Commit 1a919b68 authored by hhakim's avatar hhakim
Add an help function to access mxArray data in FaustMat2mxArray when...
Add an help function to access mxArray data in FaustMat2mxArray when interleaved complex API (R2018a) is enabled (#3).
It fixes issue #238.
parent 1d5cc280
......@@ -139,6 +139,15 @@ void mxArray2Scalar(const mxArray* scalar, typename std::enable_if<std::is_float
template<typename FPP>
void mxArray2Scalar(const mxArray* scalar, complex<FPP>* out);
#ifdef MX_HAS_INTERLEAVED_COMPLEX
* Allow to access to mxMat data as double, float, complex<double>, complex<float> ptr.
* There is no copy (direct access) but the mxArray must match the type asked (otherwise a runtime error is raised).
void newMxGetData(FPP* ptr_out, const mxArray* mxMat);
#endif
#include "faust2Mx.hpp"
#endif
......@@ -87,7 +87,7 @@ mxArray* FaustMat2mxArray(const Faust::MatDense<FPP,DEV>& M)
FPP* ptr_out;
ptr_out = static_cast<FPP*> (mxGetDoubles(mxMat));
newMxGetData(ptr_out, mxMat);
#else
ptr_out = static_cast<FPP*> (mxGetData(mxMat));
#endif
......@@ -99,7 +99,39 @@ mxArray* FaustMat2mxArray(const Faust::MatDense<FPP,DEV>& M)
template<>
void newMxGetData<float>(float* ptr_out, const mxArray* mxMat)
if(mxGetClassID(mxMat) != mxSINGLE_CLASS || mxIsComplex(mxMat))
mexErrMsgTxt("newMxGetData: the mex matrix must be double as the ptr is.");
ptr_out = static_cast<float*> (mxGetSingles(mxMat));
template<>
void newMxGetData<double>(double* ptr_out, const mxArray* mxMat)
if(mxGetClassID(mxMat) != mxDOUBLE_CLASS && mxIsComplex(mxMat))
mexErrMsgTxt("newMxGetData: the mex matrix must be double as the ptr.");
ptr_out = static_cast<double*> (mxGetDoubles(mxMat));
template<>
void newMxGetData<std::complex<double>>(complex<double>* ptr_out, const mxArray* mxMat)
if(mxGetClassID(mxMat) != mxDOUBLE_CLASS || ! mxIsComplex(mxMat))
mexErrMsgTxt("newMxGetData: the mex matrix must be complex double as the ptr.");
ptr_out = reinterpret_cast<std::complex<double>*> (mxGetComplexDoubles(mxMat));
template<>
void newMxGetData<std::complex<float>>(complex<float>* ptr_out, const mxArray* mxMat)
if(mxGetClassID(mxMat) != mxSINGLE_CLASS || ! mxIsComplex(mxMat))
mexErrMsgTxt("newMxGetData: the mex matrix must be complex float as the ptr.");
ptr_out = reinterpret_cast<std::complex<float>*> (mxGetComplexDoubles(mxMat));
#endif
mxArray* FaustMat2mxArray(const Faust::MatDense<std::complex<FPP>,Cpu>& M)
