Commit 06d39154 authored by hhakim's avatar hhakim
Remove the mingw/cython build code in CMakeLists.txt (issue #91)
parent 38b10b94
...@@ -217,8 +217,7 @@ if(UNIX) ...@@ -217,8 +217,7 @@ if(UNIX)
COMMENT "Creating pyfaust${PY_VER}") COMMENT "Creating pyfaust${PY_VER}")
endforeach() endforeach()
elseif(WIN32) elseif(WIN32)
if(NOT ${CMAKE_GENERATOR} MATCHES "MinGW Makefiles") if(NOT ${CMAKE_GENERATOR} MATCHES "Visual Studio")
# TODO: replace by MATCHES Visual Studio ?
foreach(PYTHON_EXE IN LISTS PYTHON_EXES) foreach(PYTHON_EXE IN LISTS PYTHON_EXES)
exec_program("${PYTHON_EXE}" ARGS "--version" OUTPUT_VARIABLE PY_VER RETURN_VALUE PY_RES) exec_program("${PYTHON_EXE}" ARGS "--version" OUTPUT_VARIABLE PY_VER RETURN_VALUE PY_RES)
#message(STATUS "PY_VER=${PY_VER}") #message(STATUS "PY_VER=${PY_VER}")
...@@ -235,75 +234,9 @@ elseif(WIN32) ...@@ -235,75 +234,9 @@ elseif(WIN32)
set(PY3_MINOR_VER ${PY3_MINOR_VER} PARENT_SCOPE) set(PY3_MINOR_VER ${PY3_MINOR_VER} PARENT_SCOPE)
endif() endif()
else() # ${CMAKE_GENERATOR} MATCHES "MinGW Makefiles"
# manually compiling cython extension instead of using setup.py in order to avoid visual studio to meddle in the compilation (we use mingw gcc here)
if(CYTHON_EXES_LEN AND NOT NOPY2)
foreach(INDEX RANGE 0 ${CYTHON_EXES_LEN} 1)
#message(STATUS "INDEX=${INDEX}")
if(${INDEX} LESS ${CYTHON_EXES_LEN})
list(GET CYTHON_EXES ${INDEX} CYTHON_EXE)
#list(GET PYTH0N_EXES ${INDEX} PYTHON_EXE)
# workaround to the previous command which fails to retrieve PYTHON_EXES item
if(${INDEX} EQUAL 0)
string(REGEX REPLACE "(.*);.*$" "\\1" PYTHON_EXE "${PYTHON_EXES}")
else()
string(REGEX REPLACE ".*;(.*)$" "\\1" PYTHON_EXE "${PYTHON_EXES}")
endif()
string(REGEX REPLACE "(.*)(/|\\\\).*" "\\1" PYTHON_PARENT_PATH ${PYTHON_EXE})
#message(STATUS "PYTHON_PARENT_PATH=${PYTHON_PARENT_PATH}")
#message(STATUS "PYTHON_EXE=${PYTHON_EXE}, PYTHON_EXES=${PYTHON_EXES}, INDEX=${INDEX}")
# get abbreviated python version
string(REGEX REPLACE "Python ([0-9]\\.[0-9]).*$" "\\1." PY_VER_WITH_POINTS ${PY_VER})
string(REGEX REPLACE "Python ([0-9])\\.([0-9]).*$" "\\1\\2" PY_VER ${PY_VER})
# set header inclusion flags
string(REGEX REPLACE "," ";-I" FAUST_PY_CFLAGS ${FAUST_PYTHON_INCLUDE_DIR})
string(REGEX REPLACE "'" "" FAUST_PY_CFLAGS ${FAUST_PY_CFLAGS})
set(FAUST_PY_CFLAGS "${FAUST_PY_CFLAGS};-I${PYTHON_PARENT_PATH}\\include")
# get numpy header dir
execute_process(COMMAND "${PYTHON_EXE}" "-c" "import numpy;print(numpy.get_include())" OUTPUT_VARIABLE NUMPY_INCLUDE ERROR_VARIABLE PY_ERR RESULT_VARIABLE PY_RES)
#message(STATUS "NUMPY_INCLUDE=${NUMPY_INCLUDE}")
set(FAUST_PY_CFLAGS "-I${FAUST_PY_CFLAGS};-I${NUMPY_INCLUDE}")
string(REGEX REPLACE "\n" "" FAUST_PY_CFLAGS ${FAUST_PY_CFLAGS})
string(REGEX REPLACE ";?-I" ";-I" FAUST_PY_CFLAGS ${FAUST_PY_CFLAGS})
# find libfaust.a to statically link it into the python wrapper lib
#find_library(FAUST_LIB_PATH libfaust.a PATHS ${PROJECT_BINARY_DIR}/lib PATH_SUFFIXES release debug NO_DEFAULT_PATH)
# use rather generated expression to point to faust target file below ("$<TARGET_FILE:${FAUST_TARGET}>")
#message(STATUS "FAUST_LIB_PATH=${FAUST_LIB_PATH}")
find_library(MATIO_STATIC_LIB_PATH libmatio.a PATHS ${MATIO_LIB_DIR} NO_DEFAULT_PATH)
set(PYTHON_STATIC_LIB_PATH PYTHON_STATIC_LIB_PATH-NOTFOUND) # forcing search of lib (otherwise could be stuck to the previous iteration python)
find_library(PYTHON_STATIC_LIB_PATH libpython${PY_VER}.a PATHS ${PYTHON_PARENT_PATH} PATH_SUFFIXES libs NO_DEFAULT_PATH)
#message(STATUS "PYTHON_STATIC_LIB_PATH=${PYTHON_STATIC_LIB_PATH}")
if(PY_VER MATCHES 3)
set(PY_DYNLIB "_FaustCorePy.cp${PY_VER}-win_amd64.pyd")
set(PY3_VER ${PY_VER_WITH_POINTS})
string(REGEX REPLACE ".*([0-9])$" "\\1" PY3_MINOR_VER ${PY_VER})
else() #py 2.7.x
set(PY_DYNLIB "_FaustCorePy.pyd")
endif()
set(PY_STATIC_LIBS "$<TARGET_FILE:${FAUST_TARGET}>;${MATIO_STATIC_LIB_PATH};${PYTHON_STATIC_LIB_PATH}")
string(REGEX REPLACE "\n" ";" PY_STATIC_LIBS "${PY_STATIC_LIBS}")
add_custom_command(TARGET ${FAUST_PYTHON_TARGET}
COMMAND ${CYTHON_EXE}
ARGS "--cplus" "-o" "${FAUST_PYTHON_BIN_DIR}/_FaustCorePy.cpp" "${FAUST_PYTHON_BIN_DIR}/_FaustCorePy.pyx"
# patch the weird bug: missing cmath include in cython generated cpp code
COMMAND echo \#include ^<cmath^> ">" "FAUST_CORE_TMP_FILE"
COMMAND type
ARGS "FAUST_CORE_TMP_FILE" "_FaustCorePy.cpp" ">" "_FaustCorePy.cpp2" 2>NUL
COMMAND type
ARGS "_FaustCorePy.cpp2" ">" "_FaustCorePy.cpp" 2>NUL
COMMAND ${CMAKE_CXX_COMPILER}
ARGS "-std=c++11" "-shared" "-DMS_WIN64" "-s" "-O3" "${WIN32_GCC_OMP}" "-o" "${PY_DYNLIB}" "${FAUST_PYTHON_BIN_DIR}/_FaustCorePy.cpp" ${FAUST_PY_CFLAGS} ${PY_STATIC_LIBS}
endif()
endforeach()
endif()
endif() endif()
else() else()
message(FATAL_ERROR "Win32 python Faust version is supported only when compiling with MinGW") message(FATAL_ERROR "Not handled system.")
endif() endif()
#install the python wrapper #install the python wrapper
