GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.6.
Show more breadcrumbs
faust group
faust
155f61a4
155f61a4
4 years ago
hhakim
Downloads
Patches
Ignore python2.7 in linux RPM/DEB post-install script (py2.7 is not longer supported).
866be969
misc/binpkg_postinst_scripts/debrpm/postinst_py.sh
+1
-1
1 addition, 1 deletion
1 addition
1 deletion
155f61a4
@@ -47,7 +47,7 @@ function link_py_files(){
# default root PATH is not necessarily including /usr/local/bin (which is very common when python is built manually), so add it to the PATH!
export
PATH
$PATH
:/usr/local/bin
for
V
in
2
3.
$SUPPORTED_PY3
for
V
in
3.
$SUPPORTED_PY3
do
which python
$V
2>&1
/dev/null
link_py_files
$V
done
This diff is collapsed.
Loading
Save comment
