i=0;i < this->getNbRow(); i ++) for(int i=0;i < this->getNbRow(); i ++)
Y_mat.row(i) = X_mat.row(bitrev_perm[i]) * perm_d_ptr[i]; Y_mat.row(i) = X_mat.row(bitrev_perm[i]) * perm_d_ptr[i];
#else #else
Y_mat = D * X_mat(bitrev_perm, Eigen::placeholders::all); Y_mat = D * X_mat(bitrev_perm, Eigen::placeholders::all);
#endif #endif
auto Z = new FPP[this->getNbRow()*X_ncols]; }
int i = 0; else
fac.multiply(X, X_mat.cols(), Z, this->getNbRow());
i = 1;
if(i & 1) if(i & 1)
fac.multiply(Z, Y_mat.cols(), Y, this->getNbRow()); fac.multiply(Z, Y_mat.cols(), Y, this->getNbRow());
else else
...@@ -149,21 +191,34 @@ namespace Faust ...@@ -149,21 +191,34 @@ namespace Faust
MatDense<FPP, Cpu> TransformHelperButterfly<FPP,Cpu>::multiply(const MatSparse<FPP,Cpu> &X) MatDense<FPP, Cpu> TransformHelperButterfly<FPP,Cpu>::multiply(const MatSparse<FPP,Cpu> &X)
MatDense<FPP, Cpu> Y(this->getNbRow(), X.getNbCol()); MatDense<FPP, Cpu> Y(this->getNbRow(), X.getNbCol());
#pragma omp parallel for auto Z = new FPP[this->getNbRow()*X.getNbCol()];
for(int i=0;i < this->getNbRow(); i ++) int i = 0;
Y.mat.row(i) = X.mat.row(bitrev_perm[i]) * perm_d_ptr[i]; if(has_permutation)
else
Y = X;
#ifdef FAUST_BUTTERFLY_MULTILPY_SINGLE_BUFFER #ifdef FAUST_BUTTERFLY_MULTILPY_SINGLE_BUFFER
// consume less memory but with more copies // consume less memory but with more copies
for(auto fac: opt_factors) // for(auto fac: opt_factors)
Y = fac.multiply(Y); Y = fac.multiply(Y);
i++;
#else #else
// consume more memory but spare copies (faster if enough memory) // double buffering consumes more memory but spare copies (faster if enough memory)
auto Z = new FPP[this->getNbRow()*X.getNbCol()]; //TODO: factorize with MatDense product
int i = 0; while(i < opt_factors.size())
if(i & 1) if(i & 1)
fac.multiply(Z, Y.mat.cols(), Y.getData(), this->getNbRow()); fac.multiply(Z, Y.mat.cols(), Y.getData(), this->getNbRow());
else else
