Commit 1ea25ea1 authored by hhakim's avatar hhakim
Avoid to exit in matlab postinstall script.
It could block another postinstall script to be executed after.
parent 70f0ac5a
Pipeline #833823 skipped
...@@ -8,10 +8,13 @@ function dirname_noerr { ...@@ -8,10 +8,13 @@ function dirname_noerr {
MATLAB_ROOT=$(dirname_noerr $(dirname_noerr $(which matlab 2>/dev/null))) MATLAB_ROOT=$(dirname_noerr $(dirname_noerr $(which matlab 2>/dev/null)))
[[ ! -d "${MATLAB_ROOT}" ]] && MATLAB_ROOT=$(dirname_noerr $(dirname_noerr $(find /usr/local -maxdepth 10 -type f -name "matlab" | tail -n 1))) [[ ! -d "${MATLAB_ROOT}" ]] && MATLAB_ROOT=$(dirname_noerr $(dirname_noerr $(find /usr/local -maxdepth 10 -type f -name "matlab" | tail -n 1)))
[[ ! -d "${MATLAB_ROOT}" ]] && MATLAB_ROOT=$(dirname_noerr $(dirname_noerr $(find /opt/ -maxdepth 10 -type f -name "matlab" | tail -n 1))) [[ ! -d "${MATLAB_ROOT}" ]] && MATLAB_ROOT=$(dirname_noerr $(dirname_noerr $(find /opt/ -maxdepth 10 -type f -name "matlab" | tail -n 1)))
[[ ! "$?" = 0 || ! -d "${MATLAB_ROOT}" ]] && echo "Can't find Matlab root dir. Add MATLAB_ROOT/bin to the PATH environment variable (of root user)." >&2 && exit 1 if [[ ! "$?" = 0 || ! -d "${MATLAB_ROOT}" ]]
STARTUP_DIR="${MATLAB_ROOT}/toolbox/local/" then
STARTUP_FILE=${STARTUP_DIR}/startup.m echo "Can't find Matlab root dir. Add MATLAB_ROOT/bin to the PATH environment variable (of root user)." >&2
[[ -r "$STARTUP_FILE" ]] && grep -i -v faust "$STARTUP_FILE" > "$STARTUP_FILE" else
FAUST_MATLAB_WRAPPER_PATH="@CMAKE_INSTALL_MATLAB_PREFIX@" STARTUP_DIR="${MATLAB_ROOT}/toolbox/local/"
echo "addpath(genpath('"$FAUST_MATLAB_WRAPPER_PATH"'))" >> "$STARTUP_FILE" STARTUP_FILE=${STARTUP_DIR}/startup.m
fi
#!/bin/bash #!/bin/bash
MATLAB_ROOT=$(find /Applications/ -iname "MATLAB*" -maxdepth 1 | tail -n 1) MATLAB_ROOT=$(find /Applications/ -iname "MATLAB*" -maxdepth 1 | tail -n 1)
[[ ! "$?" = 0 || ! -d "${MATLAB_ROOT}" ]] && echo "Can't find Matlab root dir. Add MATLAB_ROOT/bin to the PATH environment variable (of admin. user)." >&2 && exit 1 if [[ ! "$?" = 0 || ! -d "${MATLAB_ROOT}" ]]
STARTUP_FILE=${STARTUP_DIR}/startup.m echo "Can't find Matlab root dir. Add MATLAB_ROOT/bin to the PATH environment variable (of admin. user)." >&2
echo "addpath(genpath('"$FAUST_MATLAB_WRAPPER_PATH"'))" >> $STARTUP_FILE STARTUP_FILE=${STARTUP_DIR}/startup.m
fi
