Commit 0b84d70b authored by hhakim's avatar hhakim
Add support of complex matrices in matfaust for the 2020 versions of PALM4MSA...
Add support of complex matrices in matfaust for the 2020 versions of PALM4MSA and hierarchical algorithm (CPU & GPU).
parent 72efe2ae
......@@ -182,7 +182,11 @@ function varargout = hierarchical(M, p, varargin)
[lambda, core_obj] = mexHierarchical2020Real(M, mex_params);
else
error('backend 2020 doesn''t handle yet the complex matrices')
if(gpu)
[lambda, core_obj] = mexHierarchical2020_gpu2Cplx(M, mex_params);
else
[lambda, core_obj] = mexHierarchical2020Cplx(M, mex_params);
F = Faust(core_obj, isreal(M));
......@@ -79,17 +79,22 @@ function [F,lambda] = palm4msa(M, p, varargin)
[lambda, core_obj] = mexPalm4MSACplx(mex_params);
elseif(backend == 2020)
init_faust = matfaust.Faust(p.init_facts);
% no need to keep the ParamsPalm4MSA extracted/generated cell for init_facts
% mex_params = rmfield(mex_params, 'init_facts')
if(isreal(M))
if(gpu)
[lambda, core_obj] = mexPALM4MSA2020_gpu2Real(mex_params, get_handle(init_faust));
else
[lambda, core_obj] = mexPALM4MSA2020Real(mex_params, get_handle(init_faust));
else
init_faust = complex(matfaust.Faust(p.init_facts));
if(gpu)
[lambda, core_obj] = mexPALM4MSA2020_gpu2Cplx(mex_params, get_handle(init_faust));
else
[lambda, core_obj] = mexPALM4MSA2020Cplx(mex_params, get_handle(complex(init_faust)));
......@@ -122,23 +122,24 @@ foreach(SCALAR_AND_FSUFFIX double:Real std::complex<double>:Cplx) # TODO: float
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexPalm4MSA.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexPalm4MSA${FSUFFIX}.cpp @ONLY)
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexHierarchical_fact.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexHierarchical_fact${FSUFFIX}.cpp @ONLY)
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexButterfly.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexButterfly${FSUFFIX}.cpp @ONLY)
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexHierarchical2020.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexHierarchical2020${FSUFFIX}.cpp @ONLY)
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexHierarchical2020.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexHierarchical2020${FSUFFIX}.m @ONLY)
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexPALM4MSA2020.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexPALM4MSA2020${FSUFFIX}.cpp @ONLY)
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexPALM4MSA2020.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexPALM4MSA2020${FSUFFIX}.m @ONLY)
if(USE_GPU_MOD)
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexPALM4MSA2020_gpu2.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexPALM4MSA2020_gpu2${FSUFFIX}.cpp @ONLY)
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexPALM4MSA2020_gpu2.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexPALM4MSA2020_gpu2${FSUFFIX}.m @ONLY)
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexHierarchical2020_gpu2.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexHierarchical2020_gpu2${FSUFFIX}.m @ONLY)
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexHierarchical2020_gpu2.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexHierarchical2020_gpu2${FSUFFIX}.cpp @ONLY)
else()
file(REMOVE ${FAUST_MATLAB_MEX_SRC_DIR}/mexPALM4MSA2020_gpu2${FSUFFIX}.cpp) # delete a possible previous file generated with USE_GPU_MOD = ON (because otherwise it fails the building)
file(REMOVE ${FAUST_MATLAB_MEX_SRC_DIR}/mexHierarchical2020_gpu2${FSUFFIX}.cpp) # delete a possible previous file generated with USE_GPU_MOD = ON (because otherwise it fails the building)
endif()
# Givens FGFT is only for double and float scalars
if(NOT ${FAUST_SCALAR} MATCHES "complex")
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexfgftgivens.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexfgftgivens${FSUFFIX}.cpp @ONLY)
configure_file(${FAUST_MATLAB_MEX_SRC_DIR}/mexsvdtj.cpp.in ${FAUST_MATLAB_MEX_SRC_DIR}/mexsvdtj${FSUFFIX}.cpp @ONLY)
if(USE_GPU_MOD)
else()
endif()
endif()
# copy the *.m for factorization now, because we have the FSUFFIX in hands
configure_file(${FAUST_MATLAB_DOC_SRC_DIR}/mexHierarchical_fact.m.in ${FAUST_MATLAB_DOC_SRC_DIR}/mexHierarchical_fact${FSUFFIX}.m COPYONLY)
......@@ -87,8 +87,8 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
// initialization of the matrix that will be factorized
Faust::MatDense<SCALAR,Cpu> matrix;
mxArray2FaustMat(matlab_matrix,matrix);
Faust::MHTPParams<SCALAR> mhtp_params;
mxArray2FaustMHTPParams<SCALAR>(matlab_params, mhtp_params);
Faust::MHTPParams<Real<SCALAR>> mhtp_params;
mxArray2FaustMHTPParams<Real<SCALAR>>(matlab_params, mhtp_params);
auto *params = mxArray2FaustParams<SCALAR,FPP2>(matlab_params);
FPP2 lambda = params->init_lambda;
......@@ -101,7 +101,8 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
std::vector<Faust::StoppingCriterion<Real<SCALAR>>> sc = {params->stop_crit_2facts.get_crit(), params->stop_crit_global.get_crit()};
auto th = Faust::hierarchical(matrix, sc, fac_cons, res_cons, lambda, params->isUpdateWayR2L, params->isFactSideLeft, params->factors_format, params->packing_RL, mhtp_params, compute_2norm_on_arrays, params->norm2_threshold, params->norm2_max_iter, params->isVerbose, params->isConstantStepSize, params->step_size);
auto th_times_lambda = th->multiply(lambda);
SCALAR _lambda = SCALAR(lambda);
auto th_times_lambda = th->multiply(_lambda);
delete th;
th = th_times_lambda;
......@@ -116,11 +116,11 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
Faust::MatDense<SCALAR,Cpu> gpu_matrix(matrix);
Faust::MatDense<SCALAR,GPU2> gpu_matrix(matrix);
......@@ -135,9 +135,10 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
// gpu_matrix.Display();
// cout << "gpu_fac_cons.size():" << gpu_fac_cons.size() << endl;
auto th = Faust::hierarchical<FPP2, GPU2>(gpu_matrix, sc, gpu_fac_cons, gpu_res_cons, lambda, params->isUpdateWayR2L, params->isFactSideLeft, params->factors_format, params->packing_RL, mhtp_params, compute_2norm_on_arrays, params->norm2_threshold, params->norm2_max_iter, params->isVerbose, params->isConstantStepSize, params->step_size);
auto th = Faust::hierarchical<SCALAR, GPU2>(gpu_matrix, sc, gpu_fac_cons, gpu_res_cons, lambda, params->isUpdateWayR2L, params->isFactSideLeft, params->factors_format, params->packing_RL, mhtp_params, compute_2norm_on_arrays, params->norm2_threshold, params->norm2_max_iter, params->isVerbose, params->isConstantStepSize, params->step_size);
delete th;
......@@ -97,11 +97,11 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
// PALM4MSA parameters
auto params = mxArray2FaustParamsPALM4MSA<SCALAR,FPP2>(prhs[0], presentFields);
mxArray2FaustMHTPParams<SCALAR>(prhs[0], mhtp_params);
mxArray2FaustMHTPParams<Real<SCALAR>>(prhs[0], mhtp_params);
if(params->isVerbose) params->Display();
// Faust::BlasHandle<Cpu> blas_handle;
SCALAR lambda = params->init_lambda;
TransformHelper<SCALAR, Cpu>* F = nullptr, *F_lambda = nullptr;
......@@ -139,7 +139,8 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
params->norm2_max_iter, params->isConstantStepSize, params->step_size, false /* on_gpu*/, params->isVerbose);
Faust::MatDense<FPP2,Cpu> mat1x1Lambda = Faust::MatDense<FPP2, Cpu>(&lambda, 1, 1);
plhs[0] = FaustMat2mxArray(mat1x1Lambda);
F_lambda = F->multiply(lambda);
F_lambda = F->multiply(_lambda);
delete F; // if init_facts is used F is a copy too
F = F_lambda;
plhs[1] = convertPtr2Mat<Faust::TransformHelper<SCALAR, Cpu>>(F);
......@@ -102,11 +102,11 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
// creation of parameters
auto params = mxArray2FaustParamsPALM4MSA<SCALAR,FPP2>(prhs[0], presentFields); //Cpu world
TransformHelper<SCALAR, GPU2>* F = nullptr, *F_lambda = nullptr;
......@@ -162,7 +162,8 @@ void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
Faust::MatDense<FPP2,Cpu> mat1x1Lambda = Faust::MatDense<FPP2, Cpu>(1, 1, &lambda);
F = F_lambda;
auto cpuF = F->tocpu();
......@@ -689,7 +689,6 @@ const Params<SCALAR, Cpu, FPP2>* mxArray2FaustParams(const mxArray* matlab_param
mxCurrentField = mxGetField(matlab_params, 0, mat_field_type2str(FACTOR_FORMAT).c_str());
factors_format = static_cast<FactorsFormat>((int)mxGetScalar(mxCurrentField));
std::cout << "mx2Faust factors_format:" << factors_format << std::endl;
bool packing_RL = Params<SCALAR, Cpu, FPP2>::defaultPackingRL;
